Indigo Plugins and APIs
in this location:
The Indigo Plugin Bundle
The Info.plist File
PluginVersion- this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.ServerApiVersion- this is the version of the server plugin API as defined by us. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.- Bundle display name (
CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead. - Bundle identifier (
CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use thecom.yourorgidentifier.*namespace. This key is required. - Bundle version (
CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us. This key is required. - URL types (
CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
Menu Items Folder
Resources Folder
Indigo Server Plugins
Indigo Plugin Host
Plugin Failure Handling
Server Plugin Folder
Indigo Plugin XML Conventions
Configuration Dialogs
<ConfigUI>
<Field id="autoLabel"
type="label"
visibleBindingValue="false">
</Field>
<Field id="exampleButton"
type="button"
<Title>Find Node ID</Title>
</Field>
<Field id="nodeID"
type="textfield"
readonly="YES"
<Label>Node ID:</Label>
</Field>
<Field type="checkbox"
id="manualEntry"
defaultValue="false">
</Field>
<Field id="manualNodeID"
type="textfield"
visibleBindingValue="true">
<Label>Enter Node ID:</Label>
</Field>
</ConfigUI>
Text Field
<Label>Text Field:</Label>
</Field>
Popup Menu
return valuesDict
List
Dynamic Lists
Class: indigo.devices |
Class: indigo.triggers |
return myArray
Serial Port
Checkbox
return valuesDict
Label
Separator
Button
The process flow is this:
<Name>Music Server</Name>
<ConfigUI>
<Title>Begin Pairing</Title>
</Field>
<!-- SNIP -->
</Device>
return valuesDict
Validation Methods
return True
return (True, valuesDict)
errorDict = indigo.Dict()
Validating serialport Fields
Validation Best Practices
There are several ways you can optimize your validation routines and improve users' experience.
Leveraging Validation Routines
In instances where users might use Python scripts to access your plugin's functions, you can use the same validation code to test built-in functions and use the same code to test incoming data from scripted function calls. For example,
# Called from the config dialog
return self.myValidator(valuesDict)
def myValidator(self, valuesDict):
if len(errorDict) > 0:
def actionApi(self, plugin_action, dev, caller_waiting_for_result):
# Called from a scripting action
props = plugin_action.PROPS
result = self.myValidator(props)
if not result[0]:
# scripting failure return
# Do scripting action
Dialog Close Notification
PluginConfig.xml
/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/
Custom HTML Config Dialogs
You can also implement your own custom configuration in HTML if you prefer. Rather than adding lots of <Field> definitions, you simply specify a <URL> element. The URL specified can either be a fully specified URL (%%protocol:host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example.
==== Devices.xml ====
^Name ^ Type ^ Required ^Notes ^
|type| Attribute | Yes |This must be one of: relay, dimmer, thermostat, sensor, speedcontrol, or custom. We’ll discuss each below.|
|id| Attribute | Yes |This is your plugins unique identifier for this device type. It must be unique in this plugin.|
|Name| Element | Yes |This is the name of the device type that users will see when selecting the type in the Devices dialog.|
|ConfigUI| Element | No |This is the custom UI for configuring the device. It’s optional but in reality we can’t envision a device that needs no configuration.|
|States| Element | No |This element is used to describe the possible states for the device. For custom devices it is all available states. For subclassed devices it will describe any additional states for the device. See the description below for more details.|
=== Custom Device Type ===
<code><States>
<State id=“temperature”>
<ValueType>Number</ValueType>
<State id=“heatSetPoint”>
<State id=“coolSetPoint”>
<State id=“mode”>
<Option value=“off”>Off</Option>
<Option value=“heatOn”>Heat On</Option>
<Option value=“coolOn”>Cool On</Option>
<Option value=“heatCoolOn”>Heat and Cool On</Option>
</States></code>
|id| Attribute | Yes |This is a unique identifier for this State within the context of this Device element. IDs must follow the XML standard in terms of construction with one addition: they may not include periods ('.') - periods are reserved for internal use only.|
|readonly| Attribute | No |If you want this state to be read only, set this attribute to “YES”. For instance, as in this example, the temperature the thermostat is sensing isn’t user settable. (Currently unused but it may be used in the future)|
