Back to Top
Folder Structure Image
in this location:
/Library/Application Support/Perceptive Automation/Indigo 7(.X)
Back to Top
Bundle Layout Image
<plist version="1.0">
<dict>
	<key>PluginVersion</key>
	<string>1.2.3</string>
	<key>ServerApiVersion</key>
	<string>2.0</string>
	<key>CFBundleIdentifier</key>
	<key>CFBundleVersion</key>
	<string>1.0.1</string>
	<key>CFBundleURLTypes</key>
	<array>
		<dict>
			<key>CFBundleURLName</key>
		</dict>
	</array>
</dict>
</plist>
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.
  • ServerApiVersion - this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • Bundle name (CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.
  • Bundle identifier (CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.yourorgidentifier.* namespace. This key is required.
  • Bundle version (CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.1. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
This folder is meant to contain any assets (like images, templates, etc.) that your plugin might need. If there is an icon.png file in here, it will be displayed in the Plugin Store once you submit the plugin (see Plugin Store below for more details).
Back to Server Plugins
Server Plugin Folder Image
  • id's cannot contain spaces
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Text Field
    <Label>Text Field:</Label>
</Field>
Back to Configuration Dialogs
Configuration UI Menu Image
	<Label>Popup Menu:</Label>
</Field>
</Field>
    return valuesDict
List
<code><Field type="list" id="listSample" defaultValue="item1,item3">
	<Label>List:</Label>
</Field></code>
^Attribute  ^  Required  ^  API Version  ^Notes  ^
|//''defaultValue''//|  No  |  1.0  |You can enter a default value here. The value must be a comma separated list of values, each value must be listed as an option in the //''List''// element.|
|//''enabledBindingId''//|  No  |  1.0 (1.9)  |If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field. \\  \\ <color green>API v1.9</color>: You can also bind to a list field and this field will only be enabled if something is selected in the list.|
|//''enabledBindingNegate''//|  No  |  1.9  |Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false.  |
|//''hidden''//|  No  |  1.0  |If this attribute is set to //''true''// then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user.|
|//''id''//|  Yes  |  1.0  |This is a unique identifier for this //''Field''// within the context of this //''ConfigUI''// element. It must be alphanumeric (and may contain underscores) and must begin with an alphabetic character.|
|//''readonly''//|  No  |  1.0  |This attribute will make the field readonly - useful to show the user data that changes in some other way rather than being manipulated directly by the user.|
|//''rows''//|  No  |  1.4  |Use this attribute to specify the number of rows that will show in the list. The minimum (and default) is 4.  |
|//''tooltip''//|  No  |  1.0  |The tooltip will be shown when you hover over the actual list control.|
|//''type''//|  Yes  |  1.0  |This must be //''list''//.|
|//''visibleBindingId''//|  No  |  1.0  |If you want to conditionally show/hide this field based on the value of another field, set this value to the //''id''// of another field. If you set this, you must also include a //''visibleBindingValue''//|
|//''visibleBindingValue''//|  No  |  1.0  |If you specify a //''visibleBindingId''//, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to //''false''// will mean the menu field is visible only when the checkbox is unchecked, and a //''true''// means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of //''Option''// values (//''item1, item2''//). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups.|
Static list fields are constructed almost identically to static popup menu fields - with a //''Label''// element and a //''List''// element which contains multiple //''Option''// elements. Each //''Option''// element must have a //''value''// attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma or semicolon characters. The text inside the //''Option''// element is what is displayed for each line in the user interface.
As with //''menu''// fields, you may also specify a list dynamically at runtime - that is, when the UI is created, the client will call into your plugin to get the list items. This will allow you to dynamically adjust the list items every time the UI comes up. You can also specify some built-in dynamic items that the IndigoServer will provide automatically for you. See the [[#Dynamic Lists]] section below for details.
[[#configuration_dialogs|Back to Configuration Dialogs]]
=== Dynamic Lists ===
<code><Field id="insteonDimmers" type="menu">
</Field></code>
The //''indigo.devices''// class specifies that the list will contain Indigo devices. If you don’t specify a filter, all devices defined by the user in Indigo will be returned. You can supply two filters if and only if one is an interface filter (see the first two in the list below). The filters are ANDed together, so one interface filter and one device type filter are the only combinations that will result in a non-empty list.
