Integration APIs
his article is about the two APIs in IWS that developers can use to integrate Indigo with external services:
- WebSocket API – (which the new Indigo Touch Web UI uses, and
NOTE:
Versioning
%%/v2/%%- this is the top level version number and will change as necessary
Python vs JavaScript
"key1": "value 1",
"key2": 2
| Python | JSON Equivalent |
| True | true |
| False | false |
| float | Number |
| int | Number |
| None | null |
| dict | Object |
| list | Array |
| tuple | Array |
| str | String |
WebSocket API
%%/v2/api/ws/device-feed%%- WebSocket to do all communication about devices%%/v2/api/ws/variable-feed%%- WebSocket to do all communication about variables%%/v2/api/ws/action-feed%%- WebSocket to do all communication about action groups%%/v2/api/ws/page-feed%%- WebSocket to do all communication about control pages%%/v2/api/ws/log-feed%%- WebSocket to do all communication about logs
WebSocket Lifecycle
- Setup:
Authentication
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed?api-key=YOUR-API-KEY%%
Note the protocol: wss. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Don't share your API keys with anyone who isnot authorized to use them — especially in posts to the Indigo user forums.
==== Examples ====
=== Python Receiver Example ===
<code python>
import asyncio
import websockets
import json
API_KEY = 'YOUR-API-KEY'
async def receiver():
headers = {“Authorization”: f“Bearer {API_KEY}”}
async with websockets.connect(“ws:localhost:8176/v2/api/ws/device-feed”, extra_headers=headers) as websocket:
while True:
except Exception as exc:
print(f“Exception:\n{exc}”)
asyncio.run(receiver())
</code>
=== Python Receiver/Sender Example ===
<code python>
import asyncio
import json
API_KEY = 'YOUR_API_KEY' # YOUR API KEY HERE
DEVICE_ID = 12345678 # YOUR DEVICE ID HERE
HEADERS = {“Authorization”: f“Bearer {API_KEY}”}
URI = “ws:127.0.0.1:8176/v2/api/ws/device-feed” # wss: if using the reflector
async def receiver(ws):
print(“Starting receiver task”)
refresh_message = {
“id”: “initial-device-refresh”,
“message”: “refresh”,
“objectType”: “indigo.Device”,
“objectId”: DEVICE_ID
counter = 0
device = {}
while counter < 20:
log_string = “ignoring message”
if message_type == “refresh”:
device = message[“objectDict”]
log_string = f“receiver: device refresh message: '{device.get('name', 'unknown')}'”
elif message_type == “patch”:
if message[“objectId”] == device[“id”]:
log_string = f“'receiver: device patch message: {device.get('name', 'unknown')}' update: \n{message_json}”
print(f“receiver: loop count: {counter}”)
print(f“receiver: {log_string}”)
counter += 1
async def sender(ws, count):
print(“Starting sender task”)
message = {
for count in range(10):
print(f“sender: loop count: {count}”)
msg = json.dumps(message)
print(f“sender: sending message: {msg}”)
await asyncio.sleep(5)
async def main():
asyncio.run(main())
</code>
=== JavaScript Example ===
Here's a simple nodejs JavaScript to open the device-feed and print out any messages it receives (you'll need to %%ws:localhost:8176/v2/api/ws/device-feed%%npm install websocket before running it).
