Indigo Plugins and APIs
in this location:
/Library/Application Support/Perceptive Automation/Indigo 7(.X)
You'll notice these two folders in particular: Plugins and *Plugins (Disabled)*. These two folders are where the plugin bundles are stored (see the next section for details). Plugins that are enabled from the UI are located in the Plugins folder and when a user disables a plugin it’s moved to the *Plugins (Disabled)* folder.
The Indigo Plugin Bundle
The Info.plist File
<plist version="1.0">
<dict>
<key>PluginVersion</key>
<string>1.2.3</string>
<key>ServerApiVersion</key>
<string>2.0</string>
<key>CFBundleIdentifier</key>
<key>CFBundleVersion</key>
<string>1.0.1</string>
<key>CFBundleURLTypes</key>
<array>
<dict>
<key>CFBundleURLName</key>
</dict>
</array>
</dict>
</plist>
PluginVersion- this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, "1.0.5.2" is valid, but "1.0.5b2" is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.ServerApiVersion- this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.- Bundle display name (
CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. "ShortName Device Controls"). If it's not provided we'll use the bundle display name instead. - Bundle identifier (
CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the*com.yourorgidentifier.**namespace. This key is required. - Bundle version (
CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.1. This key is required. - URL types (
CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called "About [PLUGIN NAME]" - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
Menu Items Folder
You can drop Python scripts into this folder and they will show up in your plugin's sub-menu on the new "Plugins" menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI.
Resources Folder
the plugin (see #Plugin Store below for more details).
Indigo Server Plugins
Indigo Plugin Host
Plugin Failure Handling
Plugin Fatal: Errors that occur because of invalid XML or a failure inside the plugin initialization code (init method) are considered fatal. They will log an error and cause the Indigo Server to temporarily suspend the plugin -- the plugin will remain enabled but won't be running. Once the errors are corrected, the plugin can be restarted by its Reload menu option. Because the plugin is still in the enabled state, it will also be restarted on the next Indigo Server restart.
Plugin Auto-Restarted: If a plugin successfully initializes but then experiences a runtime crash (or is terminated via a kill signal not originating from an Indigo Server plugin disable request), then the Indigo Server will log an error and automatically restart the plugin after several seconds. This is only a crash fail-safe -- if your plugin has crashes then please fix the underlying problem (or forward the information to us if you think the problem is in the Indigo Plugin Host). If a plugin crashes multiple times over a short period of time, then the Indigo Server may slow or suppress its plugin auto-restart functionality requiring the plugin to be manually restarted via the Reload menu item.
Concurrent Thread Auto-Restarted: If a plugin defines runConcurrentThread() and an uncaught python exception is thrown within that method, then the Indigo Plugin Host will automatically (after several seconds) create a new thread and again call runConcurrentThread(). An error will also be logged with a call stack trace. In general, plugins should catch and handle common errors (hardware communication problems, out-of-bounds parameters, etc.) themselves inside runConcurrentThread(). The thread restart functionality implemented by the plugin Indigo Plugin Host is a fail-safe in case an error isn't handled, and should only be relied on for unexpected errors (if at all).
Error Logged: If an uncaught python exception is thrown out of any callback method (deviceStartComm, deviceStopComm, validatePrefsConfigUi, validateDeviceConfigUi, actionControlDimmerRelay, etc.) then an error will be logged with a call stack trace. In general, plugins should catch and handle common errors (hardware communication problems, out-of-bounds parameters, etc.) themselves. Errors logged for uncaught exceptions should be used by developers to implement their own (and more user friendly) error handling.
