in this location:
and Plugins (Disabled)
folder.
PluginVersion
- this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.ServerApiVersion
- this is the version of the server plugin API as defined by us. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.CFBundleDisplayName
) - this is a standard macOS key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.CFBundleName
) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.CFBundleIdentifier
) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.yourorgidentifier.*
) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us. This key is required.CFBundleURLTypes
) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's Github repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.We want the user experience to be very similar for plugins, at least until it comes to configuration and use of the plugin, so you should be careful to get the Info.plist correct.
file in here, it will be displayed in the Plugin Store once you submit the plugin (see Plugin Store below for more details). Note that the code that loads config UI XML templates assumes that the Server Plugin
folder is the root, so those template files should always be in the Server Plugin
tree (i.e., Server Plugin/Templates/my_template.xml
Folder | Authentication | Description |
, Action
, Device
, type
, defaultValue
id
's can contain letters, numbers, and other ASCII charactersid
's cannot start with a number or punctuation characterid
's cannot start with the letters xml (or XML, or Xml, etc)id
's cannot contain spaces
, Events
, Actions
, and the PluginConfig
file.
attribute is required for every field and must be unique within the dialog - it’s used to establish enabled and visible bindings between fields and more importantly it’s the key used in the dictionary to get the values when you get messages from the dialog (discussed more later). The id
must be alphanumeric (and may contain underscores) and must begin with an alphabetic character.
attribute. The value
element and a List
elements. Each Option
element must have a value
As with menu
Dynamic List Attributes | ||
Attribute | Required | Notes |
class | Yes | A reference to a class value as described below. The class attribute must be set to one or more of the built-in classes (listed below), or self . |
filter | No | A filter attribute is not required, but if one is included, it must be set to a valid filter (see below) or empty filter=“” . |
The indigo.devices
class specifies that the list will contain Indigo devices. If you don’t specify a filter, all devices defined by the user in Indigo will be returned. You can supply two filters if and only if one is an interface filter (see the first three in the list below). The filters are ANDed together, so one interface filter and one device type filter are the only combinations that will result in a non-empty list.
Class: indigo.devices |
The indigo.triggers
Class: indigo.triggers |
Using the indigo.schedules
and indigo.controlPages
The valuesDict
The typeId
, Network Socket
, or Network RFC-2217
Aside from the standard Label
The process flow is this:
<CallbackMethod>
element.
XML for a device like this:
method.
False
, Events
, and Actions
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/
in the Info.plist
You can also implement your own custom configuration in HTML if you prefer. Rather than adding lots of <Field>
definitions, you simply specify a <URL>
element. The URL specified can either be a fully specified URL (protocol://host/path) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example.
type | Attribute | Yes | This must be one of: dimmer , relay , sensor , speedcontrol , thermostat , or custom . We’ll discuss each below. |
subType | Attribute | No | This must be one of: kDimmerDeviceSubType , kRelayDeviceSubType , kSensorDeviceSubType . We’ll discuss each below. There are also several device SubType examples in the Indigo SDK. |
allowUserCreation | Attribute | No | If set, the value must either be true or false (defaults to true ). This attribute is discussed in more detail below. |
ConfigUI | Element | No | This is the custom UI for configuring the device. It’s optional, but in reality we can’t envision a device that needs no configuration. If the optional <ConfigUi> element is not used, the “Edit Device Settings…” button will be displayed, but disabled. |
<?xml version="1.0"?> <Device type="sensor" id="my_temp_sensor"> <Name>Example Temperature Sensor Module</Name> <ConfigUI> <Field id="address" type="textfield" defaultValue="123"> <Label>Module Address:</Label> </Field> </ConfigUI> <States> <State id="temperature"> <ValueType>Integer</ValueType> <TriggerLabel>Temperature</TriggerLabel> <ControlPageLabel>Temperature</ControlPageLabel> </State> </States> </Device>
Name | SubType | Attribute(s) | Notes |
Device | kDeviceSubType | Amplifier, Automobile, Camera, Keypad, Mobile, Remote, Robot, Security, Speaker, Streaming, Television, Weather, Other | For example, indigo.kDeviceSubType.Amplifier |
Dimmer | kDimmerDeviceSubType | Blind, Bulb, ColorBulb, ColorDimmer, Dimmer, Fan, InLine, Outlet, Plugin, Value | For example, indigo.kDimmerDeviceSubType.Dimmer |
Relay | kRelayDeviceSubType | DoorBell, DoorController, GarageController, InLine, Lock, Outlet, Plugin, Siren, Switch | For example, indigo.kRelayDeviceSubType.Switch |
Sensor | kSensorDeviceSubType | Analog, Binary, CO, DoorWindow, GasLeak, GlassBreak, Humidity, Illuminance, Motion, Presence, Pressure, Smoke, Tamper, Temperature, UV, Vibration, Voltage, WaterLeak, Zone | For example, indigo.kSensorDeviceSubType.Temperature |
* There are no device sub-types for other built-in devices at this time.
