Triggers
Trigger Base Class
| Property | Type | Writable | Description | |
actions |
list of Action | Yes | a list of Action objects (action steps in AS) that are executed for this trigger Not yet implemented | |
description |
string | Yes | description of the trigger | |
enabled |
boolean | Yes | true if this trigger is enabled | |
folderId |
integer | No | unique ID of the folder this trigger is in | |
globalProps |
dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
id |
integer | No | a unique id of the trigger, assigned on creation by IndigoServer | |
name |
string | Yes | the unique name of the trigger - no two triggers can have the same name | |
pluginProps |
dictionary | No | an indigo.Dict() representing the name/value pairs defined by your plugin for the trigger - plugin developers should publish this information if you want other plugins/scripts to create triggers of this type - see About Plugin Properties below for details |
suppressLogging |
boolean | Yes | true if execution of this trigger will not be logged into the event log | |
upload |
boolean | Yes | true if IndigoServer should attempt to upload this trigger to the interface - will always be false for plugin triggers |
trigger=indigo.triggers[123]
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
*duplicateName* |
No | string | name for the newly duplicated trigger |
Enable/Disable Trigger
| Parameters | |||
*value* |
Yes | boolean | True to enable, False to disable |
*delay* |
No | integer | number of seconds to delay before disabling or enabling the trigger |
*duration* |
No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
| Parameters | |||
*ignoreConditions* |
No | boolean | will ignore any conditions associated with the trigger if True (default) and will evaluate conditions if False |
| Parameters | |||
*value* |
Yes | integer | id or instance of the folder to move the trigger to |
| Parameters | |||
DeviceStateChangeTrigger
deviceId |
integer | Yes | the unique device id | |
stateChangeType |
kStateChange | Yes | the type of state change | |
stateSelector |
kStateSelector | Yes | can use either a string or one of the enumerations listed in the state selector enumeration | |
stateSelectorIndex |
integer | Yes | a 0-based integer value to specify which of multiple options to monitor - see the About State Selector section below for more information | |
stateValue |
string | Yes | the value the current state should be compared against - will be converted to the right type by the server |
State Change Type Enumeration
| indigo.kStateChange | ||
BecomesEqual |
*stateSelector* becomes equal to *stateValue* |
*ActiveZone* \ AnalogInput \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput |
BecomesFalse |
*stateSelector* becomes *False* |
*BinaryInput* \ BinaryOutput \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ Zone |
BecomesGreaterThan |
*stateSelector* becomes greater than *stateValue* |
*AnalogInput* \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput |
BecomesLessThan |
*stateSelector* becomes less than *stateValue* |
BecomesNotEqual |
*stateSelector* becomes not equal to *stateValue* |
BecomesTrue |
*stateSelector* becomes True |
Changes |
*stateSelector* has any change |
*ActiveZone* \ AnalogInput \ AnalogInputsAll \ BinaryInput \ BinaryInputsAll \ BinaryOutput \ BinaryOutputsAll \ BrightnessLevel \ HumidityInput \ HumidityInputsAll \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanMode \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ SensorInput \ SensorInputsAll \ SetpointCool \ SetpointHeat \ TemperatureInput \ TemperatureInputsAll \ Zone |
State Selector Enumeration
| indigo.kStateSelector | |
ActiveZone |
monitor the sprinkler’s activeZone to become =, !=, or any change |
AnalogInput |
monitor (one of) the analog input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs |
AnalogInputsAll |
monitors all of the analog inputs available on the device for any change |
BinaryInput |
monitor (one of) the binary input(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available inputs |
BinaryInputsAll |
monitors all of the binary inputs available on the device for any change |
BinaryOutput |
monitor (one of) the binary output(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available outputs |
BinaryOutputsAll |
*BrightnessLevel* |
monitor the brightness level of a device for =, !=, <, >, and any change |
HumidityInput |
monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
HumidityInputsAll |
monitors all of the humidity sensors available on the device for any change |
HvacCoolerIsOn |
monitor the thermostat for any time the air conditioning turns on, off, or has any change (coolIsOn is the current compressor state) |
HvacFanIsOn |
monitor the thermostat for any time the fan turns on, off, or has any change (fanIsOn is the current fan state) |
HvacFanMode |
monitor the fanMode of the thermostat for any change |
HvacFanModeIsAlwaysOn |
monitor the fanMode of the thermostat for a change to/from kFanMode.AlwaysOn |
HvacFanModeIsAuto |
monitor the fanMode of the thermostat for a change to/from kFanMode.AutoOn |
HvacHeaterIsOn |
monitor the thermostat for any time the heater turns on, off, or has any change (heatIsOn is the current heater state) |
HvacOperationMode |
monitor the hvacMode of the thermostat for any change |
HvacOperationModeIsAuto |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatCoolOn |
HvacOperationModeIsCool |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.CoolOn |
HvacOperationModeIsHeat |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatOn |
HvacOperationModeIsOff |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.Off |
HvacOperationModeIsProgramAuto |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramAuto |
HvacOperationModeIsProgramCool |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramCool |
HvacOperationModeIsProgramHeat |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramHeat |
KeypadButtonLed |
FIXME |
OnOffState |
monitor the device for a change to/from on/off |
SensorInput |
monitor (one of) the sensor input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs |
SensorInputsAll |
monitors all of the sensor inputs available on the device for any change |
SetpointCool |