Server Plugin Folder
Indigo Plugin XML Conventions
Important: Most of the major elements will have an id of some kind. It's extremely important that you follow these rules when creating the //id//:
Configuration Dialogs
<ConfigUI>
<Field id="autoLabel"
type="label"
visibleBindingValue="false">
</Field>
<Field id="exampleButton"
type="button"
<Title>Find Node ID</Title>
</Field>
<Field id="nodeID"
type="textfield"
readonly="YES"
<Label>Node ID:</Label>
</Field>
<Field type="checkbox"
id="manualEntry"
defaultValue="false">
</Field>
<Field id="manualNodeID"
type="textfield"
visibleBindingValue="true">
<Label>Enter Node ID:</Label>
</Field>
</ConfigUI>
Text Field
<Label>Text Field:</Label>
</Field>
defaultValue |
No | 1.0 | You can enter a default value here. |
enabledBindingId |
No | 1.0 (1.9) | If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field. \ \ API v1.9: You can also bind to a list field and this field will only be enabled if something is selected in the list. |
enabledBindingNegate |
No | 1.9 | Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false. |
hidden |
No | 1.0 | If this attribute is set to true then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user. |
id |
Yes | 1.0 | This is a unique identifier for this Field within the context of this ConfigUI element. It must be alphanumeric (and may contain underscores) and must begin with an alphabetic character. |
readonly |
No | 1.0 | This attribute will make the field readonly - useful to show the user data that changes in some other way rather than being manipulated directly by the user - in the example above clicking the Find Node ID button will populate the ID field. |
secure |
No | 1.4 | If you specify true for this value then when the user types into the field the actual characters won't show but rather will be replaced with the bullet (•) character. The values typed into these fields are not stored securely - this will solely mask the value in the field from viewing in the UI. |
tooltip |
No | 1.0 | Unfortunately, enabled text fields won’t show tooltips (Cocoa limitation), so your tooltip should probably tell the user why it’s disabled (since that’s the only time it’ll show) if the field is ever disabled. |
type |
Yes | 1.0 | This must be textfield. |
visibleBindingId |
No | 1.0 | If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the text field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on a list or menu, set this value to a comma separated list of option values (item1, item2). You can even bind it to the value in another text field, but that’s probably of limited use. Note: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
Popup Menu
<Label>Popup Menu:</Label>
</Field>
defaultValue |
No | 1.0 (1.9) | You can enter a default value here. The value must be one of the values from the List element described below. \ \ API v1.9: If you specify a default value of "" (empty string) and there is no matching option, then the first menu item will be selected when the dialog is first run. This way you can avoid the user seeing "- no selection -" at the bottom of the menu. |
enabledBindingId |
hidden |
No | 1.0 | If this attribute is set to “true” then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user. |
id |
readonly |
tooltip |
No | 1.0 | Unfortunately, enabled menus won’t show tooltips (Cocoa limitation), so your tooltip should probably tell the user why it’s disabled (since that’s the only time it’ll show) if the field is ever disabled. |
type |
Yes | 1.0 | This must be “menu”. |
visibleBindingId |
No | 1.0 | If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the menu field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on a list or another menu, set this value to a comma separated list of option values (“item1, item2”). You can even bind it to the value in a text field, but that’s probably of limited use. Note: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
</Field>
return valuesDict
List
```xml
| *`defaultValue`* | No | 1.0 | You can enter a default value here. The value must be a comma separated list of values, each value must be listed as an option in the *`List`* element. |
| *`enabledBindingId`* | No | 1.0 (1.9) | If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field. \\ \\ <span class="dw-color-green">API v1.9</span>: You can also bind to a list field and this field will only be enabled if something is selected in the list. |
| *`enabledBindingNegate`* | No | 1.9 | Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false. |
| *`hidden`* | No | 1.0 | If this attribute is set to *`true`* then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user. |
| *`id`* | Yes | 1.0 | This is a unique identifier for this *`Field`* within the context of this *`ConfigUI`* element. It must be alphanumeric (and may contain underscores) and must begin with an alphabetic character. |
| *`readonly`* | No | 1.0 | This attribute will make the field readonly - useful to show the user data that changes in some other way rather than being manipulated directly by the user. |
| *`rows`* | No | 1.4 | Use this attribute to specify the number of rows that will show in the list. The minimum (and default) is 4. |
| *`tooltip`* | No | 1.0 | The tooltip will be shown when you hover over the actual list control. |
| *`type`* | Yes | 1.0 | This must be *`list`*. |
| *`visibleBindingId`* | No | 1.0 | If you want to conditionally show/hide this field based on the value of another field, set this value to the *`id`* of another field. If you set this, you must also include a *`visibleBindingValue`* |
| *`visibleBindingValue`* | No | 1.0 | If you specify a *`visibleBindingId`*, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to *`false`* will mean the menu field is visible only when the checkbox is unchecked, and a *`true`* means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of *`Option`* values (*`item1, item2`*). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
Static list fields are constructed almost identically to static popup menu fields - with a *`Label`* element and a *`List`* element which contains multiple *`Option`* elements. Each *`Option`* element must have a *`value`* attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma or semicolon characters. The text inside the *`Option`* element is what is displayed for each line in the user interface.
As with *`menu`* fields, you may also specify a list dynamically at runtime - that is, when the UI is created, the client will call into your plugin to get the list items. This will allow you to dynamically adjust the list items every time the UI comes up. You can also specify some built-in dynamic items that the IndigoServer will provide automatically for you. See the [#Dynamic Lists](#dynamic-lists) section below for details.