In Devices.xml
<Device type="sensor" subType="kSensorDeviceSubType.Temperature" id="my_temp_sensor"> <Device type="sensor" subType="kSensorDeviceSubType.Temperature, ui=Outdoor Temperature" id="my_temp_sensor" <Name>Example Adjustable Sensor Module</Name> ...
In Python:
When the allowUserCreation
attribute is present and set to false
, Indigo will not display the device model type when the user elects to create a new device (the “Model” dropdown will not contain the device type). This is especially useful for complex devices that have multiple sub-types that are set programmatically (but not created using the Device Factory approach). Your plugin may not support individual sub-types as stand-alone devices and, therefore, you wouldn't want users to be able to create them. The allowUserCreation
attribute was introduced with Indigo version 2022.1.2
and API 3.1
IMPORTANT: Plugin developers should account for each devices' callbacks when implementing built-in device types – even if you don't use all the callbacks within your plugin. For example, if your plugin implements theSpeed Control
device type, your plugin should include handlers for all the Speed Control callbacks – such asturnOn
,turnOff
, ortoggle
. This is very important because these callbacks will still be exposed in the Indigo Client UI for things like Actions and Triggers. It's best to give users an indication that the callback won't do anything in your plugin by writing a warning to the Event log. Consult the SDK for more information on each device types' callbacks and examples of how to handle them.
The custom
, String
, List
(enumeration), Boolean
defined in the <Device>
As you can see, your <Event>
element as well - the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Event to be a separator in your event list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements:
<Event id="sep1"/>
elements:
As with <Event>
, your <Action>
element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all actions will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Action defined like this between two other Action elements:
<Action id="sep1"/>
elements:
deviceFilter | Attribute | No | If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod . This will avoid the necessity to create a ConfigUI element with just a device popup. |
%%v:12345%%
into their string where 12345
%%d:12345:someStateId%%
You can also implement your own custom menu item form in HTML if you prefer. Rather than adding <CallbackMethod>
and <ConfigUI>
Anywhere you can specify a <SupportURL>
element, the value can be either a full URL or a relative URL. If it's relative, then Indigo will attempt to guess the best base URL. You can use this to supply static HTML files or dynamic help provided through the HTTP processing API discussed below.
You'll most likely use the |
Note: |
You must call |
Device Specific Methods | ||
Trigger Specific Methods | ||
add schedule documentation when it is complete (not currently available) | ||
Name | Required | Notes |
add action group documentation when it is complete (not currently available) | ||
and <Actions>
Property | Value Type | Notes |
, errorLog()
, and exceptionLog()
. These were shortcuts which showed varying levels of log information in the Indigo Event Log window. In API 2.0, we've deprecated those methods in favor of the standard Python logging module (don't worry, the previous APIs will continue to work).
Attribute | Description |
The Python logger module is extremely powerful and flexible, and we recommend reading through the docs for a good understanding of how it works and how you can add great logging to your plugin. We'll describe the minimum here that you need to know to do basic logging to the Indigo Event Log window and to your plugin's log file. The logger module defines 5 levels of logging shown below. Instances of the Logger object can be set to log messages at any of those 5 levels, and the level logged can be changed at any time. By default, the self.logger
The debugLog()
, errorLog()
and self.plugin_file_handler
, self.logger.info
The self.indigo_log_handler
is an instance of a custom Handler object that will write (or emit in Python Handler speak) your log messages into the Indigo Event Log. We haven't yet updated the Indigo event handling to deal with 5 levels of log messages, so each the message type (the left part in the Event Log) is modified so that it reflects the level. Here's an example of each:
For convenience, the various log levels are represented in color in the Indigo Event Log.
In a future release, we hope to change the server's internal logging to use these same 5 log levels. When we do so, you won't have to do anything - we'll just update the self.indigo_log_handler
instance to emit the appropriate messages to the server.
