Indigo Scripting Tutorial
Talking to the Indigo Server
To launch the Terminal utility application (inside /Applications/Utilities/
) in an Indigo shell mode choose the Plugins→Open Scripting Shell
menu item.
Example Code Snippets
Note: For simplicity some of the samples below specify objects based on name (“office desk lamp”
Device Examples
indigo.device.turnOn(1234567890) # Preferred, where the number is the ID of "office desk lamp" # OR the less preferred way because it will break if you rename the device indigo.device.turnOn("office desk lamp")
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
from datetime import datetime lamp = indigo.devices[91776575] # ID of "Hallway light" timeDelta = datetime.now() - lamp.lastChanged if not lamp.onState and timeDelta.seconds > 60: indigo.device.turnOn(91776575) # ID of "Hallway light"
Access a custom device state
Variable Examples
newVar = indigo.variable.create("fooMonster", "default value") indigo.variable.updateValue(newVar, "asleep") indigo.variable.updateValue(newVar, "awake") indigo.variable.delete(newVar)
Getting a variable object and using it's value:
myVar = indigo.variables[123] if myVar.value == "true": indigo.server.log("The variable had a value of 'true'")
Duplicating a variable:
myVar = indigo.variables[1893500335] # always use variable ID rather than name import urllib, urllib2 urllib2.urlopen("http://example.com/foo/bar?param=%s" % urllib.urlencode(myVar.value))
myAsciiString = "ASCII String" indigo.variable.updateValue(1234567, value=myAsciiString) myUnicodeString = u"éçø" indigo.variable.updateValue(1234567, value=myUnicodeString) myInteger = 1 indigo.variable.updateValue(1234567, value=unicode(myInteger)) myFloat = 1.0 indigo.variable.updateValue(1234567, value=unicode(myFloat)) myList = ["one", 2, "three", 4] indigo.variable.updateValue(1234567, value=unicode(myList)) myDictionary = {"first":1, "second":"two", "third":3, "fourth":"four"} indigo.variable.updateValue(1234567, value=unicode(myDictionary))
import simplejson as json myList = ["one", 2, "three", 4] myDictionary = {"first":1, "second":"two", "third":3, "fourth":"four", "myList":myList} indigo.variable.updateValue(1234567, value=json.dumps(myDictionary)) # string will be something like: '{"second": "two", "myList": ["one", 2, "three", 4], "fourth": "four", "third": 3, "first": 1}' myNewDictionary = json.loads(indigo.variables[1234567].value) #myNewDictionary is now the same as myDictionary myNewDictionary["myList"] # results in: ['one', 2, 'three', 4]
Custom Python classes that you create can implement the __unicode__(self) method. Take this simple example:
class myCustomClass: def __init__(self): self.a=1 self.b=2 def __unicode__(self): outputString = u"a:%i, b:%i" % (self.a, self.b) return outputString
Date and Time Examples
Get the current server time:
indigo.server.getTime()
Action Group Examples
Log Examples
Log to the Indigo Event Log window all of the attributes/properties of the device "office desk lamp":
lamp = indigo.devices["office desk lamp"] indigo.server.log("{}: \n{}".format(lamp.name, str(lamp)))
Folder Examples
try: myFolder = indigo.triggers.folder.create("My Triggers") except ValueError, e: if e.message == "NameNotUniqueError": # a folder with that name already exists so just get it myFolder = indigo.triggers.folders["My Triggers"] else: # you'll probably want to do something else to make myFolder a valid folder myFolder = None
Miscellaneous Examples
Sending emails
# Simple Example indigo.server.sendEmailTo("emailaddress@company.com", subject="Subject Line Here", body="Some longish text for the body of the email") # Putting a variable's data into the subject and body theVar = indigo.variables[928734897] theSubject = "The value of %s" % (theVar.name) theBody = "The value of %s is now %s" % (theVar.name, theVar.value) indigo.server.sendEmailTo("emailaddress@company.com", subject=theSubject, body=theBody) # Putting device data into the subject and body theDevice = indigo.devices[980532604] theSubject = "Summary of %s" % (theDevice.name) theBody = "%s is %s\n%s is %s" % ("onState", str(theDevice.onState), "lastChanged", str(theDevice.lastChanged)) indigo.server.sendEmailTo("emailaddress@company.com", subject=theSubject, body=theBody)
/usr/local/indigo/indigo-host
Connecting Remotely over SSH
What Else Can it Do?
indigo-host -e ' indigo.device.toggle("office lamplinc") indigo.device.toggle("office lamplinc") indigo.device.toggle("office lamplinc") '
Executing Indigo Python Files
Executing AppleScript
So, you can create files of classes, functions, etc. you want to share between all Python scripts using these mechanisms. If you add/change something in that directory while the Indigo Server is running, you'll need to tell the server to reload - select the Plugins→Reload Libraries and Attachments
menu item and Indigo will restart the Python interpreter (which will cause your module to be reloaded).
""" indigo_attachments.py In this file you can insert any methods and classes that you define. They will be shared by all Python scripts - you can even import the IOM (as shown below) but if you do then you'll only be able to import this script in Python processes started by Indigo. If you don't need the IOM then skip the import and it'll work in any Python script no matter where it's run from. """ try: import indigo except ImportError: print "The indigo module can only be used by scripts started from within Indigo" raise ImportError from datetime import datetime def log(message, label=None): # Create a log line with the date/timestamp prepended in MM/DD/YYYY HH:MM:SS format log_line ="%s %s" % (datetime.today().strftime("%x %X"), message) # Write the log line with the label. If you didn't pass in a label # then the default label will be used. indigo.server.log(log_line, type=label)
import indigo_attachments indigo_attachments.log("Here's a special sort of log message", label="My Custom Label")
MyMac:testdir jay$ python2.7 testHandlerCall.py The indigo module can only be used by scripts started from within Indigo Traceback (most recent call last): File "testHandlerCall.py", line 3, in <module> import indigo_attachments File "/Users/USERNAME/Library/Python/2.7/site-packages/indigo_attachments.py", line 14, in <module> raise ImportError ImportError
Scripting Indigo Plugins
pluginDisplayName | The name displayed to users in the clients |
pluginId | The ID of the plugin (same as was passed to the getPlugin() method above) |
pluginSupportURL | The URL supplied by the plugin that points to it's user documentation |
pluginVersion | The version number specified by the plugin |
iTunes Toggle Play State
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): itunesPlugin.executeAction("playPause", deviceId=135305663)
iTunes Set Volume to 50
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): itunesPlugin.executeAction("setVolume", deviceId=135305663, props={'volume':50})
itunesId = "com.perceptiveautomation.indigoplugin.itunes" itunesPlugin = indigo.server.getPlugin(itunesId) if itunesPlugin.isEnabled(): myWeatherStation = indigo.devices[1798384204] outsideTemp = myWeatherStation.states['temperatureF'] currentCondition = myWeatherStation.states['currentCondition'] spokenString = "The current temperature is %s degrees. Current condition is %s." % (outsideTemp, currentCondition) itunesPlugin.executeAction("pauseAndSay", deviceId=135305663, props={'message':spokenString})
Restart a Plugin
