KeypadLinc Buttons
KeypadLinc buttons, and how you use them, is a pretty complex topic for a variety of reasons. One, while the buttons are directly addressable from Indigo on newer KeypadLincs, doing so is quite expensive in terms of Insteon traffic. So if you're doing a lot of button LED manipulation it's often better to do it in a more efficient manner (explained below).
Another complexity is how to keep buttons on multiple KPLs in sync when they are representing the same state. There are a variety of ways of doing this (again, see below for another option), but you can use Insteon links to link those buttons together so that when, say, button 4 is pressed on KPL#1, button 5 on KPL#2 lights up as well. You can link those buttons together via the KPL instructions, or you can use Indigo's remote link management feature to do the linking.
One thing to keep in mind about KPLs: they come in 6 and 8 button configurations. On an 8 button KPL, Indigo refers to the buttons like this:
Keypad Linc Eight Button Numbers Image
When you refer to a button on a 6 button KPL in Indigo, you refer to the buttons like this:
Keypad Linc Six Button Numbers Image
Note - the KPL will never send a button 2 or 8 in 6 button configuration.
There are two major tasks that you'll likely find yourself wanting to do: execute Indigo actions when a button is pressed and manage the state of a button (on/off) with Indigo.
OK, so, you just bought a KeypadLinc (KPL for short). And, you've got it wired up and controlling the load. Now, how the heck do you use those wonderful extra buttons? Having Indigo execute commands when a KeypadLinc button is pressed is quite simple (for example, looking for button 3):
  1. Select TRIGGERS from the outline view on the left
  2. Click the New… button
  3. Name the trigger whatever you want
  4. Select Insteon Command Received from the Type: popup
  5. Select the KeypadLinc in the popup list beside the Device radio button
  6. Select On from the popup labeled Received:
  7. Select Button/Group 3
  8. Click the Actions tab and add any actions you want to perform
That would execute whenever button 3 is pressed and turns ON. Create a similar trigger that fires when the button goes OFF to perform some other set of actions. If you don't want the button to toggle between ON and OFF (but rather just always perform the same action) then you can set the button's toggle mode (select Interfaces→INSTEON/X10 Power Line→Set KeypadLinc Button Toggle Mode…).
Managing the button states from Indigo is a more complex task, though not significantly so. First thing you're gonna want to do is carefully read INSTEON Button Basics. It's critical that you understand how INSTEON Groups/Scenes work before you continue.
Woohoo, you're now done with that. Head spinning? You might want to stew on that for a few minutes before you proceed. Grab a cup of tea. Achieve a nice Zen state.
So, let's walk through a couple of scenarios, each building on the last and each becoming more complex. These How-To's assume you've already defined the KPL in Indigo.
  1. Select DEVICES (or a subfolder) in the Outline View
  2. Select your KPL in the list
  3. Click the Edit… button
  4. In the Edit Device dialog, click on the Manage Links… button
  5. In the Manage INSTEON Device Links dialog, click New Link to Responder - in this situation, the KPL is the controller and your device will be the responder
  6. Select the button number on your controller you want to link the device to - on an 8 button KPL, the button numbering is obvious - start at the top left, then top right, then next row, etc. On a 6 button KPL, the large top button (load ON) is 1, the second row of 2 buttons is 3 and 4, next row 5 & 6, and the large bottom button (load off) is 7.
  7. Select the device you want to link the button to: many devices work but some don't (sprinklers, IRLincs, some IO devices). Those that do work, you may have some options: on lights, you can set the brightness and the ramp rate; on the thermostat, you can set mode and setpoints
  8. Click on the Sync Now button
OK, so, now, when you press the button on the KPL, it should control the device as you specified. Hold the button down to dim/brighten the light. Double tap the button to do an instant on/instant off. Pretty cool. And, if you watch the log, you'll notice that Indigo sees all this traffic. In fact, you can create trigger actions that do other things in conjunction with the KPL directly controlling the linked device. For instance, if you also want an X10 light to come on/go off, you can create trigger actions that look for an on/off from that button and issue the on/off X10 command to that light. Heck, you can even have the X10 device match the brightness of the other device (Pro only - requires writing some AppleScript).
Now, the KPL is directly controlling a device, and Indigo can see those button presses. On to the next scenario.
Before we jump in, let's discuss why one would want to have Indigo turn on/off a button on a KPL. There are several possible reasons:
  • You want the KPL button to represent the status of an X10 device
  • You want the KPL to represent the state of some external device or software state
  • You want to be able to flash it to impress your friends!
