INSTEON Commands
This plugin is a collection of miscellaneous INSTEON commands that aren't yet available natively in the UI (and may never be). There are several reasons for adding some INSTEON commands as actions via this plugin: it's sometimes desirable to be able to perform these actions more frequently than just once during setup (so it's in addition to the native UI) and it's often faster than adding it into the native UI. In any event, here are the actions available:
Set LED Brightness
This action will set the brightness of the LEDs on certain devices. Newer KeypadLincs are supported as well as some SwitchLinc models. Unfortunately, there isn't really a way to tell you which devices are supported so you'll just have to try it and see if it works.
Available in v1.0.0.
Available in v1.0.1.
Set Motion Sensor Timeout
Set I/O Linc Momentary Mode
Configure SynchroLinc
Send Raw INSTEON Command
As of v1.0.2 all the above actions can be run interactively from the plugin's menu so you don't need to create a separate Action Group to run them.
We'll add other functionality here where it makes sense. Drop us an email if you have an idea.
Scripting Support
Plugin ID: com.perceptiveautomation.indigoplugin.InsteonCommands
Action specific properties
Set LED Brightness
Action id: setLedBrightness
Properties for scripting:
device | required | the ID of the target device |
brightness | optional | desired brightness of the device from 1-100 (100 is default) |
brightenMethod | optional | method to use to try the command, one of “kpl” (default) or “swl” |
acId = "com.perceptiveautomation.indigoplugin.InsteonCommands"
actionPlugin = indigo.server.getPlugin(acId)
if actionPlugin.isEnabled():
actionPlugin.executeAction("setLedBrightness", props={'device':'1435361545','brightness':'1', 'brightenMethod':'kpl'})
Action id: setKPLLeds
keypadlinc | required | the ID of the target keypadlinc |
button2 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
button3 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
button4 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
button5 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
button6 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
button7 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
button8 | optional | one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone” |
actionPlugin.executeAction("setKPLLeds", props={'keypadlinc':'1435361545','button4':'leaveAlone'})
Action id: setAutoOffButtonGroup
controlButton | required | the control button (the one that turns off the others) - value from 1-8 |
button2 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
button3 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
button4 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
button5 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
button6 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
button7 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
button8 | optional | True if you want a press on the controlButton to turn off, False (default) otherwise |
# Here we set button 3 so that it turns off buttons 4, 5, and 6
actionPlugin.executeAction("setAutoOffButtonGroup", props={'keypadlinc':'1435361545','controlButton':'3', "button4":True, "button5":True, "button6":True})
Action id: setKPLToggleMode
button1toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button1onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button2toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button2onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button3toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button3onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button4toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button4onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button5toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button5onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button6toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button6onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button7toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button7onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
button8toggle | optional | True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior) |
button8onMode | optional | True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode) |
# Here we set button 3 so that it always sends an OFF command
actionPlugin.executeAction("setKPLToggleMode", props={'keypadlinc':'1435361545', "button3toggle":True, "button3onMode":False})
Action id: setMotionSensorLedBrightness
device | required | the ID of the target motion sensor |
brightness | optional | desired brightness of the motion sensor from 0-255 (100 is default) |
actionPlugin.executeAction("setMotionSensorLedBrightness", props={'device':'554249383','brightness':'0'})
Action id: setMotionSensorTimeout
timeout | optional | desired timeout of the motion sensor from 0-255 (1 is default) |
actionPlugin.executeAction("setMotionSensorTimeout", props={'device':'554249383','timeout':'5'})
Action id: setMotionSensorSensitivity
sensitivity | optional | desired sensitivity of the motion sensor from 0-255 (128 is default) |
actionPlugin.executeAction("setMotionSensorSensitivity", props={'device':'554249383','sensitivity':'200'})
Action id: setIOLincMomentaryMode
iolinc | required | the ID of the target device |
momentaryMode | optional | the mode, one of “A”, “B”, “C”, and “None” - see the I/O Linc docs for details |
actionPlugin.executeAction("setIOLincMomentaryMode", props={'iolinc':'1053088701','momentaryMode':'A'})
Action id: configureSynchroLinc
synchrolinc | required | the ID of the target device |
triggerWatts | optional | (0 to 1800 watts in 0.5 watt steps): the wattage needed before the SynchroLinc broadcasts (will retain existing setting if not included) |
thresholdWatts | optional | (aka hysteresis, 0 to 127.5 watts in 0.5 watt steps): tolerance before on/off toggle is sent (will retain existing setting if not included) |
delaySeconds | optional | (0.15 to 38.25 seconds): prevents message flooding if thresholdWatts is too low (will retain existing setting if not included) |
actionPlugin.executeAction("configureSynchroLinc", props={'synchrolinc':'662726927','triggerWatts':'14.5','thresholdWatts':'4.0','delaySeconds':'4.50'})
Use the indigo.insteon.sendRaw() and indigo.insteon.sendRawExtended() commands. add links when those methods get documented