[Back to Configuration Dialogs](#configuration-dialogs)
#### Dynamic Lists
```python
</Field>
Class: indigo.devices |
indigo.zwave |
include Z-Wave devices - this is an interface filter that can be used with other filters |
indigo.insteon |
include INSTEON devices - this is an interface filter that can be used with other filters |
indigo.x10 |
include X10 devices - this is an interface filter that can be used with other filters |
indigo.responder |
include devices whose state can be changed |
indigo.controller |
include devices that can send commands |
indigo.relay |
relay devices |
indigo.dimmer |
dimmer devices |
indigo.sprinkler |
sprinklers |
indigo.thermostat |
thermostats |
indigo.iodevice |
input/output devices |
indigo.sensor |
all sensor type devices: motion sensors, TriggerLinc, SynchroLinc (sensor devices that have a virtual state in Indigo) |
self |
all device types defined by the calling plugin |
self.devTypeId |
all devices of type deviceTypeId, where deviceTypeId is one of the device types specified by the calling plugin |
com.somePlugin |
all device types defined by some other plugin |
com.somePlugin.devTypeId |
all devices of type deviceTypeId, where deviceTypeId is one of the device types specified in some other plugin |
Class: indigo.triggers |
| indigo.varChange | variable changed triggers |
</Field>
return myArray
</Field>
</Field>
Serial Port
Checkbox
```xml
| *`id`* | Yes | 1.0 | This is a unique identifier for this Field within the context of this *`ConfigUI`* element. |
| *`type`* | Yes | 1.0 | This must be “checkbox”. |
| *`defaultValue`* | No | 1.0 | You can enter a default value here. The value must be either *`true`* or *`false`*. |
| *`visibleBindingValue`* | No | 1.0 | If you specify a *`visibleBindingId`*, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to *`false`* will mean the menu field is visible only when the checkbox is unchecked, and a *`true`* means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (*`item1, item2`*). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
Checkboxes contain the standard required Label element. They also contain an optional element, *`Description`*, that’s used to deliver extra information on the right side of the checkbox. Many checkboxes may not need this extra information.
Like [button fields](#button), you can specify a *`CallbackMethod`* element in your field definition:
```xml
</Field>
return valuesDict
Label
```xml
Label fields are used to present text that span the width of the dialog. As you may have noticed, each control has an element called *`Label`* (with the exception of *`Separator`*, discussed next). When the dialog is displayed, each of those Label elements is right aligned and the actual control is left aligned directly to the right of the label. This field gives you a way to communicate a much longer chunk of text - like instructions, etc. It will actually span the entire width of the dialog and will wrap as necessary. The following table describes the attributes that are available for label fields.
| *`alignText`* | No | 1.4 | This will control how the label text is justified. Valid options are: "left" (default), "center", and "right". |
| *`alignWithControl`* | No | 1.4 | If set to "true", this will align the left margin of the label with the left margin for the actual controls (not their labels). Anything other than "true" will be considered "false" (which is also the default if not specified). This is very useful in conjunction with specifying font characteristics described below when you want to add some help specific to a control - just insert the label right below the control field and it will align with the actual control above. |
| *`fontColor`* | No | 1.4 | Use this attribute to control the color of the label text. Valid options are: "black (default), "darkgray", "red", "orange", "green", and "blue". |
| *`fontSize`* | No | 1.4 | Use this attribute to specify the size of the font. Valid options are: "regular" (default, same size as all other text in the dialog), "small, which is a point or two smaller, and "mini which is yet another point size or two smaller. |
| *`type`* | Yes | 1.0 | This must be *`label`*. |
Labels have a single element, *`Label`*, that holds the text to be displayed. **Note**: in a label field type, the *`Label`* element is required. This field type is read-only, which means that you can't have an error message attached to it from a validation method or a button method (see below for details).
#### Separator
```xml
<Field id="simpleSeparator1"
type="separator"
visibleBindingValue="1"/>
id |
Yes | 1.0 | This is a unique identifier for this Field within the context of this ConfigUI element. |
type |
Yes | 1.0 | This must be separator. |
enabledBindingId |
visibleBindingId |
No | 1.0 | If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to false will mean the menu field is visible only when the checkbox is unchecked, and a true means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (item1, item2). You can even bind it to the value in a text field, but that’s probably of limited use. Note: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
Button
```xml
| *`type`* | Yes | 1.0 | This must be *`button`*. |
Aside from the standard *`Label`* element, the button field also contains two other required elements. The first is the *`Title`* element - this is the string that is displayed inside the button. The other required element is the *`CallbackMethod`* element, which contains the name of a Python method in your code that’s called when the user presses the button. This field type is read-only, which means that you can't have an error message attached to it from a validation method or a button method (see below for details).
The process flow is this:
1. A dictionary containing all the values of the fields in the dialog are sent to the method that you identify in the *`<CallbackMethod>`* element.
1. Your plugin can then do whatever it needs to and it returns a the dictionary back to the dialog containing any field changes.
