iTunes Integration (Indigo versions 2-4)
There are many ways to integrate iTunes and Indigo Pro; this page will show you how to perform these integrations:
NOTE: If you are using Indigo 5, please use the iTunes plugin which is quite a bit easier.
Set up the iTunes sync script
Indigo comes with an iTunes Sync script which inserts a bunch of different data into Indigo Variables about what iTunes is doing. These can be shown on Control Pages, etc. This functionality is enabled by default in the sample house - check it out! If it's not already in your database, here's how (it's very simple)
- Select
TRIGGERSfrom the outline view on the left - Click the
New…button - Name the trigger whatever you want
- Select
Indigo Server Startupfrom theType:popup (this will cause the actions in this trigger to be executed each time the server starts up) - Click the
Actionstab - Select
Execute AppleScriptfrom theTypepopup - Select the
File:radio button - A standard Mac file dialog will appear: open
Background Tasksand selectiTunes sync.scpt - Click
OK
That's it. Next time you restart the server it will start up the iTunes sync script.
However, there are much more useful things that you can do to enable iTunes control from all over the house using various hardware controllers and Indigo Pro.
Setting up PalmPad (or other X10 controller) buttons to control iTunes
Difficulty: Simple
These instructions assume you're setting up a PalmPad remote, but the process would be much the same for any other X10 controller (SlimFire, Maxi controller, etc.)
Set up the Play/Pause button(s)
- Make a note of the X10 house code that your controller is using. The PalmPad has a dial on the lower end of the remote that points to the letter of the house code. Also note which unit codes the remote is going to send: it's either 1-8 or 9-16 on the PalmPad because it only has 8 sets of buttons. You can tell by the switch at the lower end of the remote under the buttons.
- In Indigo Pro, select
New…button - Name the trigger “Palm Pad - Play iTunes” (or whatever you want)
- Select
X10/RF Command Receivedfrom theType:popup - Select
Onfrom the popup labeledReceived: - Click the
Addressradio button - Select the appropriate house code (as noted in step 1) and set the unit code (the number) to whichever button you want to use to start iTunes playing. (Make sure it isn't overlapping with a real X10 device, like a light, or the button will start iTunes playing AND turn on the light!)
- Click the
Actionstab - Select
Execute AppleScriptfrom theTypepopup - Make sure the
Embedded:radio button is checked - Type the following script into the text area below
Embedded::iTunesPlay()
- Click
OK(You've just created the trigger that will start iTunes playing - now, let's create the trigger that will pause iTunes) - Click the
New…button again - Name the trigger “Palm Pad - Pause iTunes” (or whatever you want)
- Select
Offfrom the popup labeledReceived: - Click the
Addressradio button - Set the house code (the letter) and unit code (the number) to the same values as step 8 above
- Click the
Actionstab - Select
Embedded::iTunesPause()
- Click
OK
That should do it for Play and Pause. When you press the right “On” button on the Palm Pad, iTunes should start playing and it should pause when you press the corresponding “Off” button. NOTE: iTunes should be in a playable state: in other words, a valid playlist should be selected OR the Music Library. At the moment, the iTunes Attachment script (which you use by calling iTunesPlay()) isn't smart enough to first check to see if there is a playable playlist selected.
Set up the Volume Up/Volume Down button(s)
New…button - Name the trigger “Palm Pad - iTunes Volume Up” (or whatever you want)
- Select
Addressradio button - Select the appropriate house code (as noted in step 1) and set the unit code (the number) to whichever button you want to use to start iTunes playing. Make sure it isn't the same you used for Play and Pause above - it's not gonna work as you might expect!
- Click the
Actionstab - Select
Embedded::iTunesVolumeUp(5)
- Click
OK(You've just created the trigger that will increase iTunes volume by 5% each time that button is pressed) - Click the
- Select
- Click the
Actionstab - Select
Embedded::iTunesVolumeDown(5)
- Click
OK
Now, when you press the right “On” button on the Palm Pad, iTunes will increase the volume by 5% and the corresponding “Off” button will decrease the volume by 5%.
See, that wasn't hard at all! Next, we'll discuss getting it to work with an Insteon ControlLinc. It's really not much different.
Setting up Insteon ControLinc buttons to control iTunes
Difficulty: Simple
The process isn't very different from the PalmPad, but here's the whole thing.
- Make a note of which buttons you plan on using on the ControLinc. There are 5 button groups (On and Off).
New…button - Name the trigger “ControLinc - Play iTunes” (or whatever you want)
- Select
Insteon Command Receivedfrom theType:popup - Select
Deviceradio button - Select the ControLinc in the popup list
- Select the button/group you want to use (as identified in step 1)
- Click the
Actionstab - Select
- Click
New…button again - Name the trigger “ControLinc - Pause iTunes” (or whatever you want)
- Select
- Click the
Actionstab - Select
- Click
OK
That should do it for Play and Pause. When you press the right “On” button on the ControLinc, iTunes should start playing and it should pause when you press the corresponding “Off” button. NOTE: iTunes should be in a playable state: in other words, a valid playlist should be selected OR the Music Library. At the moment, the iTunes Attachment script (which you use by calling iTunesPlay()) isn't smart enough to first check to see if there is a playable playlist selected.
- Select
- Click the
Actionstab - Select
- Click
- Select
- Click the
Actionstab - Select
- Click
OK
Now, when you press the right “On” button on the ControLinc, iTunes will increase the volume by 5% and the corresponding “Off” button will decrease the volume by 5%.
See, that wasn't hard either! Next, we'll discuss getting it to work with an Insteon KeypadLinc.
Setting up KeypadLinc buttons to control iTunes
KeypadLinc buttons operate inherently differently from other controllers: the buttons, by default, are toggle buttons - which means that they are either on or off as indicated by whether it's lit up or not. We've created a separate How-To that explains how to control those buttons, and specifically how to keep one in sync with the iTunes play state. Read it!