|ValueType| Element | Yes |This is the type of the state, which must be one of the following: Boolean, Number, List (enumeration constructed just like the <List> element of a <Field> as described above), String, and Separator (used only to visually group your states in the various popups). The <ValueType> element may also have an optional attribute if the value is Boolean: boolType can be: “TrueFalse” (default), “OnOff”, “YesNo”, and “OneZero”. Example: <ValueType boolType=”OnOff”>Boolean</ValueType>|
|TriggerLabel| Element | Yes |When selecting “Device State Changed” type trigger events, you can select your device in the resulting list. A popup below the device will list all of your States using this text.|
|TriggerLabelPrefix| Element | No |When defining an enumeration, trigger change label is usually going to need to be a bit different than just the trigger label (“Mode Changed to Heat” vs “Operation Mode Changed” - the former is to test a specific change, the latter will trigger on any change). To accomplish this, you can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above. |
|ControlPageLabel| Element | Yes |In the Control Page Editor, when selecting “Device State” as the display type, then select your device, the next popup will show all your states using this text.|
|ControlPageLabelPrefix| Element | No |When defining an enumeration, the control page label is usually going to need to be a bit different (“Mode is Heat” vs “Current Mode” - the former will show whether a the state is true, the latter shows the state value). You can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above.|
==== Events.xml ====
<code><?xml version=“1.0”?>
<Events>
<Event id=“updateAvailable”>
</Event>
</Events></code>
<code><Event id=“sep1”/></code>
|id| Attribute | Yes |This is a unique id for the event in this Events.xml file.|
|Name| Element | Yes |This is the text that’s shown in the trigger event dialog that represents this event.|
|ConfigUI| Element | No |If your event requires any configuration, you can specify a <ConfigUI> element that’s defined exactly as above.|
==== Actions.xml ====
<Actions>
<Action id=“resetInterface”>
<Name>Reset Interface</Name>
</Action>
</Actions></code>
<code><Action id=“sep1”/></code>
|id| Attribute | Yes |This is a unique id for the event in this Actions.xml file.|
|deviceFilter| Attribute | No |If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod. This will avoid the necessity to create a ConfigUI element with just a device popup.|
|uiPath| Attribute | No |Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify “DeviceActions”, Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify “NotificationActions”, Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does). Added in API v2.0: use “hidden” to hide the action in the UI. Useful for actions that are only intended to be used from scripts/plugins (an API of sorts).|
|Name| Element | Yes |This is the text that’s shown in the actions dialog that represents this action.|
|CallbackMethod| Element | Yes |This is the name of the method that implements the action in your code.|
|ConfigUI| Element | No |If your action requires any configuration (as most will), you can specify a <ConfigUI> element that’s defined exactly as above.|
<code>def writeToLog(self, action):
theMessage = self.substitute(action.props.get(“message”, ””))
theType = action.props.get(“type”)
self.debugLog(u”Write to log: “ + theMessage)
if theType:
indigo.server.log(theMessage)</code>
Notice the call to self.substitute() - this method is defined in the plugin base class. If your user inserts <code>%%v:12345%%</code> into their string where 12345 is the ID of a variable, the call will return a string with all variable occurrences substituted. If your user inserts <code>%%d:12345:someStateId%%</code> into their string where 12345 is the ID of a device and someStateId is a valid state identifier, the call will return a string with all device state occurrences substituted.
==== MenuItems.xml ====
<MenuItems>
<MenuItem id=“menu1”>
</MenuItem>
<MenuItem id=“menu2”>
</MenuItem>
<MenuItem id=“menu3”>
<Name>Turn Off Light…</Name>
<ConfigUI>
<Field id=“targetDevice” type=“menu”>
<Label>Light:</Label>
<List class=“self” filter=“self.myLightType” method=“getDynamicList” />
</Field>
</ConfigUI>
</MenuItem>
<!– Added in v1.2 –>
<MenuItem id=“menu4”>
<ConfigUI actionId=“someAction”/>
</MenuItem>
</MenuItems></code>
^Name ^ Type ^ Required ^ API Version ^Notes ^
|id| Attribute | Yes | 1.0 |This is a unique id for the menu item in this file.|
|Name| Element | Yes | 1.0 |This is the text that’s shown in your plugin’s sub-menu.|
|CallbackMethod| Element | No | 1.0 (1.1) |This is the name of the method defined in your plugin that will be called when your user selects this menu item.
