About this Reference
# some code here
# that does something
Term Meaning
Introduction
For Scripters and Developers:
For Developers:
  • To change a device's state on the server, use myDevice.updateStateOnServer(key="keyName", value="Value")
Class Command namespace Notes
Device (indigo.Device) indigo.device.* for commands and properties that apply to all device subclasses
DimmerDevice (indigo.DimmerDevice) indigo.dimmer.* manipulate a dimmer
InputOutputDevice (indigo.MultiIODevice) indigo.iodevice.* manipulate an I/O device
SensorDevice (indigo.SensorDevice) indigo.sensor.* manipulate a sensor (motion, etc)
RelayDevice (indigo.RelayDevice) indigo.relay.* manipulate a relay, lock, or other 2 state device
SpeedControlDevice (indigo.SpeedControlDevice) indigo.speedcontrol.* manipulate a speed control/motor device
SprinklerDevice (indigo.SprinklerDevice) indigo.sprinkler.* manipulate a sprinkler device
ThermostatDevice (indigo.ThermostatDevice) indigo.thermostat.* manipulate a thermostat
Schedule
Schedule (indigo.Schedule) indigo.schedule.* manipulate a scheduled event FIXME not yet implemented
Triggers
Trigger (indigo.Trigger) indigo.trigger.* commands and properties that apply to all trigger subclasses
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger indigo.devStateChange.* manipulate a device state change trigger
EmailReceivedTrigger (indigo.EmailReceivedTrigger) indigo.emailRcvd.* manipulate an email received trigger
Trigger Class (indigo.InsteonCommandReceivedTrigger) indigo.insteonCmdRcvd.* manipulate an INSTEON command received trigger
InterfaceFailureTrigger (indigo.InterfaceFailureTrigger) indigo.interfaceFail.* manipulate an interface failure trigger
InterfaceInitializedTrigger (indigo.InterfaceInitializedTrigger) indigo.interfaceInit.* manipulate an interface initialized trigger
PluginEventTrigger (indigo.PluginEventTrigger) indigo.pluginEvent.* manipulate an trigger defined by a plugin event
PowerFailureTrigger (indigo.PowerFailureTrigger) indigo.powerFail.* manipulate a power failure trigger
ServerStartupTrigger (indigo.ServerStartupTrigger) indigo.serverStartup.* manipulate a server startup trigger
X10CommandReceivedTrigger (indigo.X10CommandReceivedTrigger) indigo.x10CmdRcvd.* manipulate an X10 command received trigger
VariableValueChangeTrigger (indigo.VariableValueChangeTrigger) indigo.varValueChange.* manipulate a variable changed trigger
ActionGroup (indigo.ActionGroup) indigo.actionGroup.* commands for action groups
Variables
Variable (indigo.Variable) indigo.variable.* manipulate a variable
Protocol Specific Commands
Insteon Specific Commands indigo.insteon.* commands specific to the INSTEON protocol
X10 Specific Commands indigo.x10.* commands specific to the X10 protocol
General Commands
Commonly used commands and server properties indigo.server.* for commands and properties that are more general in nature
IOM Class Hierarchy
IOM Object Hierarchy Image
Indigo specific data types
  • always retrieve values (ex: myprops["key"] or mylist[2]) as a copy and not reference of the object.
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
a['c'] = c          # a COPY of list C above is inserted (not a reference)
print(str(a))
c.append(6)
print(str(a))           # no change from previous output!
a['c'].append(6)
a['c'] = c
print(str(a))           # now has a COPY of the updated object, c
print(str(a))
Built-in objects
Object Description
indigo.devices All devices in the database
indigo.triggers A ll triggers in the database
indigo.schedules All schedules in the database
indigo.actionGroups All action groups in the database
indigo.variables All variables in the database
  2. They contain a "folders" attribute that has all the folders defined for that object type
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming() and subscribeToOutgoing() methods in the indigo.insteon and indigo.x10 command spaces to see commands regardless of their effect on device state.
Iterating Object Lists
for dev in indigo.devices:
    # do stuff with dev here
Triggers also have filters:
Filter Description
indigo.insteonCmdRcvd insteon command received triggers
indigo.powerFail power failure triggers
indigo.pluginEvent plugin defined triggers
self include triggers defined by the calling plugin
self.myTriggerType include myTriggerType's triggers defined by the calling plugin
com.company.plugin.xyzTriggerType include all xyzTriggerType's defined by another plugin
for var in indigo.variables:
    # all variables
Common Python Exceptions
Possible Exceptions
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
