Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start (which will be deprecated in a future version of Indigo 7). Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
Back to Top
Folder Structure Image
in this location:
Back to Top
Bundle Layout Image
<plist version="1.0">
<dict>
	<key>PluginVersion</key>
	<string>1.2.3</string>
	<key>ServerApiVersion</key>
	<string>2.0</string>
	<key>CFBundleIdentifier</key>
	<key>CFBundleVersion</key>
	<string>1.0.1</string>
	<key>CFBundleURLTypes</key>
	<array>
		<dict>
			<key>CFBundleURLName</key>
		</dict>
	</array>
</dict>
</plist>
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.
  • ServerApiVersion - this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • Bundle name (CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.
  • Bundle identifier (CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.yourorgidentifier.* namespace. This key is required.
  • Bundle version (CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.1. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
You can drop Python scripts and AppleScripts (AppleScript support will be deprecated in a future version of Indigo 7) into this folder and they will show up in your plugin's sub-menu on the new “Plugins” menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI.
This folder is meant to contain any assets (like images, templates, etc.) that your plugin might need. If there is an icon.png file in here, it will be displayed in the Plugin Store once you submit the plugin (see Plugin Store below for more details).
Back to Server Plugins
Server Plugin Folder Image
  • id's cannot contain spaces
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Text Field
    <Label>Text Field:</Label>
</Field>
Back to Configuration Dialogs
Configuration UI Menu Image
	<Label>Popup Menu:</Label>
</Field>
</Field>
    return valuesDict
List
Configuration UI List Image
	<Label>List:</Label>
</Field>
Dynamic Lists
</Field>
Class: indigo.devices
Optional Filters Description
indigo.relayrelay devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Class: indigo.triggers
</Field>
	return myArray
</Field>
</Field>
Serial Port
Configuration UI Serial Port Socket Image
Configuration UI Serial Port RFC2217 Image
Checkbox
	<Label>Checkbox:</Label>
</Field>
</Field>
    return valuesDict
Label
Configuration UI Label Image
<Field id="exampleLabel" type="label"
	</Label>
</Field>
Separator
<Field id="simpleSeparator1"
		type="separator"
		visibleBindingValue="1"/>
Button
Configuration UI Button Image
		type="button"
		visibleBindingValue="1">
</Field>
The process flow is this:
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
    return True
    return (True, valuesDict)
    errorDict = indigo.Dict()
Validating serialport Fields
	errorsDict = indigo.Dict()
	if len(errorsDict) > 0:
Dialog Close Notification
Dialog Type Method Signature
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/Plugins/
Name Type Required Notes
Custom Device Type
    <State id="temperature">
        <ValueType>Number</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
<Events>
    <Event id="updateAvailable">
    </Event>
</Events>
<Event id="sep1"/>
<Actions>
    <Action id="resetInterface">
        <Name>Reset Interface</Name>
    </Action>
</Actions>
<Action id="sep1"/>
def writeToLog(self, action):
    if theType:
        indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
<MenuItems>
    <MenuItem id="menu1">
    </MenuItem>
    <MenuItem id="menu2">
    </MenuItem>
    <MenuItem id="menu3">
        <ConfigUI>
			<Label>Light:</Label>
		</Field>
        </ConfigUI>
    </MenuItem>
    <!-- Added in v1.2 -->
    <MenuItem id="menu4">
    </MenuItem>
</MenuItems>
def checkForUpdates(self):
In API v1.x
General Plugin Methods
__init__(self,
         pluginId,
         pluginDisplayName,
         pluginVersion,
         pluginPrefs)
__del__(self)
def __del__(self):
startup(self)
def startup(self):
shutdown(self)
def shutdown(self):
runConcurrentThread(self)
    while True:
        # Do your stuff here
        self.sleep(60) # in seconds
except self.StopThread:
    # do any cleanup here
    pass
stopConcurrentThread(self)
    self.stopThread = True
prepareToSleep(self)
wakeUp(self)
Device Specific Methods
getDeviceStateList(self,
                   dev)
getDeviceDisplayStateId(self,
                        dev)
deviceStartComm(self,
                dev)
deviceStopComm(self,
               dev)
                            origDev,
                            newDev)
deviceCreated(self,
              dev)
Deprecated in 1.4 This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use deviceStartComm() instead.
deviceUpdated(self,
              origDev,
              newDev)
deviceDeleted(self,
              dev)
Trigger Specific Methods
triggerStartProcessing(self,
                       trigger)
triggerStopProcessing(self,
                      trigger)
                                   origTrigger,
                                   newTrigger)
triggerCreated(self,
               trigger)
triggerUpdated(self,
               origTrigger,
               newTrigger)
triggerDeleted(self,
               trigger)
Schedule Specific Methods
Action Group Specific Methods
Name Required Notes
Variable Specific Methods
Name Required Notes
variableCreated(self, var)
variableDeleted(self, var)
                                bundleID)
browserOpen(self,
            url)
debugLog(self,
         msg)
errorLog(self,
         msg)
openSerial(self,
         ownerName,
         portUrl, baudrate, bytesize,
         parity, stopbits, timeout,
         dsrdtr, interCharTimeout)
sleep(self,
         seconds)
substituteVariable(self,
                   inString,
                   validateOnly=False)
String
if validateOnly is False
(BOOL, errStr)
if validateOnly is True
%%v:VARID%%
substituteDeviceState(self,
                      inString,
                      validateOnly=False)
String
(BOOL, errStr)
%%d:DEVICEID:STATEKEY%%
substitute(self,
           inString,
           validateOnly=False)
Attribute Description
self.indigo_log_handler
self.plugin_file_handler
Log Levels
Logging from submodules
Back to Top
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/plugin_guide.txt