Each button's method signature will match the parameters that are used in the [#validation methods](#validation-methods) described below. For instance, if you specify a method called "beginPairing" in a button field of the *`<ConfigUI>`* XML for a device like this:
```xml
<Name>Music Server</Name>
<ConfigUI>
<Title>Begin Pairing</Title>
</Field>
<!-- SNIP -->
</Device>
return valuesDict
Validation Methods
| device | validateDeviceConfigUi(self, valuesDict, typeId, devId) |
typeId - device type specified in the type attribute \ deviceId - the unique device ID for the device being edited (or 0 of it's a new device) \ *valuesDict* - the dictionary of values currently specified in the dialog |
| event | *validateEventConfigUi(self, valuesDict, typeId, eventId)* |
typeId - event type specified in the type attribute \ eventId - the unique event ID for the event being edited (or 0 of it's a new event) \ *valuesDict* - the dictionary of values currently specified in the dialog |
| action | validateActionConfigUi(self, valuesDict, typeId, deviceId) |
typeId - action type specified in the type attribute \ deviceId - the unique device ID for the device the user selected for the action if you specify a *deviceFilter* \ *valuesDict* - the dictionary of values currently specified in the dialog |
| PluginConfig | *validatePrefsConfigUi(self, valuesDict)* |
return True
return (True, valuesDict)
errorDict = indigo.Dict()
Validating serialport Fields
errorsDict = indigo.Dict()
if len(errorsDict) > 0:
Notice that at the top of the validation method after we define the errorsDict, we call self.validateSerialPortUi(). This method will look for the fields that make up the specified field ("devicePortFieldId" in this case). It will make sure that a valid serial port is selected if it's a physical connection or that the address field is formatted properly if it's one of the network connections. If not, it will automatically add the appropriate errors to the errorsDict and will attempt to correct any URL prefix errors ("socket:%%%%" or "rfc2217:%%%%"). You can then continue to validate the rest of the fields in your dialog and use the length check on errorsDict to see if there were any errors discovered. If so, return False along with both dicts. If it's empty, just return true with the valuesDict.
Dialog Close Notification
PluginConfig.xml
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/
Devices.xml
type |
Attribute | Yes | This must be one of: relay, dimmer, thermostat, sensor, speedcontrol, or custom. We’ll discuss each below. |
id |
Attribute | Yes | This is your plugins unique identifier for this device type. It must be unique in this plugin. |
Name |
Element | Yes | This is the name of the device type that users will see when selecting the type in the Devices dialog. |
ConfigUI |
Element | No | This is the custom UI for configuring the device. It’s optional but in reality we can’t envision a device that needs no configuration. |
States |
Element | No | This element is used to describe the possible states for the device. For custom devices it is all available states. For subclassed devices it will describe any additional states for the device. See the description below for more details. |
Custom Device Type
<State id="temperature">
<ValueType>Number</ValueType>
<State id="heatSetPoint">
<State id="coolSetPoint">
<State id="mode">
id |
Attribute | Yes | This is a unique identifier for this State within the context of this Device element. IDs must follow the XML standard in terms of construction with one addition: they may not include periods ('.') - periods are reserved for internal use only. |
readonly |
Attribute | No | If you want this state to be read only, set this attribute to “YES”. For instance, as in this example, the temperature the thermostat is sensing isn’t user settable. (Currently unused but it may be used in the future) |
ValueType |
Element | Yes | This is the type of the state, which must be one of the following: Boolean, Number, List (enumeration constructed just like the <List> element of a <Field> as described above), String, and Separator (used only to visually group your states in the various popups). The <ValueType> element may also have an optional attribute if the value is Boolean//: boolType can be: “TrueFalse” (default), “OnOff”, “YesNo”, and “OneZero”. Example: <ValueType boolType=”OnOff”>Boolean</ValueType>// |
TriggerLabel |
Element | Yes | When selecting “Device State Changed” type trigger events, you can select your device in the resulting list. A popup below the device will list all of your States using this text. |
TriggerLabelPrefix |
Element | No | When defining an enumeration, trigger change label is usually going to need to be a bit different than just the trigger label (“Mode Changed to Heat” vs “Operation Mode Changed” - the former is to test a specific change, the latter will trigger on any change). To accomplish this, you can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above. |
ControlPageLabel |
Element | Yes | In the Control Page Editor, when selecting “Device State” as the display type, then select your device, the next popup will show all your states using this text. |
ControlPageLabelPrefix |
Element | No | When defining an enumeration, the control page label is usually going to need to be a bit different (“Mode is Heat” vs “Current Mode” - the former will show whether a the state is true, the latter shows the state value). You can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above. |
Events.xml
<Events>
<Event id="updateAvailable">
</Event>
</Events>
<Event id="sep1"/>
id |
Attribute | Yes | This is a unique id for the event in this Events.xml file. |
Name |
Element | Yes | This is the text that’s shown in the trigger event dialog that represents this event. |
ConfigUI |
Element | No | If your event requires any configuration, you can specify a <ConfigUI> element that’s defined exactly as above. |
Actions.xml
<Actions>
<Action id="resetInterface">
<Name>Reset Interface</Name>
</Action>
</Actions>
<Action id="sep1"/>
| Name | Type | Required | Notes | ||
id |
Attribute | Yes | This is a unique id for the event in this Actions.xml file. |
deviceFilter |
Attribute | No | If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod. This will avoid the necessity to create a ConfigUI element with just a device popup. |
uiPath |
Attribute | No | Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify "DeviceActions", Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify "NotificationActions", Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does). Added in API v2.0: use "hidden" to hide the action in the UI. Useful for actions that are only intended to be used from scripts/plugins (an API of sorts). | ||
Name |
Element | Yes | This is the text that’s shown in the actions dialog that represents this action. | ||
CallbackMethod |
Element | Yes | This is the name of the method that implements the action in your code. | ||
ConfigUI |
Element | No | If your action requires any configuration (as most will), you can specify a <ConfigUI> element that’s defined exactly as above. |
def writeToLog(self, action):
if theType:
indigo.server.log(theMessage)
Notice the call to self.substitute() - this method is defined in the plugin base class. If your user inserts %%v:12345%% into their string where 12345 is the ID of a variable, the call will return a string with all variable occurrences substituted. If your user inserts %%d:12345:someStateId%% into their string where 12345 is the ID of a device and someStateId is a valid state identifier, the call will return a string with all device state occurrences substituted.