API v1.1: If you specify a <ConfigUI> for the menu, then this property is optional. If it's present, then the the method will be called with arguments much like a validation (see example below). If it's not present (in which case a ConfigUI must be present), then the dialog will contain only a single “Close” button. In that case the functionality in the dialog will be completely left up to buttons contained within the dialog.|
|ConfigUI| Element | No | 1.1 (1.2) |If you want a menu to open an associated dialog, you can include a standard ConfigUI element (see Configuration Dialogs above for details).
API v1.2: You may also specify an actionId attribute on this element with the id of one of your actions and that action UI will be executed rather than having to specify the UI itself. If it requires a device ID that will be added at the top of the dialog. Ex: <ConfigUI actionId=“actionIdHere”/>|
|ButtonTitle| Element | No | 1.1 |If you have a ConfigUI element and a CallbackMethod, you can add this element to specify the title used on the button that executes the dialog. By default it's “Execute”.|
<code>def checkForUpdates(self):
indigo.server.log(u”checkForUpdates called“)
# Do the actual work here to see if there are any updates</code>
<code>def turnOffLight(self, valuesDict, typeId):
indigo.server.log(“Turning off light: %s” % valuesDict[“targetDevice”])
return (True, valuesDict, errorsDict)</code>
=== Custom HTML Menu Item Dialogs ===
You can also implement your own custom menu item form in HTML if you prefer. Rather than adding <CallbackMethod> and <ConfigUI> definitions, you simply specify a <URL> element. The URL specified can either be a fully specified URL (%%protocol:host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example.
SupportURL Elements
plugin.py
General Plugin Methods
__init__(self,
pluginId,
pluginDisplayName,
pluginVersion,
pluginPrefs)
You'll most likely use the |
Note: |
while True:
# Do your stuff here
self.sleep(60) # in seconds
except self.StopThread:
# do any cleanup here
pass
You must call |
self.stopThread = True
getDeviceStateList(self,
dev)
getDeviceDisplayStateId(self,
dev)
deviceStartComm(self,
dev)
deviceStopComm(self,
dev)
origDev,
newDev)
deviceUpdated(self,
origDev,
newDev)
deviceDeleted(self,
dev)
triggerStartProcessing(self,
trigger)
triggerStopProcessing(self,
trigger)
origTrigger,
newTrigger)
triggerCreated(self,
trigger)
triggerUpdated(self,
origTrigger,
newTrigger)
triggerDeleted(self,
trigger)
| Name | Required | Notes |
Helper Methods
bundleID)
browserOpen(self,
url)
debugLog(self,
msg)
errorLog(self,
msg)
openSerial(self,
ownerName,
portUrl, baudrate, bytesize,
parity, stopbits, timeout,
dsrdtr, interCharTimeout)
sleep(self,
seconds)
substituteVariable(self,
inString,
validateOnly=False)
substituteDeviceState(self,
inString,
validateOnly=False)
substitute(self,
inString,
validateOnly=False)
Properties
Logging
| Attribute | Description |
self.indigo_log_handler
self.plugin_file_handler
Log Levels
Logging from submodules
Logging from a submodule is relatively straight-forward. You can either get the logger for the plugin:
Custom IndigoLogHandler
?other=args&api_key=KEYHERE) - The user may also enable Basic HTTP authentication and pass the username and password on the URL (https://username:[email protected]/message/PLUGINID/actionId/). Note this is less secure and not recommended.
<Name>some message</Name>
</Action>
return some_value
| Key | Value |
file_path | this will be a list of path parts from the URL after the action ID. So for the url: %%http://host/message/pluginid/actionid/path/to/some/file.txt%% the value will be an indigo.List with the following items: %%[“path”, “to”, “some”, “file.txt”]%% |
| Key | Value |
| Status | Meaning |
| Key | Value |
Usage Guidance
- Binary data - this release of the API isn't designed for binary data
Event and Message Flow
Plugin Preferences File
3rd Party Python Libraries