^  Class: //''indigo.devices''//  ^^
^Optional Filters  ^Description  ^
|//''indigo.zwave''//|include Z-Wave devices - this is an interface filter that can be used with other filters|
|//''indigo.insteon''//|include INSTEON devices - this is an interface filter that can be used with other filters|
|//''indigo.x10''//|include X10 devices - this is an interface filter that can be used with other filters|
|//''indigo.responder''//|include devices whose state can be changed|
|//''indigo.controller''//|include devices that can send commands|
|//''indigo.relay''//|relay devices|
|//''indigo.dimmer''//|dimmer devices|
|//''indigo.sprinkler''//|sprinklers|
|//''indigo.thermostat''//|thermostats|
|//''indigo.iodevice''//|input/output devices|
|//''indigo.sensor''//|all sensor type devices: motion sensors, TriggerLinc, SynchroLinc (sensor devices that have a virtual state in Indigo)|
|//''self''//|all device types defined by the calling plugin|
|//''self.devTypeId''//|all devices of type deviceTypeId, where deviceTypeId is one of the device types specified by the calling plugin|
|//''com.somePlugin''//|all device types defined by some other plugin|
|//''com.somePlugin.devTypeId''//|all devices of type deviceTypeId, where deviceTypeId is one of the device types specified in some other plugin|
The //''indigo.triggers''// class specifies that the list will contain Indigo triggers. Only a single filter from the list below will return a useful list.
^  Class: //''indigo.triggers''//  ^^
|indigo.insteonCmdRcvd  |INSTEON command received triggers|
|indigo.x10CmdRcvd  |x10 command received triggers|
|indigo.devStateChange  |device state changed triggers|
|indigo.varValueChange  |variable changed triggers|
|indigo.serverStartup  |startup triggers|
|indigo.powerFailure  |power failure triggers|
|indigo.interfaceFail  |interface failure triggers - can be used with or without a specified protocol|
|indigo.interfaceInit  |interface connection triggers - can be used with or without a specified protocol|
|indigo.emailRcvd  |email received triggers|
Using the //''indigo.schedules''// class will result in a list of all schedules, as will //''indigo.actionGroups''// and //''indigo.controlPages''// for their respective object types. None of these classes support any kind of filter. Lastly, //''indigo.variables''// will get you a list of variables. If you include //''filter="indigo.readWrite"''//, you’ll get only variables for which you can change the value. Currently, there’s only one read-only variable (isDaylight) defined by the system, but it may be possible to create them in future versions of the API.
Another special built-in list is serial ports - use //''indigo.serialPorts''// to get a list of available serial ports, and what's returned to your plugin is the full path to the plugin (e.g. "/dev/tty*"). This is suitable for using with PySerial, which we include with Indigo. See the "serialport" field type below for an even better way of collecting serial communication information.
</Field></code>
<code>def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0):
	return myArray</code>
<color red>Note</color>: both return tuple values should be strings. Specifically, items with ''**None**'' as the value (first item) will be skipped. Additionally, the first tuple value (option1 and option2 in the above example) must be a string that does not contain comma or semicolon characters.
The //''valuesDict''// parameter will contain the valuesDict for the object being edited - if it's a device config UI then it'll be the valuesDict from that device (just like what's passed in to [[#validation methods]]), etc. **Note**: if it's a new object that hasn't been saved yet, valuesDict may be None or empty so test accordingly.
The //''typeId''// parameter will contain the type - for instance, if it's an event, it will be the event type id. The //''targetId''// is the ID of the object being edited. It will be 0 if it's a new object that hasn't been saved yet.
<code><Field id="customList" type="menu">
</Field></code>
</Field></code>
<color red>Note</color>: this will cause an extra round-trip (client->Indigo server->plugin->Indigo server->client) so you should only use this when the list can change while the dialog is actually running.