MenuItems.xml
<MenuItems>
<MenuItem id="menu1">
</MenuItem>
<MenuItem id="menu2">
</MenuItem>
<MenuItem id="menu3">
<ConfigUI>
<Label>Light:</Label>
</Field>
</ConfigUI>
</MenuItem>
<!-- Added in v1.2 -->
<MenuItem id="menu4">
</MenuItem>
</MenuItems>
| Name | Type | Required | API Version | Notes | |
id |
Attribute | Yes | 1.0 | This is a unique id for the menu item in this file. | |
Name |
Element | Yes | 1.0 | This is the text that’s shown in your plugin’s sub-menu. | |
CallbackMethod |
Element | No | 1.0 (1.1) | This is the name of the method defined in your plugin that will be called when your user selects this menu item. \ \ API v1.1: If you specify a |
ConfigUI |
Element | No | 1.1 (1.2) | If you want a menu to open an associated dialog, you can include a standard ConfigUI element (see Configuration Dialogs above for details). \ \ API v1.2: You may also specify an actionId attribute on this element with the id of one of your actions and that action UI will be executed rather than having to specify the UI itself. If it requires a device ID that will be added at the top of the dialog. Ex: <ConfigUI actionId="actionIdHere"/> |
ButtonTitle |
Element | No | 1.1 | If you have a ConfigUI element and a CallbackMethod, you can add this element to specify the title used on the button that executes the dialog. By default it's "Execute". |
def checkForUpdates(self):
As of API v1.1 you can have your menu item open a dialog which will allow you to gather input from a user before executing the action. Just add a
You also have the option of adding a ButtonTitle element - which will allow you to change the name of the button (it defaults to "Execute").
If you don't specify a CallbackMethod then the dialog will not have Execute and Cancel buttons but rather will have just a single "Close" button. Why? We wanted to allow you the flexibility of making a dialog perform multiple actions if you like using button field types within the dialog itself. When doing that it would be awkward to have an "Execute" button that didn't really do anything.
In API v1.x
plugin.py
| General Plugin Methods | ||
| ```text | ||
| init(self, | ||
| pluginId, | ||
| pluginDisplayName, | ||
| pluginVersion, | ||
| pluginPrefs) | ||
| Yes | This method gets a dictionary of preferences that the server read from disk. You have the opportunity here to use them or alter them if you like although you most likely will just pass them on to the plugin base class: \\ \\python |
| def init(self, pluginPrefs): | ||
| indigo.PluginBase.init(self, pluginPrefs) | ||
`` You'll most likely use thestartup` method, described below, to do your global plugin initialization. |
__del__(self) |
Yes | This is the destructor for the class. Again, you’ll probably just call the super class’s method: \ \ ```python |
| def del(self): | ||
| indigo.PluginBase.del(self) | ||
startup(self) |
No | This method will get called after your plugin has been initialized. This is really the place where you want to make sure that everything your plugin needs to do gets set up correctly. It’s passed no parameters. If you’re storing a config parameter that’s not editable by the user, this is a good place to make sure it’s there and set to the right value. This is not, however, where you want to initialize devices and triggers that your plugin may provide - those are handled after this method completes (see the methods below). \ \ ```python |
| def startup(self): | ||
| indigo.server.log(u"Startup called") | ||
shutdown(self) |
No | This method will get called when the IndigoServer wants your plugin to exit. If you define a global shutdown variable, this is the place to set it. Other things you might do in this method: if your plugin uses a single interface to talk to multiple devices, this is the place where you would want to shut down that interface (close the serial port or network connection, etc). Each device and trigger will already have had a chance to shutdown by the time this method is called (see the methods below). \ \ ```python |
| def shutdown(self): | ||
| # do any cleanup necessary before exiting | ||
`` Note: *shutdown* will be called after *runConcurrentThread* (discussed next) so cleanup here will be after any changes that might result from a loop in *runConcurrentThread`*. |
runConcurrentThread(self) |
No | This method is called in a newly created thread after the startup() method finishes executing. It’s expected that it should run a loop continuously until asked to shutdown. \ \ ```python |
| def runConcurrentThread(self): | ||
| try: | ||
| while True: | ||
| # Do your stuff here | ||
| self.sleep(60) # in seconds | ||
| except self.StopThread: | ||
| # do any cleanup here | ||
| pass | ||
`` You must call *self.sleep()* with the number of seconds to delay between loops. *self.sleep()* will raise an *self.StopThread* exception when you should end *runConcurrentThread*. You don’t have to catch that exception if you don’t need to do any cleanup before returning - it will just throw out to the next level. Note: *shutdown* will be called after *runConcurrentThread`* finishes processing so you can do your cleanup there. |
stopConcurrentThread(self) |
No | This method will get called when the IndigoServer wants your plugin to stop any threads that it may have created. The default implementation (below) will set the stopThread instance variable which causes the self.sleep() method to throw the exception that you handle in runConcurrentThread above. In most circumstances, your plugin won't need to implement this method. \ \ ```python |
