Integration APIs
his article is about the two APIs in IWS that developers can use to integrate Indigo with external services:
  • WebSocket API – (which the new Indigo Touch Web UI uses, and
NOTE:
  • /v2/ - this is the top level version number and will change as necessary
  "key1": "value 1",
  "key2": 2
PythonJSON Equivalent
True true
False false
float Number
int Number
None null
dict Object
list Array
tuple Array
str String
  • /v2/api/ws/device-feed - WebSocket to do all communication about devices
  • /v2/api/ws/variable-feed - WebSocket to do all communication about variables
  • /v2/api/ws/action-feed - WebSocket to do all communication about action groups
  • /v2/api/ws/page-feed - WebSocket to do all communication about control pages
  • /v2/api/ws/log-feed - WebSocket to do all communication about logs
WebSocket Lifecycle
  1. Setup:
Note the protocol: wss. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Don't share your API keys with anyone who is not authorized to use them — especially in posts to the Indigo user forums.
Python Receiver Example
import asyncio
import websockets
import json
API_KEY = 'YOUR-API-KEY'
async def receiver():
            while True:
    except Exception as exc:
        print(f"Exception:\n{exc}")
asyncio.run(receiver())
import asyncio
import json
async def receiver(ws):
        refresh_message = {
            "message": "refresh",
            "objectId": DEVICE_ID
        counter = 0
        device = {}
        while counter < 20:
            if message_type == "refresh":
            elif message_type == "patch":
            counter += 1
async def sender(ws, count):
        print("Starting sender task")
        message = {
        for count in range(10):
            msg = json.dumps(message)
            await asyncio.sleep(5)
async def main():
asyncio.run(main())
JavaScript Example
  console.log(message.data);
add device message
  "message": "add",
  objectDict": {
    "address": "3B.04.7A",
    "batteryLevel": null,
    "blueLevel": null,
    "brightness": 100,
    "buttonConfiguredCount": 0,
    "buttonGroupCount": 1,
    "configured": true,
    "defaultBrightness": 100,
    "deviceTypeId": "",
    "displayStateValRaw": 100,
    "displayStateValUi": "100",
    "enabled": true,
    "energyAccumBaseTime": null,
    "energyAccumTimeDelta": null,
    "energyAccumTotal": null,
    "energyCurLevel": null,
    "errorState": "",
    "folderId": 1552926800,
    "globalProps": {
      "emptyDict": {}
    "greenLevel": null,
    "id": 1508839119,
    "ledStates": [],
    "name": "Insteon Dimmer",
    "onBrightensToLast": false,
    "onState": true,
    "ownerProps": {},
    "pluginId": "",
    "pluginProps": {},
    "redLevel": null,
    "remoteDisplay": false,
    "sharedProps": {},
    "states": {
      "brightnessLevel": 100,
      "onOffState": true
    "subModel": "Plug-In",
    "subType": "Plug-In",
    "supportsAllOff": true,
    "supportsColor": false,
    "supportsOnState": true,
    "supportsRGB": false,
    "supportsWhite": false,
    "version": 67,
    "whiteLevel": null,
    "whiteLevel2": null,
    "whiteTemperature": null
update device message
  "message": "patch",
  "objectId": 1508839119,
  "patch": [
      "change",
      "brightness",
      [100, 0]
      "change",
      "displayStateImageSel",
      "change",
      "displayStateValRaw",
      [100,  0]
      "change",
      "displayStateValUi",
      ["100", "0"]
      "change",
      "lastChanged",
      "change",
      "lastSuccessfulComm",
      "change",
      "onState",
      [true, false]
      "change",
      "states.brightnessLevel",
      [100, 0]
      "change",
      "states.onOffState",
      [true, false]
device refresh messages
  "list": []
  "objectDict": {}
delete device message
  "message": "delete",
  "objectId": 123456789
Device messages to the server
device refresh requests
  // Specify the object type
device command messages
  "objectId": 123456789,
  "class": "indigo.Variable",
  "description": "",
  "folderId": 0,
  "globalProps": {
  "id": 345633244,
  "name": "house_status",
  "pluginProps": {},
  "readOnly": false,
  "remoteDisplay": true,
  "sharedProps": {},
  "value": "home"
add variable message
  "message": "add",
update variable message
delete variable message
variable refresh messages
variable command messages
updateValue
  "parameters": {
    "value": "Some string value"
  "description": "",
  "folderId": 532526508,
  "globalProps": {
      "speakDelayTime": "5",
  "id": 94914463,
  "name": "Movie Night",
  "pluginProps": {},
  "sharedProps": {
add action group message
  "message": "add",
update action group message
delete action group message
action group refresh messages
action group command messages
  "backgroundImage": "",
  "description": "",
  "folderId": 0,
  "globalProps": {},
  "hideTabBar": true,
  "id": 963336187,
  "name": "Weather Images",
  "pluginProps": {},
  "sharedProps": {}
add control page message
  "message": "add",
update control page message
delete control page message
  "id": 617272302,
  "class": "indigo.Folder",
  "name": "My Device Folder",
refresh folder server message
  "message": "add",
  "objectDict": {
    "message": "Stopping plugin \"Web Server 2023.1.0\" (pid 1020)",
    "typeStr": "Application",
    "typeVal": 0
  • /v2/api/indigo.devices - endpoint to get a list of devices
  • /v2/api/indigo.devices/123456789 - endpoint to get a specific device instance (See Device Objects below)
  • /v2/api/indigo.variables - endpoint to get a list of variables
  • /v2/api/indigo.variables/123456789 - endpoint to specific variable object (See Variable Objects below)
  • /v2/api/indigo.actionGroups - endpoint to get a list of action groups
  • /v2/api/indigo.actionGroups/123456789 - endpoint to get a specific action group (See Action Group Objects below)
  • /v2/api/command - endpoint to send Indigo a command (device control, variable update, action execution).
