Getting Started Guide
Welcome to Indigo 7.4!
- Mac OS X 10.7.5 (https://en.wikipedia.org/wiki/Mac_OS_X_Lion) or higher.
- Any Mac capable of running Mac OS X 10.7.5.
Z-Wave
- ON/OFF devices (plug-in modules, switches, and outlets)
- Dimmers (plug-in modules and switches)
- Sensors (contact, magnetic, motion, temperature, etc.)
- Thermostats
- Locks
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
- The Indigo Installer.pkg file - double click this to start the Indigo installation. Follow the instructions provided by the installer. On the Installation Type screen, press the Install button (do not use Customize) to install all the Indigo packages (Server, Server Scripts, Drivers, and Client) on your designated hard drive. Note: you must install and run Indigo from an account on your Mac that has administrator privileges.
The Indigo 7.4 application can be found here:
/Applications/Indigo 7.4.app
/Library/Application Support/Perceptive Automation/Indigo 7.4/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 7.4 installer again (which will repair any permission issues that Time Machine may have introduced).
Upgrading from Indigo 7.3
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and earlier), the installer moves previously installed control page images and web server plugins to the new install location.
Indigo 7.3→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.3→Quit Indigomenu item. - Open the
Upgrading from Indigo 7.2
Indigo 7.2→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.2→Quit Indigomenu item. - Open the
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and earlier), the installer is now smarter and moves previously installed control page images and web server plugins to the new install location.
Indigo 7→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7→Quit Indigomenu item. - Open the
First, run the Indigo 7.4 installer. Then look through this list for any final actions.
- Indigo 7 moved to Python 2.7, so if you installed any shared scripts (as outlined here) then you'll need to move them from:
/Library/Python/2.6/site-packages/to/Library/Python/2.7/site-packages/ - Indigo will automatically copy your old preference file into the new location during the installation.
- Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo 7, then it will automatically be installed and used on launch.
- Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 6/Scripts/ - Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/ - Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 5/Scripts/ - Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/ - Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 4/Scripts/ - Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/ - Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 2/Scripts/ - Control Page Images:
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 6, 5, 4, 3, or 2 files. They have been modified to run optimally under Indigo 7(.X).
AppleScript after Upgrading
Upgrading from Indigo 1.x
- Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. You will be prompted to save the new copy of the Indigo database file. The Indigo 7(.X) file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo 7(.X) to your database settings will not be available in older versions of Indigo.
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 1.x files. They have been modified to run optimally under Indigo 7(.X).
Moving an Indigo 7 Installation to another Mac
Indigo 7.4→License Details…menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 7.4/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 7.4 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
Uninstalling Indigo
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 7.4→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 7.4 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 7.4//System/Library/Extensions/IndigoOverrides.kext~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist
/Applications/Indigo 7.4.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-client6.plist~(your user folder)/Library/Preferences/Indigo 7 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 7 Client Settings.indiPref
To uninstall older versions but leave 7.4 installed correctly, delete these:
- Indigo 7.3:
- Indigo 7.2:
- Indigo 7.0 and 7.1:
Starting Indigo Server
- Double click the
Indigo 7.4application (/Applications/Indigo 7.4.app). - If this is the first time to run
Indigo 7on this Mac, then press theStart Local Server…button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 7.4→Start Local Server…menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application radio button. This will automatically run the client/server as a single application. This requires that the Indigo UI always be running on your Mac - when you quit the Indigo 7.4 Client application (Indigo 7.4→Quit) all Indigo event processing (triggers, schedules, scripts, etc.) will cease processing. This is not our recommended configuration.
Running in Client/Server Mode
Use the Enable anywhere secure access checkbox for secure Web browser access from anywhere. This option requires a you to have configured a Reflector, which handles maintaining the secure connection to Indigo Server automatically. Reflectors are included as part of your Up-to-Date subscription.
Use the Enable remote Indigo client access checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server.
Use the Log Device state history to SQLite or PostgreSQL checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions.
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 7.4application (inside/Applications/Indigo 7.4.app) on the remote Mac. - If this is the first time to run
Indigo 7on this remote Mac, then press theConnect to Remote Server…button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 7.4→Connect to Remote Server…menu item. - Enter the
Connectbutton.
http://192.168.1.23:8176/
Managing Plugins
Installing Plugins
- Make sure that the plugin is supported by Indigo 7.2 (look for the Requires field).
- Click the
Download Latest Releasebutton, which will download the plugin. - When the download is complete, click on the down arrow in the title bar which will show the plugin download.
- Click the
Incompatible Plugins
Note if you see the error alert below that the “Plugin is not compatible” then the version of the plugin you installed is too new to run with your Indigo Server version. In this case the best solution is to upgrade your version of Indigo Server.
- Open the Trash folder from the Finder
- Move the previous (older) version of the plugin from the Trash folder to your Desktop.
- Lastly, follow the same instructions as above to re-install the older version of the plugin (Double-click it).
Plugin Configuration
Plugin Menus in Indigo
Main Plugins Menu
a green dot with no arrows means the plugin is enabled
Individual Plugin Submenu
The next section contains:
- the
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 7→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
- the
Uninstalling a Plugin
Indigo 7.4→Stop Servermenu item in the Mac client (you can leave the client app running). - Open the following folder in the Finder:
/Library/Application Support/Perceptive Automation/Indigo 7.4/(you can select theGo→Go to Folder…menu item in the Finder and paste in the path to open a Finder window). In that Finder window you'll see two folders:PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. - Switch back to the Indigo 7.4 Mac client and click on the
Configuring Email Settings
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as [email protected]. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server options shown below to reduce mailbox clutter.
To configure email sending
- Choose
Indigo 7→Preferences…menu item, then make sure theEmailtab is selected. - Enter your SMTP server address. You probably don't need to change the SMTP server port, but if your server uses SSL (TLS) security, check that checkbox.
- Enter your SMTP username and password (these may be optional)
- If you want the recipient of the email to reply to a different email address than the one you're sending from, enter it in the
Reply-to email addressfield. Note that some SMTP mail servers are configured to not send emails unless the reply-to address specified matches the email address for the account. If mail sending fails, then make sure that the reply-to email address matches the email address for your account.
To configure email scanning
- Choose
Indigo 7→Preferences…menu item, then make sure theEmailtab is selected. - Enter your POP server address, user (also called account) name, and password.
- Select the
Check email everycheckbox. - Enter the time interval to wait between email scans (default 10 minutes).
- Optionally choose
Delete from server emails that trigger actionsto have Indigo automatically remove any email messages that cause Indigo to trigger an action from your mail server. You should only use this option if Indigo has a dedicated email account. - Optionally choose
Delete from server all emailsto have Indigo automatically remove all email messages from your mail server. You should only use this option if Indigo has a dedicated email account.
- Choose
Date & Timeicon. - Select the
- Choose the
Indigo 7.4→Preferences…menu item, then make sure theSunset & Sunrisetab is selected. - Select the
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 7→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 7→Check for Updates… menu item.
- Choose
Energy Savericon. - Move the
Where to Go Next
