Indigo Plugins and APIs
in this location:
The Indigo Plugin Bundle
The Info.plist File
<plist version="1.0">
<dict>
<key>PluginVersion</key>
<string>1.2.3</string>
<key>ServerApiVersion</key>
<string>2.0</string>
<key>CFBundleIdentifier</key>
<key>CFBundleVersion</key>
<string>1.0.1</string>
<key>CFBundleURLTypes</key>
<array>
<dict>
<key>CFBundleURLName</key>
</dict>
</array>
</dict>
</plist>
PluginVersion(Plugin version) - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it. If the version number is a higher version, Indigo will notify the user that the plugin will be installed and enabled. If the version number is lower than an already-installed version, Indigo will prompt the user to confirm that they want to downgrade the plugin. The version number is also used in version checking, and may eventually be used for automatic updates.ServerApiVersion(Server API version) - this value refers to the minimum server API version your plugin requires. In other words, if your plugin requires server API version 3.0, users must be running Indigo 2022.1.0 or later (the first Indigo version that supports server API version 3.0). Otherwise, Indigo will not allow the plugin to be installed. In rare circumstances, a new server API version may deprecate prior functions, so it's best to review the API Version Chart as new API versions are released.CFBundleDisplayName(Bundle display name) - this is a standard macOS key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.CFBundleName(Bundle name) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.CFBundleIdentifier(Bundle identifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use thecom.yourorgidentifier.*namespace. This key is required.CFBundleVersion(Bundle version) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us. This key is required.CFBundleURLTypes(URL types) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
Menu Items Folder
Resources Folder
Packages Folder
Indigo Server Plugins
Indigo Plugin Host
Plugin Failure Handling
Server Plugin Folder
Indigo Plugin XML Conventions
- cannot contain spaces.
Configuration Dialogs
<ConfigUI>
<Field id="autoLabel"
type="label"
visibleBindingValue="false">
</Field>
<Field id="exampleButton"
type="button"
<Title>Find Node ID</Title>
</Field>
<Field id="nodeID"
type="textfield"
readonly="YES"
<Label>Node ID:</Label>
</Field>
<Field type="checkbox"
id="manualEntry"
defaultValue="false">
</Field>
<Field id="manualNodeID"
type="textfield"
visibleBindingValue="true">
<Label>Enter Node ID:</Label>
</Field>
</ConfigUI>
Text Field
<Label>Text Field:</Label>
</Field>
Popup Menu
return valuesDict
List
Dynamic Lists
Dynamic List Filters
Class: indigo.devices |
Class: indigo.triggers |
return myArray
Serial Port
Checkbox
return valuesDict
Label
Separator
Button
The process flow is this:
<Name>Music Server</Name>
<ConfigUI>
<Title>Begin Pairing</Title>
</Field>
<!-- SNIP -->
</Device>
return valuesDict
Validation Methods
return True
return (True, valuesDict)
errorDict = indigo.Dict()
Validating serialport Fields
errorsDict = indigo.Dict()
if len(errorsDict) > 0:
Dialog Close Notification
PluginConfig.xml
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Preferences/Plugins/
Custom HTML Config Dialogs
Devices.xml
Device Types
<ConfigUI>
</Field>
</ConfigUI>
<State id="temperature">
</Device>
Device Sub-Types
In Devices.xml
In Python:
Custom Device Type
<ValueType>Number</ValueType>
<State id="heatSetPoint">
<State id="coolSetPoint">
<State id="mode">
Device Factory
Events.xml
<Events>
<Event id="updateAvailable">
</Event>
</Events>
<Event id="sep1"/>
Actions.xml
<Actions>
<Action id="resetInterface">
<Name>Reset Interface</Name>
</Action>
</Actions>
</Field>
<Action id="sep1"/>
configured : True
config_prop_1 : 123 (integer)
config_prop_2 : true (bool)
textToSpeak :
def writeToLog(self, action):
if theType:
indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
- None
None, - booleans
bool, - integers
int(), - floats
float(), - strings
str(), - Indigo Dicts
indigo.Dict(), - Indigo Lists
indigo.List().
