apiVersion string No API v1.7: the currently connected Indigo Server plugin API version as a string (ex: “1.7”)
connectionGood boolean No true if the connection to the Indigo Server is currently good
portNum integer No the port number of the currently connected Indigo Server
License Status Enumeration
Value Description
ActiveSubscription license has an active Indigo Up-to-Date subscription (access to a reflector)
Broadcast to Subscribers
Calculate Sunrise
Calculate Sunset
Event Log List
showTimeStamp No boolean indicate whether every line should have it’s timestamp prepended to the log entry - the default is true
Get Database File Name
Get Database File Path
Get Deprecated Elements
Returns the server's list of elements that have attributes orproperties that are now deprecated.
Get Install Folder Path
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
Get Plugin
Get Plugin List
Get Reflector URL
Get Serial Ports
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Get Web Server URL
  1. Reflector (https://reflector.indigodomo.net) if a reflector is configured.
  2. Bonjour name (http://MacName.local:PORT) if it can be determined.
  3. Localhost (http://localhost:PORT) if all else fails.
No Parameters
Log
Remove All Delayed Actions
Restart Plugin
Save Plugin Preferences
Send Email
Speak
Stop Plugin
Tell the server to shutdown our plugin process. Plugin will remain enabled but be in a stopped state. This command can only be called from a plugin and it refers to the plugin itself (not all plugins).
Subscribe To Log Broadcasts
indigo.server.subscribeToLogBroadcasts()
Wait Until Idle
indigo.server.waitUntilIdle()
indigo_2023.1_documentation/server_commands.txt · Last modified: 2023/09/15 14:15 by davel17
