Indigo Plugins and APIs
in this location:
The Indigo Plugin Bundle
The Info.plist File
<plist version="1.0">
<dict>
<key>PluginVersion</key>
<string>1.2.3</string>
<key>ServerApiVersion</key>
<string>2.0</string>
<key>CFBundleIdentifier</key>
<key>CFBundleVersion</key>
<string>1.0.1</string>
<key>CFBundleURLTypes</key>
<array>
<dict>
<key>CFBundleURLName</key>
</dict>
</array>
</dict>
</plist>
PluginVersion(Plugin version) - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it. If the version number is a higher version, Indigo will notify the user that the plugin will be installed and enabled. If the version number is lower than an already-installed version, Indigo will prompt the user to confirm that they want to downgrade the plugin. The version number is also used in version checking, and may eventually be used for automatic updates.ServerApiVersion(Server API version) - this value refers to the minimum server API version your plugin requires. In other words, if your plugin requires server API version 3.0, users must be running Indigo 2022.1.0 or later (the first Indigo version that supports server API version 3.0). Otherwise, Indigo will not allow the plugin to be installed. In rare circumstances, a new server API version may deprecate prior functions, so it's best to review the API Version Chart as new API versions are released.CFBundleDisplayName(Bundle display name) - this is a standard macOS key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.CFBundleName(Bundle name) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.CFBundleIdentifier(Bundle identifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use thecom.yourorgidentifier.*namespace. This key is required.CFBundleVersion(Bundle version) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us. This key is required.CFBundleURLTypes(URL types) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's Github repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
Menu Items Folder
Resources Folder
Packages Folder
Indigo Server Plugins
Indigo Plugin Host
Plugin Failure Handling
Server Plugin Folder
Indigo Plugin XML Conventions
- cannot contain spaces.
Configuration Dialogs
<ConfigUI>
<Field id="autoLabel"
type="label"
visibleBindingValue="false">
</Field>
<Field id="exampleButton"
type="button"
<Title>Find Node ID</Title>
</Field>
<Field id="nodeID"
type="textfield"
readonly="YES"
<Label>Node ID:</Label>
</Field>
<Field type="checkbox"
id="manualEntry"
defaultValue="false">
</Field>
<Field id="manualNodeID"
type="textfield"
visibleBindingValue="true">
<Label>Enter Node ID:</Label>
</Field>
</ConfigUI>
Text Field
<Label>Text Field:</Label>
</Field>
Popup Menu
return valuesDict
List
Dynamic Lists
Dynamic List Filters
Class: indigo.devices |
Class: indigo.triggers |
return myArray
Serial Port
Checkbox
return valuesDict
Label
Separator
Button
The process flow is this:
<Name>Music Server</Name>
<ConfigUI>
<Title>Begin Pairing</Title>
</Field>
<!-- SNIP -->
</Device>
return valuesDict
Validation Methods
return True
return (True, valuesDict)
errorDict = indigo.Dict()
Validating serialport Fields
errorsDict = indigo.Dict()
if len(errorsDict) > 0:
Dialog Close Notification
PluginConfig.xml
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Preferences/Plugins/
Custom HTML Config Dialogs
Devices.xml
Device Types
<ConfigUI>
</Field>
</ConfigUI>
<State id="temperature">
</Device>
Device Sub-Types
In Devices.xml
In Python:
Custom Device Type
<ValueType>Number</ValueType>
<State id="heatSetPoint">
<State id="coolSetPoint">
<State id="mode">
Device Factory
Events.xml
<Events>
<Event id="updateAvailable">
</Event>
</Events>
<Event id="sep1"/>
Actions.xml
<Actions>
<Action id="resetInterface">
<Name>Reset Interface</Name>
</Action>
</Actions>
</Field>
<Action id="sep1"/>
configured : True
config_prop_1 : 123 (integer)
config_prop_2 : true (bool)
textToSpeak :
def writeToLog(self, action):
if theType:
indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
- None
None, - booleans
bool, - integers
int(), - floats
float(), - strings
str(), - Indigo Dicts
indigo.Dict(), - Indigo Lists
indigo.List().
return some_value
completeHandler = None
# called from another thread.
# via:
except Exception, exc:
MenuItems.xml
<MenuItems>
<MenuItem id="menu1">
</MenuItem>
<MenuItem id="menu2">
</MenuItem>
<MenuItem id="menu3">
<ConfigUI>
<Label>Light:</Label>
</Field>
</ConfigUI>
</MenuItem>
<!-- Added in v1.2 -->
<MenuItem id="menu4">
</MenuItem>
</MenuItems>
def checkForUpdates(self):
menu_items = indigo.Dict()
if menu_id == "my_menu_id":
return menu_items
Custom HTML Menu Item Dialogs
You can also implement your own custom menu item form in HTML if you prefer. Rather than adding <CallbackMethod> and <ConfigUI> definitions, you simply specify a <URL> element. The URL specified can either be a fully specified URL (%%protocol:host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example.