| def stopConcurrentThread(self): | ||
| self.stopThread = True | ||
prepareToSleep(self) |
No | The default implementation of this method will call deviceStopComm() for each device instance and triggerStopProcessing() for each trigger instance provided by your plugin. You can of course override them to do anything you like. |
wakeUp(self) |
No | The default implementation of this method will call deviceStartComm() for each device instance and triggerStartProcessing() for each trigger instance provided by your plugin. You can of course override them to do anything you like. |
| ```text | ||
| getDeviceStateList(self, | ||
| dev) | ||
| ``` | No | If your plugin defines custom devices, this method will be called by the server when it tries to build the state list for your device. The default implementation just returns the |
| ```text | ||
| getDeviceDisplayStateId(self, | ||
| dev) | ||
| ``` | No | If your plugin defines custom devices, this method will be called by the server to determine which device state ID to display in the device list UI state column. The default implementation just returns the |
| ```text | ||
| deviceStartComm(self, | ||
| dev) | ||
| ``` | No | If your plugin defines devices, this is likely the place where you'll want to do the work of starting your device up. For instance, let's say that you have a device somewhere out on the network - the easiest way to "start" your device is to implement this method. You would open the network address:port (that's defined in *dev.pluginProps*), get it's current state(s) and tell the IndigoServer to set those states (using the *dev.updateStateOnServer()* method). |
| ```text | ||
| deviceStopComm(self, | ||
| dev) | ||
| ``` | No | This is the complementary method to *deviceStartComm()* - it gets called when the device should no longer be active/enabled. For instance, when the user disables or deletes a device, this method gets called. |
| ```text | ||
| didDeviceCommPropertyChange(self, | ||
| origDev, | ||
| newDev) | ||
| ``` | No | This method gets called by the default implementation of deviceUpdated() to determine if any of the properties needed for device communication (or any other change requires a device to be stopped and restarted). The default implementation checks for any changes to properties. You can implement your own to provide more granular results. For instance, if your device requires 4 parameters, but only 2 of those parameters requires that you restart the device, then you can check to see if either of those changed. If they didn't then you can just return False and your device won't be restarted (via *deviceStopComm()*/*deviceStartComm()* calls). |
| ```text | ||
| deviceCreated(self, | ||
| dev) | ||
| ``` | Deprecated in 1.4 | This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use *deviceStartComm()* instead. |
| ```text | ||
| deviceUpdated(self, | ||
| origDev, | ||
| newDev) | ||
| ``` | No | Complementary to the deviceCreated() method described above, but signals device updates. You'll get a copy of the old device object as well as the new device object. The default implementation of this method will do a few things for you: if either the old or new device are devices defined by you, and if the device type changed OR the communication-related properties have changed (as defined by the *didDeviceCommPropertyChange()* method - see above for details) then deviceStopComm() and deviceStartComm() methods will be called as necessary (stop only if the device changed to a type that isn't your device, start only if the device changed to a type that belongs to you, or both if the props/type changed and they both both belong to you). |
| ```text | ||
| deviceDeleted(self, | ||
| dev) | ||
| ``` | No | Complementary to the *deviceCreated() method* described above, but signals device deletes. The default implementation just checks to see if the device belongs to your plugin and if so calls the *deviceStopComm()* method. If you implement this method you'll need to call *deviceStopComm()* yourself or duplicate the functionality here. |
| ```text | ||
| triggerStartProcessing(self, | ||
| trigger) | ||
| ``` | No | If your plugin defines events, this is likely the place where you'll want to do the work to start watching for those events to occur. For instance, let's say that you have an event for a plugin update, then you'll want to periodically check your site to see if there's a new version available. This is where you'd start that process. When conditions are met in your plugin for a trigger to be executed, you would call indigo.trigger.execute(triggerReference) to tell the Server to execute the trigger (and it's conditions). |
| ```text | ||
| triggerStopProcessing(self, | ||
| trigger) | ||
| ``` | No | This is the complementary method to *triggerStartProcessing()* - it gets called when the event should no longer be active/enabled. For instance, when the user disables or deletes a trigger, this method gets called. |
| ```text | ||
| didTriggerProcessingPropertyChange(self, | ||
| origTrigger, | ||
| newTrigger) | ||
| ``` | No | Much like it's device counterpart above (*didDeviceCommPropertyChange()*), this method gets called by the default implementation of *triggerUpdated()* to determine if any of the properties needed for recognizing an event have changed. The default implementation checks for any changes to any properties. |