<code javascript>
const APIKEY = “YOUR-API-KEY”;
const W3CWebSocket = require(“websocket”).w3cwebsocket;
console.log(“Creating websocket”);
`ws:localhost:8176/v2/api/ws/device-feed?api-key=${APIKEY}`
console.log(message.data);
</code>
==== Device Feed ====
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed%%
=== Device messages from the server ===
== add device message ==
<code json>
“message”: “add”,
objectDict“: {
“class”: “indigo.DimmerDevice”,
“address”: “3B.04.7A”,
“batteryLevel”: null,
“blueLevel”: null,
“brightness”: 100,
“buttonConfiguredCount”: 0,
“buttonGroupCount”: 1,
“configured”: true,
“defaultBrightness”: 100,
“description”: ”- sample device -“,
“deviceTypeId”: ”“,
“displayStateId”: “brightnessLevel”,
“displayStateImageSel”: “indigo.kStateImageSel.DimmerOn”,
“displayStateValRaw”: 100,
“displayStateValUi”: “100”,
“enabled”: true,
“energyAccumBaseTime”: null,
“energyAccumTimeDelta”: null,
“energyAccumTotal”: null,
“energyCurLevel”: null,
“errorState”: ”“,
“folderId”: 1552926800,
“globalProps”: {
“com.indigodomo.indigoserver”: {},
“emptyDict”: {}
“greenLevel”: null,
“id”: 1508839119,
“lastChanged”: “2023-02-16T15:43:53”,
“lastSuccessfulComm”: “2023-02-16T15:43:53”,
“ledStates”: [],
“model”: “LampLinc (dual-band)”,
“name”: “Insteon Dimmer”,
“onBrightensToDefaultToggle”: true,
“onBrightensToLast”: false,
“onState”: true,
“ownerProps”: {},
“pluginId”: ”“,
“pluginProps”: {},
“protocol”: “indigo.kProtocol.Insteon”,
“redLevel”: null,
“remoteDisplay”: false,
“sharedProps”: {},
“states”: {
“brightnessLevel”: 100,
“onOffState”: true
“subModel”: “Plug-In”,
“subType”: “Plug-In”,
“supportsAllLightsOnOff”: true,
“supportsAllOff”: true,
“supportsColor”: false,
“supportsOnState”: true,
“supportsRGB”: false,
“supportsRGBandWhiteSimultaneously”: false,
“supportsStatusRequest”: true,
“supportsTwoWhiteLevels”: false,
“supportsTwoWhiteLevelsSimultaneously”: false,
“supportsWhite”: false,
“supportsWhiteTemperature”: false,
“version”: 67,
“whiteLevel”: null,
“whiteLevel2”: null,
“whiteTemperature”: null
</code>
== update device message ==
<code json>
“message”: “patch”,
“objectId”: 1508839119,
“patch”: [
“change”,
“brightness”,
[100, 0]
“change”,
“displayStateImageSel”,
[“indigo.kStateImageSel.DimmerOn”, “indigo.kStateImageSel.DimmerOff”]
“change”,
“displayStateValRaw”,
[100, 0]
“change”,
“displayStateValUi”,
[“100”, “0”]
“change”,
“lastChanged”,
[“2023-02-17T16:29:56”, “2023-02-17T16:30:54”]
“change”,
“lastSuccessfulComm”,
“change”,
“onState”,
[true, false]
“change”,
“states.brightnessLevel”,
[100, 0]
“change”,
“states.onOffState”,
[true, false]
}</code>
== device refresh messages ==
<code json>
“id”: “optional-custom-user-message”,
“list”: []
</code>
<code json>
“objectDict”: {}
</code>
== delete device message ==
<code json>
“message”: “delete”,
“objectId”: 123456789
</code>
=== Device messages to the server ===
== device refresh requests ==
<code json>
Specify the object type
</code>
If you want the entire device list, simply omit the %%dict(some_variable)%%objectId key and the server will return the full list. The server will respond with the appropriate device refresh message shown above.
== device command messages ==
<code json>
“message”: “indigo.device.toggle”,
“objectId”: 123456789,
</code>
==== Variable Feed ====
%%ws:localhost:8176/v2/api/ws/variable-feed%%
=== Variable messages from the server ===
== Example variable object (dictionary in Python) ==
<code json>
“class”: “indigo.Variable”,
“description”: ”“,
“folderId”: 0,
“globalProps”: {
“id”: 345633244,
“name”: “house_status”,
“pluginProps”: {},
“readOnly”: false,
“remoteDisplay”: true,
“sharedProps”: {},
“value”: “home”
</code>
== add variable message ==
<code json>
“message”: “add”,
“objectType”: “indigo.Variable”,
“objectDict”: {} Variable object as outlined above
</code>
== update variable message ==
<code json>
“message”: “patch”, we use a patch rather than send the entire updated device
“patch”: {} A patch object - see the Object Patches below for details
</code>
Variable patch objects are created via the dictdiffer python module by comparing the variable dictionary (
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/variable-feed%%) for the old variable with the one for the new dictionary as they are received in the %%variable_updated()%% Plugin method call.
== delete variable message ==
<code json>
</code>
=== Variable messages to the server ===
== variable refresh messages ==
<code json>
</code>
== Example refresh all variables message ==
<code json>
“list”: [] a list of Variable objects as outlined above
</code>
=== variable command messages ===
== updateValue ==
<code json>
Note, values passed in the parameter dictionary must be strings. You can
pass in an empty string (”“) to clear the variable value.