monitor the cool setpoint of the thermostat for =, !=, <, >, or any change |
SetpointHeat |
monitor the heat setpoint of the thermostat for =, !=, <, >, or any change |
TemperatureInput |
monitor (one of) the temperature sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
TemperatureInputsAll |
monitors all of the temperature sensors available on the device for any change |
Zone |
| python
folder=1234) |
| Parameters | |||
*description* |
No | string | the description of the trigger |
name |
Yes | string | the name of the trigger |
*folder* |
No | integer | id or instance of the folder in which to put the newly created trigger |
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
EmailReceivedTrigger
Property |
Writable | Type | Description | |
emailFilter |
kEmailFilter | Yes | the type of email filter based on the *kEmailFilter* enumeration below |
emailFrom |
string | Yes | if *emailFilter* is *MatchEmailFields*, the value to match against the sender’s address |
emailSubject |
string | Yes | if *emailFilter* is *MatchEmailFields*, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
AnyEmail |
when any email is received |
MatchEmailFields |
when email subject/from fields match |
Commands (indigo.emailRcvd.*)
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
InsteonCommandReceivedTrigger
deviceId |
integer | Yes | the unique device id - only used if commandSourceType is DeviceId |
command |
kInsteonCmd | Yes | the command to watch for | |
commandSourceType |
kDeviceSourceType | Yes | the source type - for INSTEON only DeviceId and AnyDevice apply - and deviceId above will only be used if set to DeviceId |
buttonOrGroup |
integer | Yes | the button or group number from which the command is received - see About Button or Group Numbers below for details |
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
AllBrighten |
when an all brighten command begins |
AllDim |
when an all dim command begins |
AllInstantOff |
when an all instant (fast) off is received |
AllInstantOn |
when an all instant (fast) on is received |
AllOff |
when an all off is received |
AllOn |
when an all on is received |
AnyCommand |
when any command is received |
Brighten |
when a brighten command begins |
Dim |
when a dim command begins |
InstantOff |
when an Instant (Fast) off is received in response to a double-tap |
InstantOn |
when an Instant (Fast) on is received in response to a double-tap |
Off |
when an off command is received |
On |
when an on command is received |
StatusChanged |
when a status change broadcast is received |
*NoDevice* |
when the source uses no device or address (only used for X10 RF A/V remotes) |
Device |
when the source is an existing device, the ID is specified |
Address |
when the source is a raw X10 address |
AnyAddress |
when the source is any X10 address or INSTEON device |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
theTrigger.buttonOrGroup = 1
InterfaceFailureTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
InterfaceInitializedTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
PluginEventTrigger
pluginId |
string | the unique ID of the plugin, specified in the Info.plist for the plugin (or it’s documentation) |
pluginTypeId |
string | the id specified in the Events.xml (or it’s documentation) |
| python
folder=1234),
pluginTypeId="myEvent",
props={"propA":"value","propB":"value"} |
| Parameters | |||
*description* |
name |
*folder* |
*pluginId* |
No | string | the plugin id of the plugin that owns the device you're creating - if it's not present it defaults to your plugin's id |
*pluginTypeId* |
Yes | string | this is the id of the |
*props* |
No | dictionary | this is the properties for the trigger - they will be inserted in to the pluginId's property space as supplied above. If you are creating a trigger of a type defined in a different plugin, it's that plugin's id and properties. |
PowerFailureTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
ServerStartupTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
X10CommandReceivedTrigger
address |
string | if commandSourceType = Address, the full X10 address to listen for or just the house code if command is All* or AnyCommand | |
avButton |
kX10AvButton | if command = AvButtonPressed, the A/V button to monitor | |
deviceId |
integer | if commandSourceType = Device, the unique device id | |
command |
kX10Cmd | the X10 command to watch for | |
commandSourceType |
kDeviceSourceType | the type of source specified for this trigger |
X10 Command Enumeration
| indigo.kX10Cmd | |
AllOff |
AllLightsOff |
when an all lights off is received |
AllLightsOn |
when an all lights on is received |
AvButtonPressed |
when an A/V button press is received |
AnyCommand |
Brighten |
Dim |
ExtendedData |
when an extended data X10 command is received |
Off |
On |
PresetDim |
when a preset dim command is received |
StatusOffResponse |
when a status off response is received |
StatusOnResponse |
when a status on response is received |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
*0* |
*Left* |
*1* |
*Menu* |
*2* |
*Mute* |
*3* |
*Pause* |
*4* |
*PC* |
*5* |
*Play* |
*6* |
*Power* |
*7* |
*Recall* |
*8* |
*Record* |
*9* |
*Return* |
AB |
*Rewind* |
ChannelDown |
*Right* |
ChannelUp |
*Stop* |
Display |
*Title* |
Down |
*Up* |
Enter |
*VolumeDown* |
Exit |
*VolumeUp* |
Forward |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
myTrigger.address = "F7"
myTrigger.replaceOnServer()
VariableValueChangeTrigger
variableChangeType |
kVarChange | the type of variable change to monitor | |
variableId |
integer | the unique variable id | |
variableValue |
string | the value to compare against the variable’s value if *variableChangeType* is =, !=, >, < |
| indigo.kVarChange | |
BecomesEqual |
variable value becomes equal to |
BecomesFalse |
variable value becomes false |
variable value becomes greater than |
BecomesLessThan |
variable value becomes less than |
BecomesNotEqual |
variable value becomes not equal to |
BecomesTrue |
variable value becomes true |
Changes |
variable value has any change |
Commands (indigo.varChange.*)
| python
indigo.varChange.create(name="Trigger Name Here",
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
theTrigger=indigo.emailRcvd.create(name="Var Changed to True")