| ```text | ||
| triggerCreated(self, | ||
| trigger) | ||
| ``` | No | This method will get called whenever a new trigger defined by your plugin is created. In many circumstances, you won't need to implement this method since the default behavior (which is to call the *triggerStartProcessing()* method if it's your trigger and it's enabled) is what you want anyway (see the *triggerStartProcessing()* method above for details). However, if for some reason you need to know when a trigger is created, but before your plugin is asked to start watching for the appropriate conditions, this method can provide that hook. If you implement this method, you'll need to either call *triggerStartProcessing()* or duplicate the functionality here. \ \ You can also have this method called for triggers that don't belong to your plugin. If, for instance, you want to know when all triggers are created (and updated/deleted), you can call the *indigo.triggers.subscribeToChanges()* method to have the IndigoServer send all trigger creation/update/deletion notifications. As with other change subscriptions, this should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer. |
| ```text | ||
| triggerUpdated(self, | ||
| origTrigger, | ||
| newTrigger) | ||
| ``` | No | Complementary to the triggerCreated() method described above, but signals trigger updates. You'll get a copy of the old trigger object as well as the new trigger object. The default implementation of this method will do a few things for you: if either the old or new trigger are triggers defined by you, and if the trigger type changed OR the communication-related properties have changed (as defined by the *didTriggerProcessingPropertyChange()* method - see above for details) then triggerStopProcessing() and triggerStartProcessing() methods will be called as necessary. |
| ```text | ||
| triggerDeleted(self, | ||
| trigger) | ||
| ``` | No | Complementary to the *triggerCreated() method* described above, but signals trigger deletes. The default implementation just checks to see if the trigger belongs to your plugin and if so calls the *triggerStopProcessing()* method. If you implement this method you'll need to call *triggerStopProcessing()* yourself or duplicate the functionality here. |
| FIXME add schedule documentation when it is complete (not currently available) | ||
| Name | Required | Notes |
| FIXME add action group documentation when it is complete (not currently available) | ||
variableCreated(self, var) |
No | This method will get called whenever a new variable is created. You can call the *indigo.variables.subscribeToChanges()* method to have the IndigoServer send all variable creation/update/deletion notifications. As with other change subscriptions, this should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer. |
variableUpdated(self, origVar, newVar) |
No | Complementary to the variableCreated() method described above, but signals variable updates. You'll get a copy of the old variable object as well as the new variable object. |
variableDeleted(self, var) |
No | Complementary to the *variableCreated() method* described above, but signals variable deletes. |
| Method definition | Parameters | Return Value | Notes | ||
| ```text | |||||
| applicationWithBundleIdentifier(self, | |||||
| bundleID) | |||||
| ``` | *bundleID* - this is the bundle identifier for the app |
SBApplication instance | Bundle id's are usually fully qualified strings - for iTunes it's com.apple.iTunes. What's returned is a scripting bridge SBApplication instance. See the Scripting Bridge documentation for more information. | ||
| ```text | |||||
| browserOpen(self, | |||||
| url) | |||||
| ``` | *url* - the url to open in the browser |
None | This method will open the specified in the default browser. Note it does so on the server machine and not on any remotely connected clients. | ||
| ```text | |||||
| debugLog(self, | |||||
| msg) | |||||
| ``` | *msg* - the string to insert into the event log |
None | (DEPRECATED - see Logging below) If, at any point in your plugin, you set *self.debug = True*, then any time debugLog is called the string will get inserted into Indigo's event log. If *self.debug = False* (the default) any call to debugLog does nothing. |
| ```text | |||||
| errorLog(self, | |||||
| msg) | |||||
None | (DEPRECATED - see Logging below) If you want an error to show up in the event log (in red text), use this log method rather than indigo.server.log(). |
| ```text | |||||
| openSerial(self, | |||||
| ownerName, | |||||
| portUrl, baudrate, bytesize, | |||||
| parity, stopbits, timeout, | |||||
| xonxoff, rtscts, writeTimeout, | |||||
| dsrdtr, interCharTimeout) | |||||
| ``` | *ownerName* - the name of the device or plugin that owns this serial port (used for error logging) - make sure that it's ASCII text with no unicode characters \ *other args* - all other arguments are passed directly to the pySerial's Serial contructor |
serial.Serial instance | This method is identical to creating a new pySerial Serial object except that it never throws an exception. If the serial connection cannot be opened then None is returned and an error will be automatically logged to the Indigo Server event log. | ||
| ```text | |||||
| sleep(self, | |||||
| seconds) | |||||
| ``` | *seconds* - the sleep duration as a real number |