“message”: “indigo.variable.updateValue”,
“objectId”: 123456789, the variable id to update
“parameters”: {
“value”: “Some string value”
</code>
==== Action Group Feed ====
%%dict(some_action_group)%%%%ws:localhost:8176/v2/api/ws/action-feed%%
=== Action Group messages from the server ===
== Example action group object (dictionary in Python) ==
<code json>
“class”: “indigo.ActionGroup”,
“description”: ”“,
“folderId”: 532526508,
“globalProps”: {
“speakDelayTime”: “5”,
“speakTextVariable”: “speech_string”
“id”: 94914463,
“name”: “Movie Night”,
“pluginProps”: {},
“sharedProps”: {
</code>
== add action group message ==
<code json>
“message”: “add”,
“objectType”: “indigo.ActionGroup”,
“objectDict”: {} ActionGroup object as outlined above
</code>
== update action group message ==
<code json>
</code>
Action group patch objects are created via the dictdiffer python module, by comparing the action dictionary (
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/action-feed%%) for the old action with the one for the new dictionary as they are received in the %%action_group_updated()%% Plugin method call.
== delete action group message ==
<code json>
</code>
=== Action Group messages to the server ===
== action group refresh messages ==
<code json>
</code>
== Example refresh all action groups message ==
<code json>
“list”: [] a list of ActionGroup objects as outlined above
</code>
=== action group command messages ===
== Execute ==
<code json>
“message”: “indigo.actionGroup.execute”,
“objectId”: 123456789 the action group id to execute
</code>
==== Control Page Feed ====
%%dict(some_page)%%%%ws:localhost:8176/v2/api/ws/page-feed%%
=== Control Page messages from the server ===
<code json>
“class”: “indigo.ControlPage”,
“backgroundImage”: ”“,
“description”: ”“,
“folderId”: 0,
“globalProps”: {},
“hideTabBar”: true,
“id”: 963336187,
“name”: “Weather Images”,
“pluginProps”: {},
“sharedProps”: {}
</code>
== add control page message ==
<code json>
“message”: “add”,
“objectType”: “indigo.ControlPage”,
“objectDict”: {} ControlPage object as outlined above
</code>
== update control page message ==
<code json>
“message”: “patch”, we use a patch rather than send the entire updated control page
</code>
Page patch objects are created via the dictdiffer python module, by comparing the device dictionary (
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/page-feed%%) for the old page with the one for the new dictionary as they are received in the %%control_page_updated()%% Plugin method call.
== delete control page message ==
<code json>
</code>
==== Indigo Object Folders ====
<code>
“id”: 617272302,
“class”: “indigo.Folder”,
“name”: “My Device Folder”,
</code>
=== refresh folder server message ===
<code>
“objectType”: “indigo.Device.Folder”,
</code>
<code>
“objectType”: “indigo.Device.Folder”, or indigo.Variable.Folder, etc
“list”: [] A list of folder objects defined above
</code>
==== Log Feed ====
<code>
ws:localhost:8176/v2/api/ws/log-feed
wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/log-feed
</code>
<code json>
“message”: “add”,
“objectType”: “indigo.LogEvent”,
“objectDict”: {
“message”: “Stopping plugin \”Web Server 2023.1.0\” (pid 1020)“,
“timeStamp”: “2022-12-01T12:03:27.759000”,
“typeStr”: “Application”,
“typeVal”: 0
</code>
===== HTTP API =====
==== HTTP API Endpoints ====
* %%/v2/api/indigo.devices%% - endpoint to get a list of devices
* %%/v2/api/indigo.devices/123456789%% - endpoint to get a specific device instance (See Device Objects below)
* %%/v2/api/indigo.variables%% - endpoint to get a list of variables
* %%/v2/api/indigo.variables/123456789%% - endpoint to specific variable object (See Variable Objects below)
* %%/v2/api/indigo.actionGroups%% - endpoint to get a list of action groups
* %%/v2/api/indigo.actionGroups/123456789%% - endpoint to get a specific action group (See Action Group Objects below)
* %%/v2/api/command%% - endpoint to send Indigo a command (device control, variable update, action execution).
==== Authentication ====
==== Getting Device Objects ====
=== Getting All Device Objects ===
== Pure Python 3 (no additional libraries) ==
* Replace YOUR-API-KEY with a valid key from your Indigo account.
* Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server.
<code python>
import json
REFLECTORNAME = “YOUR-REFLECTOR-NAME”
req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.devices“)
req.add_header('Authorization', f”Bearer {APIKEY}“)
with urlopen(req) as request:
print(device_list)
</code>
== JavaScript run from nodejs (no additional libraries) ==
* Replace YOUR-API-KEYYOUR-API-KEY with a valid key from your Indigo account.
<code javascript>
Things that are specific to your environment
const REFLECTORNAME = “YOUR-REFLECTOR-NAME”
Get the http module, and tell it that you're using HTTPS
const http = require(“https”)
These are options that you'll pass to the get call
const options = {
headers: {
Get the device JSON from Indigo, parse it into an object, and log it to the console
http.get(options, (response) ⇒ {
let result = ”“
response.on(“data”, chunk ⇒ {
result += chunk;
response.on(“end”, () ⇒ {
console.log(deviceList);
</code>
== Using curl from the command line ==
<code bash>
curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices
</code>
=== Getting a Single Device Object ===
* Replace 123456789 with a valid Indigo device ID.
<code python>
import json
DEVICEID = 123456789
req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.devices/{DEVICEID}“)
print(device_instance)
</code>
* Replace with a valid key from your Indigo account.
<code javascript>
const DEVICEID = 123456789
const options = {
headers: {
let result = ”“
result += chunk;
console.log(deviceInstance);
</code>
<code bash>
curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices/123456789
</code>
=== Controlling an Indigo Device ===
<code python>
import json
message = json.dumps({
“objectId”: DEVICEID
}).encode(“utf8”)
req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/command“, data=message)
reply = json.load(request)
print(reply)
</code>
== JavaScript toggle from nodejs (no additional libraries) ==
<code javascript>
const options = {
path: ”/v2/api/command“,
method: “POST”,
headers: {
“Content-Length”: message.length
const req = http.request(options, (response) ⇒ {
let result = ”“
result += chunk;
req.write(message)
req.end()</code>
<code bash>
curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.device.toggle”, “objectId”: 123456789}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
</code>
=== Controlling an Indigo Device with Parameters ===
<code python>
import json
“message”: “indigo.dimmer.setBrightness”,
“objectId”: DEVICEID,
“parameters”: {
“value”: 50,
“delay”: 10
}).encode(“utf8”)
print(reply)
</code>
<code javascript>
“parameters”: {
“value”: 50,
“delay”: 10
const options = {
method: “POST”,
headers: {
let result = ”“
result += chunk;
req.write(message)
req.end()</code>
<code bash>
curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.dimmer.setBrightness”, “objectId”: 123456789, “parameters”: {“value”: 50, “delay”: 10}}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
</code>
==== Getting Variable Objects ====
=== Getting All Variable Objects ===
<code python>
import json
req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.variables“)
print(variable_list)
</code>
<code javascript>
const options = {
headers: {
Get the variable JSON from Indigo, parse it into an object, and log it to the console
let result = ”“
result += chunk;
console.log(VariableList);
</code>
<code bash>
curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables
</code>
=== Getting a Single Variable Object ===
* Replace 123456789 with a valid Indigo variable ID.
<code python>
import json
VARID = 123456789 # Indigo variable object id
req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.variables/{VARID}“)
print(var_instance)
</code>
<code javascript>
const VARID = 123456789
const options = {
headers: {
Get the variable object JSON from Indigo, parse it into an object, and log it to the console
let result = ”“
result += chunk;
console.log(varInstance);
</code>
<code bash>
curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables/123456789
</code>
=== Updating a Variable's Value ===
<code python>
import json
VARIABLEID = 123456789
“objectId”: VARIABLEID,
“parameters”: {
}).encode(“utf8”)
print(reply)
</code>
<code javascript>
const VARIABLEID = 123456789
“parameters”: {
const options = {
method: “POST”,
headers: {
let result = ”“
result += chunk;
req.write(message)
req.end()</code>
<code bash>
curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.variable.updateValue”, “objectId”: 123456789, “parameters”: {“value”: “Some string value”}}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
</code>
==== Getting Action Group Objects ====
=== Getting All Action Group Objects ===
<code python>
import json
req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.actionGroups“)
print(action_group_list)
</code>
<code javascript>
const options = {
headers: {
Get the action group JSON from Indigo, parse it into an object, and log it to the console
let result = ”“
result += chunk;
console.log(actionGroupList);
</code>
<code bash>
curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.actionGroups
</code>
=== Executing an Action Group ===
* Replace 123456789 with a valid Indigo action group ID.