==== SupportURL Elements ====
==== plugin.py ====
<code>class Plugin(indigo.PluginBase):</code>
=== General Plugin Methods ===
^ Method definition ^ Required ^ Notes ^
|<code>init(self,
pluginId,
pluginDisplayName,
pluginVersion,
pluginPrefs)</code>| Yes |This method gets a dictionary of preferences that the server read from disk. You have the opportunity here to use them or alter them if you like although you most likely will just pass them on to the plugin base class:
<code>def init(self, pluginPrefs):
indigo.PluginBase.init(self, pluginPrefs)</code> You'll most likely use the startup method, described below, to do your global plugin initialization.|
|<code>del(self)</code>| Yes |This is the destructor for the class. Again, you’ll probably just call the super class’s method:
<code>def del(self):
indigo.PluginBase.del(self)</code>|
|<code>startup(self)</code>| No |This method will get called after your plugin has been initialized. This is really the place where you want to make sure that everything your plugin needs to do gets set up correctly. It’s passed no parameters. If you’re storing a config parameter that’s not editable by the user, this is a good place to make sure it’s there and set to the right value. This is not, however, where you want to initialize devices and triggers that your plugin may provide - those are handled after this method completes (see the methods below).
<code>def startup(self):
indigo.server.log(u”Startup called”)</code> Beginning with Indigo 2023.2, the startup method supports a return value:<html><br></html>- don't return anything (or return None explicitly) - your plugin will start up<html><br></html>- return True - your plugin will start up<html><br></html>- return False - your plugin stops with a default message <html><br></html>- return a string - your plugin stops with that string as the message<html><br></html>- return anything else - plugin stops with a default message|
|<code>shutdown(self)</code>| No |This method will get called when the IndigoServer wants your plugin to exit. If you define a global shutdown variable, this is the place to set it. Other things you might do in this method: if your plugin uses a single interface to talk to multiple devices, this is the place where you would want to shut down that interface (close the serial port or network connection, etc). Each device and trigger will already have had a chance to shutdown by the time this method is called (see the methods below).
<code>def shutdown(self):
# do any cleanup necessary before exiting</code> Note: shutdown will be called after runConcurrentThread (discussed next) so cleanup here will be after any changes that might result from a loop in runConcurrentThread.|
|<code>runConcurrentThread(self)</code>| No |This method is called in a newly created thread after the startup() method finishes executing. It’s expected that it should run a loop continuously until asked to shutdown.
<code>def runConcurrentThread(self):
while True:
# Do your stuff here
self.sleep(60) # in seconds
except self.StopThread:
# do any cleanup here
pass</code> You must call self.sleep() with the number of seconds to delay between loops. self.sleep() will raise an self.StopThread exception when you should end runConcurrentThread. You don’t have to catch that exception if you don’t need to do any cleanup before returning - it will just throw out to the next level. Note: shutdown will be called after runConcurrentThread finishes processing so you can do your cleanup there.|
|<code>stopConcurrentThread(self)</code>| No |This method will get called when the IndigoServer wants your plugin to stop any threads that it may have created. The default implementation (below) will set the stopThread instance variable which causes the self.sleep() method to throw the exception that you handle in runConcurrentThread above. In most circumstances, your plugin won't need to implement this method.
