Getting Started Guide
Z-Wave
  • Thermostats, and
  • Locks.
INSTEON
X10
Other Devices
The Indigo 2023.2 application can be found here:
  /Applications/Indigo 2023.2.app
  /Library/Application Support/Perceptive Automation/Indigo 2023.2/
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2023.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
Indigo plugins can now run under Python 3. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
  1. Deactivate Indigo on your Mac by selecting the Indigo 2023.2→License Details… menu item and clicking the Deactivate License button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)
  2. Copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 2023.2/ (if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
  3. Install Indigo 2023.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2023.2→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2023.2 menu if the server is still running before you quit the Indigo Mac Client).
  • Optional : If you don't use Python 3.11 for anything (other than Indigo 2023.2), you can delete this folder: /Library/Frameworks/Python.framework/Versions/3.11 and this file: /Library/Frameworks/Python.framework/Versions/Current Note: this will leave any other version of Python alone including any previous versions that older Indigo installs may have installed (if you plan on reverting to an older version). To completely remove all Python installations that any version of Indigo may have installed, just delete the entire Python framework: /Library/Frameworks/Python.framework
  • ~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2023-2.plist
  • ~(your user folder)/Library/Preferences/Indigo 2023.2 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 2023.2 Client Settings.indiPref
To uninstall older versions but leave 2023.2 installed correctly, delete these:
  • Indigo 2023.1:
  • Indigo 2022.2:
  • Indigo 2022.1:
  • Indigo 2021.2:
  • Indigo 2021.1:
  • Indigo 7.5:
  • Indigo 7.4:
  • Indigo 7.3:
  • Indigo 7.2:
  • Indigo 7.0 and 7.1:
    • /Applications/Indigo 7.app
    • /Applications/Indigo 6.app
  1. Double click the Indigo 2023.2 application (/Applications/Indigo 2023.2.app).
  2. If this is the first time to run Indigo 2023.2 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 2023.2→Start Local Server… menu item.
  2. Double click the Indigo 2023.2 application (inside /Applications/Indigo 2023.2.app) on the remote Mac.
  4. If you are wanting to connect to a different Indigo Server, then select the Indigo 2023.2→Connect to Remote Server… menu item.
  7. Press the Connect button.
Indigo Touch, the iPhone and iPod Touch application from Indigo Domotics, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages. One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings button. You should see the name of your Database in the list. Tap on it, and it will connect (it will ask for your username/password if you have one set, but it will remember it going forward so you won't have to type it in again).
 http://192.168.1.23:8176/
  1. In Safari on your Indigo Server Mac, go to the Plugin Store and navigate to the Plugin you want to install.
  4. When the download is complete, click on the down arrow in the title bar which will show the plugin download.
  8. You will be switched to the Indigo Client app, and you'll a dialog window which asks you if you want to install and enable the plugin . You will see a different dialog if the version number is lower than an already-installed version; for safety, Indigo will ask you to confirm that you want to downgrade the plugin.
  9. NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the Open With menu item, then select Indigo 2023.2.
  11. Done!
Main Plugins Menu
  • a gray dot means the plugin is disabled
  • a green dot with no arrows means the plugin is enabled and up to date.
  • a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version
  • a green dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
  • a yellow dot with no arrows means the plugin is enabled but needs updating before the next Indigo release
  • a yellow dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version - you should install the update before upgrading to the next version of Indigo
  • a yellow dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
  • the plugin is not compatible with your version of Indigo and we are not aware of a version that will work with your version of Indigo.
  • the plugin has failed due to a catastrophic error that has caused the plugin to crash or has caused Indigo to stop the plugin. An error will be output to the log to explain the problem.
  • the plugin's self.stopPlugin() method has been called for any reason.
Individual Plugin Submenu
The next section contains:
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2023.2→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
  2. Switch back to Indigo and shut down the Indigo Server by selecting the Indigo 2023.2→Stop Server menu item in the Mac client (you can leave the client app running).
  4. Switch back to the Indigo 2023.2 Mac client and click on the Start Local Server… button in the Server Connection Status dialog.
  • Choose the Indigo 2023.2→Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2023.2→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2023.2→Check for Updates… menu item.
  • /www/perceptive/wiki/data/attic/indigo_2023.2_documentation/getting_started.1722889310.txt.gz
  • Last modified: 2024/08/05 20:21