Getting All Device Objects
import json
with urlopen(req) as request:
    print(device_list)
const http = require("https")
const options = {
  headers: {
  let result = ""
    result += chunk;
  response.on("end", () => {
    console.log(deviceList);
import json
DEVICEID = 123456789
    print(device_instance)
const DEVICEID = 123456789
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(deviceInstance);
Controlling an Indigo Device
import json
message = json.dumps({
    "objectId": DEVICEID
}).encode("utf8")
    reply = json.load(request)
    print(reply)
const options = {
  path: "/v2/api/command",
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
import json
  "objectId": DEVICEID,
  "parameters": {
    "value": 50,
    "delay": 10
}).encode("utf8")
    print(reply)
  "parameters": {
    "value": 50,
    "delay": 10
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
Getting All Variable Objects
import json
    print(variable_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(VariableList);
import json
    print(var_instance)
const VARID = 123456789
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(varInstance);
Updating a Variable's Value
import json
VARIABLEID = 123456789
  "objectId": VARIABLEID,
  "parameters": {
}).encode("utf8")
    print(reply)
const VARIABLEID = 123456789
  "parameters": {
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
import json
    print(action_group_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(actionGroupList);
Executing an Action Group
import json
ACTIONGROUPID = 123456789
  "objectId": ACTIONGROUPID
}).encode("utf8")
    print(reply)
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
Device Objects
Example device object
  "blueLevel": null,
  "brightness": 0,
  "configured": true,
  "deviceTypeId": "",
  "displayStateValRaw": 0,
  "displayStateValUi": "0",
  "enabled": true,
  "errorState": "",
  "folder": {
    "id": 1552926800,
    "name": "Insteon",
  "globalProps": {},
  "greenLevel": null,
  "id": 1508839119,
  "ledStates": [],
  "onState": false,
  "ownerProps": {},
  "pluginId": "",
  "pluginProps": {},
  "redLevel": null,
  "sharedProps": {},
  "states": {
    "brightnessLevel": 0,
    "onOffState": false
  "version": 67,
  "whiteLevel": null,
indigo.device
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "value": True,
indigo.dimmer
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "value": 50,
    "delay": 10
indigo.iodevice
  "parameters": {
    "index": 5,
    "value": true
indigo.sensor
  "parameters": {
    "value": true
indigo.speedcontrol
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "value": 2,
    "delay": 5
set speed level indigo.speedcontrol.setSpeedLevel(123456789, value=50, value=True)
  "parameters": {
    "value": 50,
    "delay": 5
indigo.sprinkler
  "parameters": {
    "schedule": [10,15,8, 0, 0, 0, 0, 0]
  "parameters": {
    "index": 2
indigo.thermostat
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "value": 76
  "parameters": {
  "parameters": {
    "value": 76
  "parameters": {
Variable Objects
  "description": "",
  "folderId": 0,
  "folder": {},
  "globalProps": {
  "id": 345633244,
  "pluginProps": {},
  "readOnly": false,
  "sharedProps": {},
  "value": "home"
  "parameters": {
  "description": "",
  "folder": {
    "id": 532526508,
    "name": "Mood Scenes",
  "globalProps": {
  "id": 94914463,
  "pluginProps": {},
  "sharedProps": {
Example Log Message
  "typeVal": 0
EVENT_TYPES = {
  Application = 0,
  Error = 1,
  Error_Client = 2,
  Warning = 3,
  Warning_Client = 4,
  Debug_Server = 5,
  Debug_Client = 6,
  Debug_Plugin = 7,
  Custom = 8,
Generic Error Message
  "validationErrors": {
Example API Call
  "parameters": {
    "value": 1234.56
Resulting Error Message
  1. message,
  2. objectId,
  3. parameters, and
  4. value
Invalid JSON
Example Invalid JSON Message
  "error": "invalid JSON"
Web Server Warnings
Code Condition Description
200 OK or Success Indicates that the request has succeeded.
400 Bad Request Indicates that the server cannot or will not process the request due to something that is perceived to be a client error (for example, malformed request syntax, invalid request message framing, or deceptive request routing)
401 Unauthorized Indicates that the client request has not been completed because it lacks valid authentication credentials for the requested resource.
404 Not Found Indicates that the server cannot find the requested resource.
500 Internal Server Error Indicates that the server encountered an unexpected condition that prevented it from fulfilling the request.
  • /www/perceptive/wiki/data/pages/indigo_2023.1_documentation/api.txt
