iTunes/Music Plugin for Indigo
Note: As of version 1.1.5 (Big Sur), you can no longer pair and control from a different Mac. This appears to be part of Apple's tightening of security as the Music app specifically returns an error that remote login capability is not supported.
This plugin is the basic iTunes/Music integration plugin. You may create as many “iTunes Server” devices as you have on your network (but only one per iTunes instance as defined by iTunes running on a Mac - you can't have multiple iTunes server devices that are pointing to the same iTunes instance). For each of those devices, you can trigger off of various state changes in the built-in Device State Changed trigger type and you can execute many different actions in the Actions tab. None of this requires scripting of any kind.
Plugin Config
This dialog tells you what to do next. You must pair this new device with the iTunes Server that you intend to control. Switch to iTunes.
If you're using the Music app (macOS Catalina 10.15.2 or above) that replaced iTunes, you'll see a line in the outline view on the left under Devices named “Indigo - [YOUR DATABASE NAME HERE]”. Select that item.
If you're using iTunes 12, you'll see a button with an right arrow in it in the upper left corner of the iTunes window:
If you're using iTunes 11, you'll see a button titled Remote in the upper right corner next to the iTunes Store button:
Select Indigo Remote Control
Device States
Actions
  • Play - start iTunes playing
  • Pause - pause iTunes
  • Pause iTunes and Say - pause iTunes (if it's running) and speak the supplied text. Restart only if it was paused to begin with.\\
Scripting Support
Action specific properties
Play
Action id: play
if itunesPlugin.isEnabled():
Pause
Action id: pause
Toggle Play/Pause
Action id: playPause
Next Track
Action id: nextTrack
Previous Track
Action id: prevTrack
Restart Track
Action id: restartTrack
Pause and Speak Text
Action id: pauseAndSay
Properties for scripting:
Set Volume
Action id: setVolume
Increase Volume
Action id: increaseVolume
Decrease Volume
Action id: decreaseVolume
Set Repeat
Action id: setRepeat
Set Shuffle
Action id: setShuffle
Support and Troubleshooting
indigo_7.5_documentation/plugins/itunes.txt · Last modified: 2021/06/14 16:25 by jay
