Timers and Pesters (Indigo 6)
Timers
Create a Timer
  1. Select DEVICES (or one of it's subfolders) from the Outline View
  2. Click on the New… button
  6. Click Save
Use a Timer
Timer Actions
  • Set Timer Start Value - use this action to set the default timer value without actually starting the timer. If the timer is running when it has it's start value changed, it will stop running.
Timer Event
  1. Select TRIGGERS (or one of it's subfolders) from the Outline View
  6. Click Save
Timer Uses
So, what else would you do with the timer aside from triggering off of it's expiration? You can display the various states on a control page and use those states in triggers and conditions as well. You could also show the countdown on a control page if that information is useful. You could even have an audio countdown by speaking the time left on the timer.
Pesters
Another very useful feature of this plugin is the “Create Pester” action. This action will create a little mini timer which will repeat a specified number of times, executing an action group each time through and will execute an optional action group at the end of it's final occurrence. So - say you want to have your computer announce that it's time to take out the trash. However, if you're like me, once is never enough - I need to be nagged about it several times. Create a pester that repeats every 30 seconds for 5 times (so it doesn't go forever) that executes an action group that tells you to take out the trash. The final time can send an SMS to your phone.
Scripting Support
Action specific properties
Start Timer
Action id: startTimer
if timerPlugin.isEnabled():
Pause Timer
Action id: pauseTimer
Restart Timer
Action id: restartTimer
Resume Timer
Action id: resumeTimer
Stop Timer
Action id: stopTimer
Action id: setTimerStartValue
Properties for scripting:
Support and Troubleshooting
indigo_7_documentation/plugins/timersandpesters.txt · Last modified: 2016/06/21 22:35 (external edit)
