Getting Started Guide
Welcome to Indigo 2023.2!
- Mac OS X 10.12 or higher
Z-Wave
- Thermostats, and
- Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2023.2 application can be found here:
/Applications/Indigo 2023.2.app
/Library/Application Support/Perceptive Automation/Indigo 2023.2/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2023.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
Indigo plugins can now run under Python 3. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
Indigo 2023.2→License Details…menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 2023.2/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2023.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
- manually remove the
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2023.2→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2023.2 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 2023.2/~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist- Optional : If you don't use Python 3.11 for anything (other than Indigo 2023.2), you can delete this folder:
Uninstalling the Mac Client
/Applications/Indigo 2023.2.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2023-2.plist~(your user folder)/Library/Preferences/Indigo 2023.2 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 2023.2 Client Settings.indiPref
To uninstall older versions but leave 2023.2 installed correctly, delete these:
- Indigo 2023.1:
- Indigo 2022.2:
- Indigo 2022.1:
- Indigo 2021.2:
- Indigo 2021.1:
- Indigo 7.5:
- Indigo 7.4:
- Indigo 7.3:
- Indigo 7.2:
- Indigo 7.0 and 7.1:
Starting Indigo Server
- Double click the
Indigo 2023.2application (/Applications/Indigo 2023.2.app). - If this is the first time to run
Indigo 2023.2on this Mac, then press theStart Local Server…button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2023.2→Start Local Server…menu item.
Standard startup mode
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2023.2application (inside/Applications/Indigo 2023.2.app) on the remote Mac. - If this is the first time to run
Indigo 2023.2→Connect to Remote Server…menu item. - Enter the
Connectbutton.
Indigo Touch, the iPhone and iPod Touch application from Indigo Domotics, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages. One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings button. You should see the name of your Database in the list. Tap on it, and it will connect (it will ask for your username/password if you have one set, but it will remember it going forward so you won't have to type it in again).
http://192.168.1.23:8176/
Managing Plugins
Installing/Updating Plugins
- Click the
Download Latest Releasebutton, which will download the plugin. If the release isn't compatible with your version of Indigo, you can click on the Releases tab, and look through the list for a version that works with your version of Indigo (click on it and then click theDownload this releaselink). - Most plugins will show the plugin directly as the above image. If it does, double click it and proceed to step 8 below.
. You will see a different dialog if the version number is lower than an already-installed version; for safety, Indigo will ask you to confirm that you want to downgrade the plugin. - NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the
Open Withmenu item, then select Indigo 2023.2.
- Click the
Plugin Menus in Indigo
Main Plugins Menu
Individual Plugin Submenu
The next section contains:
- the
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2023.2→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
- the
Uninstalling a Plugin
Indigo 2023.2→Stop Servermenu item in the Mac client (you can leave the client app running). - In the Finder window opened in step 1, you'll see two folders:
PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. Check to make sure that somehow there aren't plugins in both locations. - Switch back to the Indigo 2023.2 Mac client and click on the
- Choose
Date & Timeicon. - Select the
- Choose the
Indigo 2023.2→Preferences…menu item, then make sure theSunset & Sunrisetab is selected. - Select the
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2023.2→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2023.2→Check for Updates… menu item.
- Choose
Energy Savericon. - Move the
Where to Go Next
