is generally considered to be Python (or in the various example sections, AppleScript) code and represents the exact code needed. You'll also see code blocks like this:
You should be able to tell from the context if it's Python code or, sometimes, AppleScript (which will be deprecated in Indigo 7.4+), if we're comparing how to do something.
Term | Meaning |
For Scripters and Developers:
myObject.replaceOnServer()
myObject.refreshFromServer()
method.For Developers:
Devices | ||
Schedule | ||
Schedule (indigo.Schedule) | indigo.schedule.* | manipulate a scheduled event ![]() |
Triggers | ||
Action Groups | ||
Variables | ||
General Commands | ||
and delete()
If you are a user of the Indigo AppleScript Dictionary (AppleScript support will be deprecated in a future version of Indigo 7), you may have certain expectations set about how you would use the IOM in Python. While there are similarities, there are also some non-trivial differences. Most of these will become apparent in the following sections, but we’d like to outline a few here.
First, and most obvious, is the nature of most objects in the IOM as we discussed earlier - using copies and updating the server when you change the properties. In AppleScript, when you alter an object’s property the change is instantaneous since the script is running in the IndigoServer process. That significant architectural difference is what led us to the split between objects and the commands that work on them.
The next difference that you’ll notice is that there are many more classes in the IOM than there are in AppleScript. That’s because in AppleScript the classes are very flat: a device contains all possible properties for all devices. The same applies to the action step
(Action
in the IOM) class: in AppleScript it contains all possible properties for every action type. In the IOM, we broke these out into an object hierarchy in which a base class is defined that contains the common properties, then subclasses add the specifics for each type. Check out the figure in the next section for a graphical depiction of the object hierarchies in the IOM.
item 1 of myArray
myArray[0]
and indigo.List()
and list
The behavior of indigo.Dict
and indigo.List
Object | Description |
is a shortcut to get the string name of the item. Normally you would need to get a copy of the object (which would pull the entire object from the IndigoServer) then get the name, but this method is more efficient since it only gets the name from the IndigoServer rather than the whole object. So, an easy way to get a variable folder's name (maybe for logging) would be to do this: indigo.variables.folders.getname(1234)
at plugin start so that you'll always be notified when any device changes - you can then determine if your scene “state” has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming()
and subscribeToOutgoing()
methods in the indigo.insteon
and indigo.x10
command spaces to see commands regardless of their effect on device state.
Python | AppleScript (which will be deprecated in a future version of Indigo 7) |
for dev in indigo.devices: # do stuff with dev here | repeat with dev in every device -- do stuff with dev here end repeat |
Filter | Description |
Triggers also have filters:
Possible Exceptions | |
, MemoryError
, OverflowError
# first, let's get an indigo.DimmerDevice like a LampLinc >>> dev = indigo.devices[238621905] >>> dev.__class__ <class 'indigo.DimmerDevice'> >>> hasattr(dev,'onState') True >>> dir(dev) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'brightness', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'onState', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # Next, an indigo.ThermostatDevice >>> thermo = indigo.devices[171495708] >>> thermo.__class__ <class 'indigo.ThermostatDevice'> >>> dir(thermo) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'coolIsOn', 'coolSetpoint', 'description', 'deviceTypeId', 'enabled', 'fanIsOn', 'fanMode', 'folderId', 'globalProps', 'heatIsOn', 'heatSetpoint', 'humidities', 'humiditySensorCount', 'hvacMode', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'temperatureSensorCount', 'temperatures', 'updateStateOnServer', 'version'] # Here's a plugin defined device >>> tunes = indigo.devices["Whole House iTunes"] # notice that it only shows the Device base class >>> tunes.__class__ <class 'indigo.Device'> >>> dir(tunes) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # You can use the deviceTypeId attribute to get the plugin's defined type >>> tunes.deviceTypeId u'mediaserver'
