Indigo Mac Client
When you double click on the Indigo 6 icon in the Applications folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
Home Window
The Home Window is in 4 areas:
- Outline View
- Item List
- Item Detail
- Status Bar
Outline View
To create a new folder, select the main object type in the list then click the plus (+) button at the lower-left corner of the outline view. A new folder will appear and you can just start typing its new name. To delete a folder, select it, then click on the gear icon or right-click the folder (bring up the contextual menu). The resulting menu will allow you to select Delete Folder then delete it. If the folder isn't empty, it will show you a sheet with 3 options: Cancel (do nothing), Delete Items (delete the items in the folder along with the folder), or Move Items (move the items to the parent first then delete the folder).
From the same menu, you can select Rename Folder… to rename it, Enable/Disable Remote Display (for devices, action groups, and control pages) to show/hide it in remote clients (like Indigo Web Server (IWS) pages or Indigo Touch), or copy the unique folder ID for use in Python scripts.
Item List
This menu will:
indigo.devices[91776575] # “Living Room Switch” - Copy an AppleScript string that you can use to reference the object. It will look like this:
device named “Living Room Switch”
- Enable/disable the event.
indigo.triggers[565290390] # “Motion Sensor Dawn Triggered” - Copy an AppleScript string that you can use to reference the object. It will look like this:
trigger action named “Motion Sensor Dawn Triggered”
indigo.actionGroups[1703232002] # “Toggle Variable” - Copy an AppleScript string that you can use to reference the object. It will look like this:
action group named “Toggle Variable”
Item Detail
Lights/Appliances
Speed Controls
Sprinklers (Pro Only)
Thermostats (Pro Only)
Generic Output Devices (Pro Only)
I/O Controls Image
Triggers and Schedules
The Execute Actions Now button will do exactly that - execute all the actions associated with the object. NOTE: just as the triggering event will be ignored, so will any conditions associated with the object.
Control Pages
Status Bar
Event Log Window
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 6→Preferences… and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
Variable Window
Menus
Indigo 6 Menu
About Indigo 6- this will show the About window which will show what client and server versions you're running and will show your registration codeStart Local Server…- this will open the Start Server dialogStop Server- this will stop the Indigo ServerConnect to Remote Server…- this option will allow you to connect to a different Indigo server or a server running on another MacClose Connection- this will close the connection to the serverPreferences…- this opens the preferences dialogCheck for Updates…- this will have the server your connected to contact us to see if there is an update available
File Menu
New Database…- this will close the current database and create a new one - you'll be prompted for a name and save locationSelect Database…- this will allow you to switch to a different databaseClose Window- this will close the frontmost windowNew Device…- this will switch the Home Window to the devices view and open the new device dialogNew Trigger…- this will switch the Home Window to the triggers view and open the new trigger dialogNew Schedule…- this will switch the Home Window to the schedules view and open the new schedule dialogNew Action Group…- this will switch the Home Window to the action groups view and open the new action group dialog
Edit Menu
View Menu
Go Menu
Browser Devices Page- this will open your default web browser to the built-in devices listBrowser Actions Page- this will open your default web browser to the built-in actions listBrowser Variables Page- this will open your default web browser to the built-in variable listBrowser Control Pages- this will open your default web browser to the control page list (this option is only available in Indigo Pro)Event Logs Folder- this will open the Event Logs folder in the FinderPurchase Hardware- this will open your default web browser to our online store (the Indigo Store) – if you are running a trial copy this item will be called “Purchase Indigo” and will take you to the Indigo purchase pageOnline Support Forum- this will open your default web browser to our online support forums
The Go menu may have some other options in it as well - if you're using a trial or Indigo Lite it will give you the option to enter new codes and to purchase a license.
Interfaces Menu
Z-Wave® Menu
The Z-Wave interface menu has several options:
Enable/Disable- toggles the interface on and offReload- will cause the interface to restartConfigure…- opens the configuration preferences for the Z-Wave interfaceHelp with Z-Wave networks…- opens a browser window to the help page for managing your Z-Wave Network.Manage Associations…- opens the dialog where you can manage device associations and scenesRemove Failed Modules from Controller…- use this menu item remove any Z-Wave nodes that may no longer exist on the network.Reset Z-Wave Interface…- use this menu to completely reset your Z-Wave interface. You should only do this if Indigo support instructs you to.
INSTEON/X10 Powerline Submenu
Enable/Disable- toggles the interface on and offConfigure…- opens the configuration preferences for this interfaceUpload Settings…- opens the upload dialogManage INSTEON PowerLinc Links…- opens the PowerLinc link editor windowManage INSTEON Device Links…- opens the device link editor windowStart Sync INSTEON Device Links…- starts any pending link sync operationsStop Sync INSTEON Device Links- stops any ongoing linking operations
For Indigo Pro users, there are some other menu items added to this menu. Those are described in the Managing Your INSTEON Network in Indigo document.
X10 RF Submenu
Enable/Disable- toggles the interface on and offConfigure…- opens the configuration preferences for this interfaceHelp with X10 RF Interfaces…- opens a browser to the documentation for configuring this type of interface.
Virtual Devices Submenu
Enable/Disable- toggles the interface on and offReload- will cause the interface to restartHelp with Virtual Devices…- opens a browser window to the documentation page for Virtual Devices.Update Device Group Saved States…- will allow you to update the stored states for each device in the specified Device Group.Toggle Debugging- toggles debugging information in the Event Log on and off. Used primarily for technical support.
Manage Interfaces... Menu Item
Selecting the Interfaces→Manage Interfaces… menu item will open the interface preferences dialog.
Plugins Menu (Pro only)
The Plugins menu (Indigo Pro Only) will adjust based on the plugins you have installed. These menu items will always be present:
Reload Libraries and Attachments- this will reload all the attachment AppleScripts that are in the Scripts/Attachments directory of the Indigo system directory (/Library/Application Support/Perceptive Automation/Indigo 6/). It will also reload the various Python library directories (i.e. /Users/usernamehere/Library/Python/2.5/site-packages/) so that if you add Python libraries while the server is running your scripts can immediately access those librariesManage Plugins…- this item will open the preferences window to the Plugins tab3rd Party Plugin List- opens a browser to the 3rd Party Plugin list on our wiki so you can easily find plugins for other devices you might have or wish to acquireOpen Scripting Shell- this will open a terminal window and start the interactive Python shell with the Indigo module loaded - see the Scripting Tutorial for more information
For information about the plugins, see the About… menu item for each plugin.
Window Menu
Help Menu
Help for XXXX- this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular itemHow-To Wiki- this will also change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)Email Log…- this option will email some of your event log data to the specified email address. Particularly useful for technical supportIndigo 6 Documentation- this will open your browser to the landing page for all Indigo 6 documentationGetting Started Guide- this will open your browser to the Getting Started Guide, the place where everyone new to Indigo should startManaging a Z-Wave Network- opens a browser window to the Managing Your Z-Wave Network document in our Documentation wikiManaging an INSTEON Network- opens a browser window to the Managing Your INSTEON Network document in our Documentation wikiOnline Support Forum- this will open your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as wellSupported Built-in Device List- opens a browser window on our new Supported Devices web application that shows which devices and interfaces have been tested with IndigoUser Contribution Library- this will open your browser to our file library - where anyone can contribute apps, images, scripts, plugins, etc. that others may find useful
