Getting Started Guide
Welcome to Indigo 2021.2!
- Mac OS X 10.12 or higher
Z-Wave
- ON/OFF devices (plug-in modules, switches, and outlets)
- Dimmers (plug-in modules and switches)
- Sensors (contact, magnetic, motion, temperature, etc.)
- Thermostats
- Locks
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
- The Indigo Installer.pkg file - double click this to start the Indigo installation. Follow the instructions provided by the installer. On the Installation Type screen, press the Install button (do not use Customize) to install all the Indigo packages (Server, Server Scripts, Drivers, and Client) on your designated hard drive. Note: you must install and run Indigo from an account on your Mac that has administrator privileges.
The Indigo 2021.2 application can be found here:
/Applications/Indigo 2021.2.app
/Library/Application Support/Perceptive Automation/Indigo 2021.2/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2021.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Upgrading from Indigo 2021.1
In addition to the automatic upgrade logic described below (for upgrades from Indigo 7.5 and earlier), the installer moves customer-installed images and other files from:
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Web Assets/
to:
/Library/Application Support/Perceptive Automation/Indigo 2021.2/Web Assets/
Indigo 2021.1→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 2021.1→Quit Indigomenu item. - Open the
Upgrading from Indigo 7.5
to:
Indigo 7.5→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.5→Quit Indigomenu item. - Open the
Upgrading from Indigo 7.4
to:
Indigo 7.4→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.4→Quit Indigomenu item. - Open the
Upgrading from Indigo 7.3
to:
Indigo 7.3→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.3→Quit Indigomenu item. - Open the
Upgrading from Indigo 7.2
to:
Indigo 7.2→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.2→Quit Indigomenu item. - Open the
to:
Indigo 7→Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7→Quit Indigomenu item. - Open the
First, run the Indigo 2021.2 installer. Then look through this list for any final actions.
- In Indigo 7, we moved to Python v2.7, so if you installed any shared scripts (as outlined here) then you'll need to move them from:
/Library/Python/2.6/site-packages/to/Library/Python/2.7/site-packages/ - Indigo will automatically copy your old preference file into the new location during the installation.
- Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo, then it will automatically be installed and used on launch.
- Your old Indigo database file will automatically be converted to the new Indigo file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 6/Scripts/ - Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/ - Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 5/Scripts/ - Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/ - Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 4/Scripts/ - Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/ - Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 2/Scripts/ - Control Page Images:
AppleScript after Upgrading
Upgrading from Indigo 1.x
- Your old Indigo database file will automatically be converted to the new Indigo file format on first launch. You will be prompted to save the new copy of the Indigo database file. The new Indigo file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo to your database settings will not be available in older versions of Indigo.
NOTE: Do not replace the new Indigo versions of any file with your Indigo 1.x files. They have been modified to run optimally under the new version of Indigo.
Moving an Indigo Installation to another Mac
Indigo 2021.2→License Details…menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 2021.2/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2021.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2021.2→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2021.2 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 2021.2/~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist
Uninstalling the Mac Client
/Applications/Indigo 2021.2.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-client6.plist~(your user folder)/Library/Preferences/Indigo 2021.2 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 2021.2 Client Settings.indiPref
To uninstall older versions but leave 2021.2 installed correctly, delete these:
- Indigo 2021.1:
- Indigo 7.5:
- Indigo 7.4:
- Indigo 7.3:
- Indigo 7.2:
- Indigo 7.0 and 7.1:
Starting Indigo Server
- Double click the
Indigo 2021.2application (/Applications/Indigo 2021.2.app). - If this is the first time to run
Indigo 2021.2on this Mac, then press theStart Local Server…button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2021.2→Start Local Server…menu item.
Start Server Dialog Image
Standard startup mode
Use the Also allow HTTP Basic authentication (less secure) checkbox to enable HTTP Basic authentication. This setting allows you to insert the username/password in the URL line. Older services may require this, though we recommend against using it.
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2021.2application (inside/Applications/Indigo 2021.2.app) on the remote Mac. - If this is the first time to run
Indigo 2021.2→Connect to Remote Server…menu item. - Enter the
Connectbutton.
http://192.168.1.23:8176/
Managing Plugins
Installing Plugins
- Make sure that the plugin is supported by this Indigo release (look for the Requires field).
- Click the
Download Latest Releasebutton, which will download the plugin. - When the download is complete, click on the down arrow in the title bar which will show the plugin download.
- Click the
Incompatible Plugins
Note if you see the error alert below that the “Plugin is not compatible” then the version of the plugin you installed is too new to run with your Indigo Server version. In this case the best solution is to upgrade your version of Indigo Server.
- Open the Trash folder from the Finder
- Move the previous (older) version of the plugin from the Trash folder to your Desktop.
- Lastly, follow the same instructions as above to re-install the older version of the plugin (Double-click it).
Plugin Configuration
Plugin Menus in Indigo
Main Plugins Menu
a green dot with no arrows means the plugin is enabled
Individual Plugin Submenu
The next section contains:
- the
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2021.2→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
- the
Uninstalling a Plugin
Indigo 2021.2→Stop Servermenu item in the Mac client (you can leave the client app running). - Open the following folder in the Finder:
/Library/Application Support/Perceptive Automation/Indigo 2021.2/(you can select theGo→Go to Folder…menu item in the Finder and paste in the path to open a Finder window). In that Finder window you'll see two folders:PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. - Switch back to the Indigo 2021.2 Mac client and click on the
- Choose
Date & Timeicon. - Select the
- Choose the
Indigo 2021.2→Preferences…menu item, then make sure theSunset & Sunrisetab is selected. - Select the
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2021.2→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2021.2→Check for Updates… menu item.
- Choose
Energy Savericon. - Move the
Where to Go Next