return some_value
completeHandler = None
# called from another thread.
# via:
except Exception, exc:
MenuItems.xml
<MenuItems>
<MenuItem id="menu1">
</MenuItem>
<MenuItem id="menu2">
</MenuItem>
<MenuItem id="menu3">
<ConfigUI>
<Label>Light:</Label>
</Field>
</ConfigUI>
</MenuItem>
<!-- Added in v1.2 -->
<MenuItem id="menu4">
</MenuItem>
</MenuItems>
def checkForUpdates(self):
menu_items = indigo.Dict()
if menu_id == "my_menu_id":
return menu_items
Custom HTML Menu Item Dialogs
You can also implement your own custom menu item form in HTML if you prefer. Rather than adding <CallbackMethod> and <ConfigUI> definitions, you simply specify a <URL> element. The URL specified can either be a fully specified URL (%%protocol://host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example.
SupportURL Elements
plugin.py
General Plugin Methods
__init__(self,
pluginId,
pluginDisplayName,
pluginVersion,
pluginPrefs)
You'll most likely use the |
Beginning with Indigo 2023.2, the |
Note: |
while True:
# Do your stuff here
self.sleep(60) # in seconds
except self.StopThread:
# do any cleanup here
pass
You must call |
self.stopThread = True
getDeviceStateList(self,
dev)
getDeviceDisplayStateId(self,
dev)
deviceStartComm(self,
dev)
deviceStopComm(self,
dev)
origDev,
newDev)
deviceUpdated(self,
origDev,
newDev)
deviceDeleted(self,
dev)
triggerStartProcessing(self,
trigger)
triggerStopProcessing(self,
trigger)
origTrigger,
newTrigger)
triggerCreated(self,
trigger)
triggerUpdated(self,
origTrigger,
newTrigger)
triggerDeleted(self,
trigger)
| Name | Required | Notes |
Helper Methods
bundleID)
browserOpen(self,
url)
debugLog(self,
msg)
errorLog(self,
msg)
openSerial(self,
ownerName,
portUrl, baudrate, bytesize,
parity, stopbits, timeout,
dsrdtr, interCharTimeout)
sleep(self,
seconds)
substituteVariable(self,
inString,
validateOnly=False)
substituteDeviceState(self,
inString,
validateOnly=False)
substitute(self,
inString,
validateOnly=False)
Properties
Logging
| Attribute | Description |
self.indigo_log_handler
self.plugin_file_handler
Log Levels
class MyClass(object):
def __init__():
Custom IndigoLogHandler
exc_info
x = 1 / 0
Full Example
import logging
def __init__(self):
x = 1 / 0
except ZeroDivisionError:
Which yields:
x = 1 / 0
import logging
?other=args&api-key=KEYHERE)
Request
<Name>some message</Name>
</Action>
return some_value
| Key | Value |
file_path | this will be a list of path parts from the URL after the action ID. So for the url: %%http://host/message/pluginid/actionid/path/to/some/file.txt%% the value will be an indigo.List with the following items: %%[“path”, “to”, “some”, “file.txt”]%% |
Reply
| Key | Value |
Errors
| Status | Meaning |
| Key | Value |
Usage Guidance
- Binary data - this release of the API isn't designed for binary data
Event and Message Flow
###### TURN ON ######
if send_success:
###### TURN OFF ######
if send_success:
###### STATUS REQUEST ######
Plugin Preferences File
3rd Party Python Libraries
Indigo 2023.2 includes a variety of popular 3rd party Python libraries which are described on the Python Packages page. Any changes to the libraries installed will be detailed there. You should not make changes to the packages that Indigo installs. If you need a different package version, you should include it within your plugin package distribution.