<code python>
import json
ACTIONGROUPID = 123456789
“objectId”: ACTIONGROUPID
}).encode(“utf8”)
print(reply)
</code>
<code javascript>
const options = {
method: “POST”,
headers: {
let result = ”“
result += chunk;
req.write(message)
req.end()</code>
* Replace Web Server Warning HTTP 400 error for request /v2/api/command/ from 123.45.678.90''
^ Code ^ Condition ^ Description ^
| 200 | OK or Success |Indicates that the request has succeeded. |
| 400 | Bad Request |Indicates that the server cannot or will not process the request due to something that is perceived to be a client error <HTML><BR></HTML>(for example, malformed request syntax, invalid request message framing, or deceptive request routing) |
| 401 | Unauthorized |Indicates that the client request has not been completed because it lacks valid authentication credentials for the <HTML><BR></HTML>requested resource. |
| 404 | Not Found |Indicates that the server cannot find the requested resource. |
| 500 | Internal Server Error |Indicates that the server encountered an unexpected condition that prevented it from fulfilling the request. |
<code bash>
curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.actionGroup.execute”, “objectId”: 123456789}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
</code>
===== API Messages =====
==== Device Messaging ====
=== Device Objects ===
== Example device object ==
<code json>
“blueLevel”: null,
“brightness”: 0,
“configured”: true,
“deviceTypeId”: ”“,
“displayStateImageSel”: “indigo.kStateImageSel.DimmerOff”,
“displayStateValRaw”: 0,
“displayStateValUi”: “0”,
“enabled”: true,
“errorState”: ”“,
“folder”: {
“id”: 1552926800,
“name”: “Insteon”,
“globalProps”: {},
“greenLevel”: null,
“id”: 1508839119,
“lastChanged”: “2023-02-01T11:39:58”,
“lastSuccessfulComm”: “2023-02-01T11:39:58”,
“ledStates”: [],
“onState”: false,
“ownerProps”: {},
“pluginId”: ”“,
“pluginProps”: {},
“redLevel”: null,
“sharedProps”: {},
“states”: {
“brightnessLevel”: 0,
“onOffState”: false
“version”: 67,
“whiteLevel”: null,
</code>
=== Device Command Messages ===
=== indigo.device ===
<code json>
“message”: “indigo.device.statusRequest”,
</code>
<code json>
“parameters”: {
“delay”: 5,
“duration”: 10
</code>
<code json>
“message”: “indigo.device.turnOff”,
“parameters”: {
“delay”: 5,
“duration”: 10
</code>
<code json>
“message”: “indigo.device.turnOn”,
“parameters”: {
“delay”: 5,
“duration”: 10
</code>
<code json>
“message”: “indigo.device.lock”,
“parameters”: {
“delay”: 5,
“duration”: 10
</code>
<code json>
“message”: “indigo.device.unlock”,
“parameters”: {
“delay”: 5,
“duration”: 10
</code>
<code json>
“message”: “indigo.device.enable”,
“parameters”: {
“value”: True,
</code>
=== indigo.dimmer ===
<code json>
“message”: “indigo.dimmer.brighten”,
“parameters”: {
“by”: 5,
“delay”: 10
</code>
<code json>
“message”: “indigo.dimmer.dim”,
“parameters”: {
“by”: 5,
“delay”: 10
</code>
<code json>
“parameters”: {
“value”: 50,
“delay”: 10
</code>
=== indigo.iodevice ===
<code json>
“message”: “indigo.iodevice.setBinaryOutput”,
“parameters”: {
“index”: 5,
“value”: true
</code>
=== indigo.sensor ===
<code json>
“message”: “indigo.sensor.setOnState”,
“parameters”: {
“value”: true
</code>
=== indigo.speedcontrol ===
<code json>
“message”: “indigo.speedcontrol.decreaseSpeedIndex”,
“parameters”: {
“by”: 2,
“delay”: 5
</code>
<code json>
“message”: “indigo.speedcontrol.increaseSpeedIndex”,
“parameters”: {
“by”: 2,
“delay”: 5
</code>
<code json>
“message”: “indigo.speedcontrol.setSpeedIndex”,