Anyway, now that you have some ideas. here's what you'll want to do if you want to control, say, button 3 on your KPL (Indigo 5 and later only):
  1. In the Actions tab of a Trigger, Schedule, Action Group, or Control page, select Control Light/Appliance
  2. Select Turn On Keypad Button in the Action menu
  3. Select your KPL from the Device popup
  4. Select Button 3 from the popup below the Device popup
This action will turn on the LED for that button. To turn it off instead, select Turn Off Keypad Button in the Action menu instead. If you see a warning that it won't work for your KPL (or you try it and it doesn't work), never fear. The next option will work.
If you're using Indigo 4 or greater (yes, it works equally well in Indigo 5+ and is in fact a bit faster), here's what you'll want to do:
  1. Select Manage PowerLinc Links from the Interface menu
  2. Select an unused group number from the PowerLinc Group/Scene popup, and give it a name (I use “KPL button 3” as my naming scheme)
  3. Select your KPL from the responder popup
  4. Select the controls 3rd button LED from the popup next to the responder popup
  5. Click the Sync Now button, and when that's done, click the Close (Sync Later) button
Great! Now, you can send the PowerLinc Group named “KPL button 3” an ON command to turn on the LED behind KPL's button 3 and OFF to turn it off. Repeat these steps with any button whose status you want to control via Indigo. NOTE: for the buttons that control the load (1 on an 8 button KPL or 1/2 & 7/8 on a 6 button KPL), you don't need to do that - you can simply send an ON/OFF to the KPL directly.
Now you have a couple of options for controlling the KPL from Indigo.
This scenario assumes you have already defined an iTunes Server device (provided by the iTunes plugin included with Indigo).
So, here's the scenario: you want to have a button on your KPL that toggles iTunes play/pause, and that stays in sync with the current state of iTunes regardless of how it was changed (paused at the computer, via Apple's Remote iPhone App, etc.) There are a bunch of different ways to do this, and it's pretty easy. The iTunes Server device has a state, so a couple of Variable Changed triggers should do the trick:
  1. Select TRIGGERS (or a subfolder) in the outline view
  2. Click New… to create a new trigger
  3. Name the trigger, and select Device State Changed from the Type popup
  4. Select your iTunes Server device from the Device popup
  5. Select Player Status is Playing
  6. Select the Becomes True radio button
  7. Select the Actions tab
  8. Select Send INSTEON Group / Scene Command from the Type popup
  9. Leave Group On selected from the Send popup
  10. Select the PowerLinc Group/Scene that you want to control (remember, from above, it's the group named “KPL button 3” - it's the one that represents the button on the KPL)
  11. Click OK
That trigger will now turn on the button's LED when your iTunes Server device starts playing. Now, create another, just like it, except trigger it on Becomes False and send Group Off. That should keep the buttons in sync with the actual state of iTunes.
Next is the easy part - making the button play/pause iTunes:
  3. Name the trigger “KPL - Play iTunes” (or whatever you want)
  5. Select On from the popup labeled Received:
  6. Select the KPL in the popup list beside the Device radio button
  7. Select the button/group you want to use (3 for this example)
  9. Select Execute Script from the Type popup
  10. Make sure the Embedded: radio button is checked
  11. Select Python from the popup
  12. Type the following script into the text area below Embedded: Python:
    if itunesPlugin.isEnabled():
    	itunesPlugin.executeAction("play", deviceId=1234567890) # use the device id of your iTunes device
  13. Click OK (You've just created the trigger that will start iTunes playing - now, let's create the trigger that will pause iTunes)
  14. Click the New… button again
  15. Name the trigger “KPL - Pause iTunes” (or whatever you want)
  16. Select Insteon Command Received from the Type: popup
  17. Select Off from the popup labeled Received:
  18. Select the KPL in the popup list beside the Device radio button
  19. Select the button/group you want to use (3 for this example)
  20. Click the Actions tab
  21. Select Execute Script from the Type popup
  22. Make sure the Embedded: radio button is checked
  23. Select Python from the popup
  24. Type the following script into the text area below Embedded: Python:
    	itunesPlugin.executeAction("pause", deviceId=1234567890) # use the device id of your iTunes device
  25. Click OK
That's it! Now, you have a button that controls iTunes Play/Pause, and always reflects the state of iTunes regardless of where it was last controlled from.
  • /www/perceptive/wiki/data/pages/inst_keypadlinc_buttons.txt
