Getting Started Guide
Z-Wave
  • Sensors (contact, magnetic, motion, temperature, etc.)
  • Thermostats
  • Locks
INSTEON
X10
Other Devices
The Indigo 7.3 application can be found here:
  /Applications/Indigo 7.3.app
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 7.3 installer again (which will repair any permission issues that Time Machine may have introduced).
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and earlier), the installer moves previously installed control page images and web server plugins to the new install location.
  1. Shut down the Indigo Server by selecting the Indigo 7.2→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.2→Quit Indigo menu item.
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and earlier), the installer is now smarter and moves previously installed control page images and web server plugins to the new install location.
  1. Shut down the Indigo Server by selecting the Indigo 7→Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7→Quit Indigo menu item.
After running the Indigo 7 installer, here are a few things you may need to consider:
  • Indigo 7 moved to Python 2.7, so if you installed any shared scripts (as outlined here) then you'll need to move them from: /Library/Python/2.6/site-packages/ to /Library/Python/2.7/site-packages/
  • Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo 7, then it will automatically be installed and used on launch.
  • Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 2/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 2/IndigoWebServer/images/
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 6, 5, 4, 3, or 2 files. They have been modified to run optimally under Indigo 7(.X).
  • Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. You will be prompted to save the new copy of the Indigo database file. The Indigo 7(.X) file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo 7(.X) to your database settings will not be available in older versions of Indigo.
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 1.x files. They have been modified to run optimally under Indigo 7(.X).
  1. Deactivate Indigo on your Mac by selecting the Indigo 7.3→License Details… menu item and clicking the Deactivate License button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first).
  2. Copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 7.3/
  3. Install Indigo 7.3 on the new Mac (download and run the installer)
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 7.3→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Deactivate Sheet Image
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 7.3 menu if the server is still running before you quit the Indigo Mac Client).
  • /System/Library/Extensions/IndigoOverrides.kext
  • ~(your user folder)/Library/Preferences/Indigo 7 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 7 Client Settings.indiPref
To uninstall older versions but leave 7.3 installed correctly, delete these:
  • Indigo 7.2:
  • Indigo 7.0 and 7.1:
    • /Applications/Indigo 7.app
    • /Applications/Indigo 6.app
  1. Double click the Indigo 7.3 application (/Applications/Indigo 7.3.app).
  2. If this is the first time to run Indigo 7 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 7.3→Start Local Server… menu item.
Start Server Dialog Image
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application radio button. This will automatically run the client/server as a single application. This requires that the Indigo UI always be running on your Mac - when you quit the Indigo 7.3 Client application (Indigo 7.3→Quit) all Indigo event processing (triggers, schedules, scripts, etc.) will cease processing. This is not our recommended configuration.
Use the Enable anywhere secure access checkbox for secure Web browser access from anywhere. This option requires a you to have configured a Reflector, which handles maintaining the secure connection to Indigo Server automatically. Reflectors are included as part of your Up-to-Date subscription.
Use the Enable remote Indigo client access checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server.
Use the Log Device state history to SQLite or PostgreSQL checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions.
Login Dialog Image
Firewall Prompt Image
IPH Firewall Prompt Image
Network WiFi Image
Network Wired Image
  2. Double click the Indigo 7.3 application (inside /Applications/Indigo 7.3.app) on the remote Mac.
  3. If this is the first time to run Indigo 7 on this remote Mac, then press the Connect to Remote Server… button in the connection status window.
  4. If you are wanting to connect to a different Indigo Server, then select the Indigo 7→Connect to Remote Server… menu item.
  7. Press the Connect button.
Client Connect Dialog Image
 http://192.168.1.23:8176/
Interfaces Menu Image
Interfaces Tab Image
  2. Make sure that the plugin is supported by Indigo 7.2 (look for the Requires field).
  10. Done!
Incompatible Plugins
Note if you see the error alert below that the “Plugin is not compatible” then the version of the plugin you installed is too new to run with your Indigo Server version. In this case the best solution is to upgrade your version of Indigo Server.
Plugin Configuration
Plugin Configuration Dialog Image
Main Plugins Menu
Plugin Menu Image
Individual Plugin Submenu
Plugin Enabled Submenu Image
The next section contains:
Other Menus with Plugin Items
Plugin New Device Image
Plugin Events Image
Plugin Actions Image
Plugins Tab Image
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 7→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
  1. Shut down the Indigo Server by selecting the Indigo 7.3→Stop Server menu item in the Mac client (you can leave the client app running).
  2. Open the following folder in the Finder: /Library/Application Support/Perceptive Automation/Indigo 7.3/ (you can select the Go→Go to Folder… menu item in the Finder and paste in the path to open a Finder window). In that Finder window you'll see two folders: Plugins and Plugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin.
  3. Switch back to the Indigo 7.3 Mac client and click on the Start Local Server… button in the Server Connection Status dialog.
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as [email protected]. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server options shown below to reduce mailbox clutter.
Email Tab Image
To configure email sending
  1. Choose Indigo 7→Preferences… menu item, then make sure the Email tab is selected.
To configure email scanning
Longitude Latitude Tab Image
  • Choose the Indigo 7.3→Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
General Preferences Tab Image
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 7→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 7→Check for Updates… menu item.
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/getting_started.txt
