Link to this comparison view
indigo_5_documentation:deletion_dependencies [2012/09/24 15:38] jayindigo_5_documentation:deletion_dependencies [2024/06/27 00:08] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== Deletion Dependencies ======
 +When an object (Device, Trigger, Schedule, Action Group, Control Page, or Variable) is deleted, you will be presented a dialog to confirm. If there are any other objects that are dependent on the object you're deleting, the dialog will warn you that the dependencies will be deleted or otherwise modified.
 +Specifically - if the object being deleted will render the dependent object useless, for instance a trigger event that's defined with the device you're deleting in the device state changed definition, then the entire object will be deleted - in this case the trigger. Same with conditions. If the object is used in one of several actions or if it's used on a control page, just the action or page element will be deleted.
