apiVersion | string | No | API v1.7: the currently connected Indigo Server plugin API version as a string (ex: “1.7”) |
licenseStatus | string | No | API v2.5: returns one of the values specified in the indigo.kLicenseStatus enumeration below |
/* |portNum| integer | No |the port number of the currently connected Indigo Server */
/* |connectionGood| boolean | No |true if the connection to the Indigo Server is currently good| */
License Status Enumeration
| indigo.kLicenseStatus |
Value | Description |
ActiveTrial | the license is a trial |
ActiveSubscription | license has an active Indigo Up-to-Date subscription (access to a reflector) |
ExpiredSubscription | license has an expired Indigo Up-to-Date subscription (no access to a reflector) |
Unknown | license is in an unknown state |
| Parameters |
| direct parameter | No | datetime.date | a datetime.date object representing the day to calculate the sunrise time for |
| Parameters |
| Parameters |
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
| Parameters |
| Parameters |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
indigo.server.getTime()
No Parameters
No Parameters
| Parameters |
| direct parameter | Yes | string | this is the text that’s written to the log |
level | No | integer | API v2.4: the python logging level which determines both the type shown and the text color used. (ex: using level=logging.WARNING will show orange text) |
isError | No | boolean | if True, it will show up in red in the event log - default is False - if no type is included, the name of the plugin will automatically be used with “ Error” appended |
| Parameters |
| Parameters |