“parameters”: {
“value”: 2,
“delay”: 5
</code>
set speed level indigo.speedcontrol.setSpeedLevel(123456789, value=50, value=True)
<code json>
“message”: “indigo.speedcontrol.setSpeedLevel”,
“parameters”: {
“value”: 50,
“delay”: 5
</code>
=== indigo.sprinkler ===
<code json>
“message”: “indigo.sprinkler.nextZone”,
</code>
<code json>
“message”: “indigo.sprinkler.pause”,
</code>
<code json>
“message”: “indigo.sprinkler.previousZone”,
</code>
<code json>
“message”: “indigo.sprinkler.resume”,
</code>
<code json>
“message”: “indigo.sprinkler.run”,
“parameters”: {
“schedule”: [10,15,8, 0, 0, 0, 0, 0]
</code>
<code json>
“message”: “indigo.sprinkler.stop”,
</code>
<code json>
“message”: “indigo.sprinkler.setActiveZone”,
“parameters”: {
“index”: 2
</code>
=== indigo.thermostat ===
<code json>
“message”: “indigo.thermostat.decreaseCoolSetpoint”,
“parameters”: {
“delta”: 2
</code>
<code json>
“message”: “indigo.thermostat.decreaseHeatSetpoint”,
“parameters”: {
“delta”: 2
</code>
<code json>
“message”: “indigo.thermostat.increaseCoolSetpoint”,
“parameters”: {
“delta”: 2
</code>
<code json>
“message”: “indigo.thermostat.increaseHeatSetpoint”,
“parameters”: {
“delta”: 2
</code>
<code json>
“message”: “indigo.thermostat.setCoolSetpoint”,
“parameters”: {
“value”: 76
</code>
<code json>
“message”: “indigo.thermostat.setFanMode”,
“parameters”: {
“value”: “indigo.kFanMode.AlwaysOn”
</code>
<code json>
“message”: “indigo.thermostat.setHeatSetpoint”,
“parameters”: {
“value”: 76
</code>
<code json>
“message”: “indigo.thermostat.setHvacMode”,
“parameters”: {
“value”: “indigo.kHvacMode.HeatCool”
</code>
==== Variable Messaging ====
=== Variable Objects ===
== Example variable object ==
<code json>
“description”: ”“,
“folderId”: 0,
“folder”: {},
“globalProps”: {
“id”: 345633244,
“pluginProps”: {},
“readOnly”: false,
“sharedProps”: {},
“value”: “home”
</code>
=== Variable Command Messages ===
<code json>
“parameters”: {
</code>
objectId is the id of the variable. The value parameter is required and must be a string. Pass an empty string (”“) to clear the variable value.
==== Action Group Messaging ====
=== Action Group Objects ===
== Example action group object ==
<code json>
“description”: ”“,
“folder”: {
“id”: 532526508,
“name”: “Mood Scenes”,
“globalProps”: {
“id”: 94914463,
“pluginProps”: {},
“sharedProps”: {
</code>
=== Action Group Command Messages ===
<code json>
</code>
==== Log Messages ====
=== Example Log Message ===
<code json>
“typeVal”: 0
</code>
<code python>
EVENT_TYPES = {
Application = 0,
Error = 1,
Error_Client = 2,
Warning = 3,
Warning_Client = 4,
Debug_Server = 5,
Debug_Client = 6,
Debug_Plugin = 7,
Custom = 8,
</code>
===== Plugin Messaging =====
===== Error Messaging =====
== Generic Error Message ==
<code json>
“error”: “Some error description”,
“id”: “the id sent from the client in the message, or null if there wasn't one”,
“validationErrors”: {
“field1”: “some error that occurred in the message with the key field1”
</code>
== Example API Call ==
<code json>
“id”: “a-random-id-for-this-message”,
“parameters”: {
“value”: 1234.56
</code>
== Resulting Error Message ==
<code json>
“value”: “variable values must be strings”
“error”: “invalid command payload received, id: my-set-var-command”,
</code>
- %%message%%,
- %%objectId%%,
- %%parameters%%, and
- %%value%%
=== Invalid JSON ===
== Example Invalid JSON Message ==
<code json>
“request_body”: “this is not valid JSON”,
“error”: “invalid JSON”
</code>
=== Web Server Warnings ===