=== Serial Port ===
{{:indigo_2021.1_documentation:configui_serialport_local.png?nolink|Configuration UI Serial Port Local Image
Checkbox
	<Label>Checkbox:</Label>
</Field>
</Field>
    return valuesDict
Label
Configuration UI Label Image
	</Label>
</Field>
Separator
<Field id="simpleSeparator1"
		type="separator"
		visibleBindingValue="1"/>
Button
Configuration UI Button Image
		type="button"
		visibleBindingValue="1">
</Field>
The process flow is this:
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
    return True
    return (True, valuesDict)
    errorDict = indigo.Dict()
Validating serialport Fields
	errorsDict = indigo.Dict()
	if len(errorsDict) > 0:
Dialog Close Notification
Dialog Type Method Signature
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/Plugins/
Name Type Required Notes
Custom Device Type
    <State id="temperature">
        <ValueType>Number</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
<Events>
    <Event id="updateAvailable">
    </Event>
</Events>
<Event id="sep1"/>
<Actions>
    <Action id="resetInterface">
        <Name>Reset Interface</Name>
    </Action>
</Actions>
<Action id="sep1"/>
def writeToLog(self, action):
    if theType:
        indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
<MenuItems>
    <MenuItem id="menu1">
    </MenuItem>
    <MenuItem id="menu2">
    </MenuItem>
    <MenuItem id="menu3">
        <ConfigUI>
			<Label>Light:</Label>
		</Field>
        </ConfigUI>
    </MenuItem>
    <!-- Added in v1.2 -->
    <MenuItem id="menu4">
    </MenuItem>
</MenuItems>
def checkForUpdates(self):
In API v1.x
General Plugin Methods
__init__(self,
         pluginId,
         pluginDisplayName,
         pluginVersion,
         pluginPrefs)
__del__(self)
def __del__(self):
startup(self)
def startup(self):
shutdown(self)
def shutdown(self):
runConcurrentThread(self)
    while True:
        # Do your stuff here
        self.sleep(60) # in seconds
except self.StopThread:
    # do any cleanup here
    pass
stopConcurrentThread(self)
    self.stopThread = True
prepareToSleep(self)
wakeUp(self)
Device Specific Methods
getDeviceStateList(self,
                   dev)
getDeviceDisplayStateId(self,
                        dev)
deviceStartComm(self,
                dev)
deviceStopComm(self,
               dev)
                            origDev,
                            newDev)
deviceCreated(self,
              dev)
Deprecated in 1.4 This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use deviceStartComm() instead.
deviceUpdated(self,
              origDev,
              newDev)
deviceDeleted(self,
              dev)
Trigger Specific Methods
triggerStartProcessing(self,
                       trigger)
triggerStopProcessing(self,
                      trigger)
                                   origTrigger,
                                   newTrigger)
triggerCreated(self,
               trigger)
triggerUpdated(self,
               origTrigger,
               newTrigger)
triggerDeleted(self,
               trigger)
Schedule Specific Methods
Action Group Specific Methods
Name Required Notes
Variable Specific Methods
Name Required Notes
variableCreated(self, var)
variableDeleted(self, var)
                                bundleID)
browserOpen(self,
            url)
debugLog(self,
         msg)
errorLog(self,
         msg)
openSerial(self,
         ownerName,
         portUrl, baudrate, bytesize,
         parity, stopbits, timeout,
         dsrdtr, interCharTimeout)
sleep(self,
         seconds)
substituteVariable(self,
                   inString,
                   validateOnly=False)
String
if validateOnly is False
(BOOL, errStr)
if validateOnly is True
%%v:VARID%%
substituteDeviceState(self,
                      inString,
                      validateOnly=False)
String
(BOOL, errStr)
%%d:DEVICEID:STATEKEY%%
substitute(self,
           inString,
           validateOnly=False)
Attribute Description
self.indigo_log_handler
self.plugin_file_handler
Log Levels
Logging from submodules
Logging from a submodule is relatively straight-forward. You can either get the logger for the plugin:
Custom IndigoLogHandler
MyModule Debug                     Some event log debug message here
  • The user may also enable Basic HTTP authentication and pass the username and password on the URL (https://username:[email protected]/message/PLUGINID/actionId/). Note this is less secure and not recommended.
    <Name>some message</Name>
</Action>
    return some_value
Key Value
KeyValue
StatusMeaning
KeyValue
Usage Guidance
This API is meant primarily for small(ish) text message handling, like JSON/XML messaging APIs. There are a few things that you will want to avoid:
  • Binary data - this release of the API isn't designed for binary data
Back to Top
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/plugin_guide.txt