None | This method should be called from within your plugin's runConcurrentThread() defined method, if it is defined. It will automatically raise the StopThread exception when the Indigo Server is trying to shutdown or restart the plugin. See runConcurrentThread documentation above for more details. |
| ```text | |||||
| substituteVariable(self, | |||||
| inString, | |||||
| validateOnly=False) | |||||
| ``` | *inString* - the string which contains valid variable ID \ validateOnly - whether to return the actual string or a validation tuple where the first item is a boolean whether the formatting is valid and the variable ID exists and the second item is the error string to show (defaults to False) |
String \ if *validateOnly* is False \ \ (BOOL, errStr) \ if *validateOnly* is True |
This method will allow any string with the following markup to have a variable value substituted: %%v:VARID%%VARID is the unique variable ID as found in the UI in various places. It's recommended that you call this method twice: first, when the validation method for your action is called so that you can validate at that point if the syntax is correct and make sure the variable exists. The second time you call this method would be when you execute the action - call it before you actually use the string so that the substitutions will be made. Errors will show up in the event log if the variable doesn't exist (or if there's a formatting problem) at action execution time. |
| ```text | |||||
| substituteDeviceState(self, | |||||
| inString, | |||||
| ``` | *inString* - the string which contains valid device ID and state key \ validateOnly - whether to return the actual string or a validation tuple where the first item is a boolean whether the formatting is valid and the variable ID exists and the second item is the error string to show (defaults to False) |
This method will allow any string with the following markup to have a variable value substituted: %%d:DEVICEID:STATEKEY%%DEVICEID is the unique device ID as found in the UI in various places and the STATEKEY is the identifier for the state. It's recommended that you call this method twice: first, when the validation method for your action is called so that you can validate at that point if the syntax is correct and make sure the device exists. The second time you call this method would be when you execute the action - call it before you actually use the string so that the substitutions will be made. Errors will show up in the event log if the device doesn't exist (or if there's a formatting problem) at action execution time. |
| ```text | |||||
| substitute(self, | |||||
| inString, | |||||
| ``` | *inString* and validateOnly as described in the previous two methods \ substituteVariable(), substituteDeviceState() |
See above | Validation works the same and should be called when your dialog validates user input. This method calls substituteVariable() first followed by substituteDeviceState(). The ordering was carefully chosen such that the variable substitution could, in fact, add more device markup to the string before the device substitution happens. So the user can even more dynamically generate content by inserting device markup into a variable value. However, only device markup will be honored in variable values - we don't recursively call variable markup on variable values. |
Logging
| Attribute | Description | |
logger |
An instance of the standard Python logger class. You should use this instance to log messages. See the examples below for details. | |
indigo_log_handler |
An instance of a special Python Handler class that emits messages to the Indigo Event Log window and the Indigo Server's log file. | |
plugin_file_handler |
An instance of a Python TimedRotatingFileHandler which writes you own log files in the /Logs/ directory. A subdirectory will be created using your plugin's ID as the name. Inside that directory will be daily log files (with 20 days of backups) of all log messages from your plugin. See below for examples of the default format of that file. |
The logger module defines 5 levels of logging: logging.DEBUG, logging.INFO, logging.WARNING, logging.ERROR, logging.CRITICAL. Instances of the Logger object can be set to log messages at any of those 5 levels, and the level logged can be changed at any time. By default, the self.logger instance is set to logging.DEBUG (we'll see why a bit further down). You can change this if you want using the setLevel() method. We've named the self.logger instance "Plugin", because it's the name of the class from which your plugin begins. We'll see why this is important later in the examples.
The debugLog(), errorLog(), and exceptionLog() methods are now just wrappers around the corresponding method above. There is another convenience method defined in the logging module: self.logger.exception("Error log message with exception appended"). If you call this method from within an except block in your plugin, it will automatically create a logging.ERROR level message and append the stack trace to whatever message you supply.
self.indigo_log_handler
Your Plugin Debug Debug log message
Your Plugin Info log message
Your Plugin Warning Warning log message
Your Plugin Error Error log message
Your Plugin Critical Error Critical log message
self.plugin_file_handler
Log Levels
Logging from submodules
Event and Message Flow
Plugin Preferences File
3rd Party Python Libraries
