is generally considered to be Python code and represents the exact code needed. You'll also see code blocks like this:
Term | Meaning |
For Scripters and Developers:
myObject.replaceOnServer()
myObject.refreshFromServer()
method.For Developers:
Devices | ||
Schedule | ||
Schedule (indigo.Schedule) | indigo.schedule.* | manipulate a scheduled event not yet implemented |
Triggers | ||
Action Groups | ||
Variables | ||
General Commands | ||
and delete()
and indigo.List()
and list
The behavior of indigo.Dict
and indigo.List
Object | Description |
is a shortcut to get the string name of the item. Normally you would need to get a copy of the object (which would pull the entire object from the IndigoServer) then get the name, but this method is more efficient since it only gets the name from the IndigoServer rather than the whole object. So, an easy way to get a variable folder's name (maybe for logging) would be to do this: indigo.variables.folders.getName(1234)
at plugin start so that you'll always be notified when any device changes - you can then determine if your scene “state” has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming()
and subscribeToOutgoing()
methods in the indigo.insteon
and indigo.x10
command spaces to see commands regardless of their effect on device state.
for dev in indigo.devices: # do stuff with dev here
Filter | Description |
props.SupportsOnState | return only devices that support an ON state property |
Triggers also have filters:
Possible Exceptions | |
, MemoryError
, OverflowError
# first, let's get an indigo.DimmerDevice like a LampLinc >>> dev = indigo.devices[238621905] >>> dev.__class__ <class 'indigo.DimmerDevice'> >>> hasattr(dev,'onState') True >>> dir(dev) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'brightness', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'onState', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # Next, an indigo.ThermostatDevice >>> thermo = indigo.devices[171495708] >>> thermo.__class__ <class 'indigo.ThermostatDevice'> >>> dir(thermo) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'coolIsOn', 'coolSetpoint', 'description', 'deviceTypeId', 'enabled', 'fanIsOn', 'fanMode', 'folderId', 'globalProps', 'heatIsOn', 'heatSetpoint', 'humidities', 'humiditySensorCount', 'hvacMode', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'temperatureSensorCount', 'temperatures', 'updateStateOnServer', 'version'] # Here's a plugin defined device >>> tunes = indigo.devices["Whole House iTunes"] # notice that it only shows the Device base class >>> tunes.__class__ <class 'indigo.Device'> >>> dir(tunes) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # You can use the deviceTypeId attribute to get the plugin's defined type >>> tunes.deviceTypeId u'mediaserver'
