Deletion Dependencies
Dependency Sheet Image
If you double-click on the dependency, the edit dialog for that object will open so you can change/remove it. If you want the dependent objects to be deleted, just click the Delete button.
Dependency Window Image
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/deletion_dependencies.txt
