API v1.5 Release Notes
This version of the API shipped with Indigo 6 beta 5 - check the API Version Chart to see what version of the API is available in which Indigo versions.
  • Added new indigo.showModems filter - this filter for the indigo.server.getSerialPorts method will include modem type serial devices. We've found that on occasion the FTDI serial drivers will create port names that look like: /dev/cu.usbmodemfa131 rather than the more typical /dev/cu.usbserial-A500DA38. This filter will allow those ports to be returned in the method call.
  • Device types defined by plugins will now appear in the order they're declared in the Devices.xml file in the Model popup in the Device Edit dialog.
  • /www/perceptive/wiki/data/pages/api_release_notes/1.5.txt