The self.plugin_file_handler
. Does this mean that all debug or better messages are automatically sent to both the file and the Indigo Event Log? Actually, no. The reason is because you can also specify at the handler what level to actually log. We default the plugin_file_handler
to logger.DEBUG
but we default the indigo_log_handler
to logger.INFO
set to True
to logger.DEBUG
. And if it's False
, we set it to logger.INFO
class MyClass(object): def __init__(): self.logger = logging.getLogger("Plugin") self.logger.debug("MyClass Object")
and use it directly, or you can pass your logger into the methods of the submodule. You could also pass in the event log handler defined for you by the plugin base (self.indigo_log_handler
), and then attach that to a custom logger in your module.
If you use the instance of self.indigo_log_handler
, the message emitted to the Event Log window will have a type that is the name of the plugin.
If you want log lines with titles other than the plugin name (like a name specific to the submodule), you can instantiate an instance of the IndigoLogHandler
class (which is what self.indigo_log_handler
is) instead:
custom_logger = logging.getLogger("MyModule") custom_handler = self.IndigoLogHandler("MyModule", logging.DEBUG) custom_logger.addHandler(custom_handler)
And anything logged to your plugin_logger
will be reflected in the Event Log:
With the logging message self.logger.critical(“Something bad happened.”)
you will see the following in the log:
which doesn't provide any detail on what actually went wrong. Fortunately, the logging method provides a way to pass more information about the error to the logger with exc_info
; such as self.logger.critical(“Something bad happened.”, exc_info=True)
which yields:
My Plugin Error Something bad happened. Traceback (most recent call last): File "plugin.py", line 123, in runConcurrentThread x = 1 / 0 ZeroDivisionError: division by zero My Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
import logging def __init__(self): # Get the current logging level from pluginPrefs self.debugLevel = int(self.pluginPrefs.get('showDebugLevel', "30")) # Set preferred log format specifier log_format = '%(asctime)s.%(msecs)03d\t%(levelname)-10s\t%(name)s.%(funcName)-28s %(message)s' self.plugin_file_handler.setFormatter( logging.Formatter(fmt=log_format, datefmt='%Y-%m-%d %H:%M:%S') ) self.indigo_log_handler.setLevel(self.debugLevel) def runConcurrentThread(self): self.logger.debug("Starting concurrent thread.") try: x = 1 / 0 except ZeroDivisionError: self.logger.critical("Something bad happened.", exc_info=True)
Which yields:
Logging from linked and embedded scripts is very straight-forward. You can simply set the level you want by accessing the logging.*
level you want:
import logging indigo.server.log("debug message", level=logging.DEBUG) indigo.server.log("info message", level=logging.INFO) indigo.server.log("warning message", level=logging.WARNING) indigo.server.log("error message", level=logging.ERROR) indigo.server.log("critical message", level=logging.CRITICAL)
?other=args&api_key=KEYHERE
)As a reminder, here's how you specify an action in Actions.xml that is used only via an API (from another plugin such as the IWS plugin):
<Action id="handle_message" uiPath="hidden"> <Name>some message</Name> <CallbackMethod>handle_some_action</CallbackMethod> </Action>
def handle_some_action(self, action, dev=None, callerWaitingForResult=None): some_value = action.props["somekey"] return some_value
Calls via this method will always pass in callerWaitingForResult=True
. You will want to make sure that your plugin returns as quickly as possible - any long-running processes should be put into another thread with some sort of asynchronous message back to the caller if necessary.
IWS will insert several things into the action.props
dictionary:
Key | Value |
file_path | this will be a list of path parts from the URL after the action ID. So for the url: http://host/message/pluginid/actionid/path/to/some/file.txt the value will be an indigo.List with the following items: ["path", "to", "some", "file.txt"] |
Key | Value |
You can also pass back an indigo.Dict
instance that will instruct IWS to stream a file from the filesystem back to the requester. This is the structure:
{ "status": 310, # Internal status code indicating that IWS should stream back the specified file. "file_path": path, # this is a full path specifier "headers": indigo.Dict({"Content-Type": content_type} # you should add a Content-Type header )
We've provided a utility method that will validate that the file specified exists and then will pass back the appropriate indigo.Dict
instance.
Status | Meaning |
For 50x
errors, a JSON dictionary will be returned describing the issue:
Key | Value |
error | One of: plugin_disabled , invalid_plugin , invalid_action , unknown_error |