<code>def stopConcurrentThread(self):
self.stopThread = True</code>|
|<code>prepareToSleep(self)</code>| No |The default implementation of this method will call deviceStopComm() for each device instance and triggerStopProcessing() for each trigger instance provided by your plugin. You can of course override them to do anything you like. |
|<code>wakeUp(self)</code>| No |The default implementation of this method will call deviceStartComm() for each device instance and triggerStartProcessing() for each trigger instance provided by your plugin. You can of course override them to do anything you like. |
^ Device Specific Methods ^^^
|<code>getDeviceStateList(self,
dev)</code>| No |If your plugin defines custom devices, this method will be called by the server when it tries to build the state list for your device. The default implementation just returns the <States> element (reformatted as an indigo.List() that's available to your plugin via devicesTypeDict[“yourCustomTypeIdHere”]) in your Devices.xml file. You can, however, implement the method yourself to return a custom set of states. For instance, you may want to allow the user to create custom labels for the various inputs on your device rather than use generic “Input 1”, “Input 2”, etc., labels. Check out the EasyDAQ plugin for an example.|
|<code>getDeviceDisplayStateId(self,
dev)</code>| No |If your plugin defines custom devices, this method will be called by the server to determine which device state ID to display in the device list UI state column. The default implementation just returns the <UiDisplayStateId> element in your Devices.xml file. You can, however, implement the method the plugin needs to dynamically determine the which state ID to display.|
|<code>deviceStartComm(self,
dev)</code>| No |If your plugin defines devices, this is likely the place where you'll want to do the work of starting your device up. For instance, let's say that you have a device somewhere out on the network - the easiest way to “start” your device is to implement this method. You would open the network addrss:port (that's defined in dev.pluginProps), get it's current state(s) and tell the IndigoServer to set those states (using the dev.updateStateOnServer() method).|
|<code>deviceStopComm(self,
dev)</code>| No |This is the complementary method to deviceStartComm() - it gets called when the device should no longer be active/enabled. For instance, when the user disables or deletes a device, this method gets called.|
|<code>didDeviceCommPropertyChange(self,
origDev,
newDev)</code>| No |This method gets called by the default implementation of deviceUpdated() to determine if any of the properties needed for device communication (or any other change requires a device to be stopped and restarted). The default implementation checks for any changes to properties. You can implement your own to provide more granular results. For instance, if your device requires 4 parameters, but only 2 of those parameters requires that you restart the device, then you can check to see if either of those changed. If they didn't then you can just return False and your device won't be restarted (via deviceStopComm()/deviceStartComm() calls).|
|<code>deviceUpdated(self,
origDev,
newDev)</code>| No |Complementary to the deviceCreated() method described above, but signals device updates. You'll get a copy of the old device object as well as the new device object. The default implementation of this method will do a few things for you: if either the old or new device are devices defined by you, and if the device type changed OR the communication-related properties have changed (as defined by the didDeviceCommPropertyChange() method - see above for details) then deviceStopComm() and deviceStartComm() methods will be called as necessary (stop only if the device changed to a type that isn't your device, start only if the device changed to a type that belongs to you, or both if the props/type changed and they both both belong to you).|
|<code>deviceDeleted(self,
dev)</code>| No |Complementary to the deviceCreated() method described above, but signals device deletes. The default implementation just checks to see if the device belongs to your plugin and if so calls the deviceStopComm() method. If you implement this method you'll need to call deviceStopComm() yourself or duplicate the functionality here.|
^ Trigger Specific Methods ^^^
|<code>triggerStartProcessing(self,
trigger)</code>| No |If your plugin defines events, this is likely the place where you'll want to do the work to start watching for those events to occur. For instance, let's say that you have an event for a plugin update, then you'll want to periodically check your site to see if there's a new version available. This is where you'd start that process. When conditions are met in your plugin for a trigger to be executed, you would call indigo.trigger.execute(triggerReference) to tell the Server to execute the trigger (and it's conditions).|
|<code>triggerStopProcessing(self,
trigger)</code>| No |This is the complementary method to triggerStartProcessing() - it gets called when the event should no longer be active/enabled. For instance, when the user disables or deletes a trigger, this method gets called.|
|<code>didTriggerProcessingPropertyChange(self,
origTrigger,
newTrigger)</code>| No |Much like it's device counterpart above (didDeviceCommPropertyChange()), this method gets called by the default implementation of triggerUpdated() to determine if any of the properties needed for recognizing an event have changed. The default implementation checks for any changes to any properties.|
|<code>triggerCreated(self,
trigger)</code>| No |This method will get called whenever a new trigger defined by your plugin is created. In many circumstances, you won't need to implement this method since the default behavior (which is to call the triggerStartProcessing() method if it's your trigger and it's enabled) is what you want anyway (see the triggerStartProcessing() method above for details). However, if for some reason you need to know when a trigger is created, but before your plugin is asked to start watching for the appropriate conditions, this method can provide that hook. If you implement this method, you'll need to either call triggerStartProcessing() or duplicate the functionality here.
You can also have this method called for triggers that don't belong to your plugin. If, for instance, you want to know when all triggers are created (and updated/deleted), you can call the indigo.triggers.subscribeToChanges() method to have the IndigoServer send all trigger creation/update/deletion notifications. As with other change subscriptions, this should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer.|
|<code>triggerUpdated(self,
origTrigger,
newTrigger)</code>| No |Complementary to the triggerCreated() method described above, but signals trigger updates. You'll get a copy of the old trigger object as well as the new trigger object. The default implementation of this method will do a few things for you: if either the old or new trigger are triggers defined by you, and if the trigger type changed OR the communication-related properties have changed (as defined by the didTriggerProcessingPropertyChange() method - see above for details) then triggerStopProcessing() and triggerStartProcessing() methods will be called as necessary.|
|<code>triggerDeleted(self,
trigger)</code>| No |Complementary to the triggerCreated() method described above, but signals trigger deletes. The default implementation just checks to see if the trigger belongs to your plugin and if so calls the triggerStopProcessing() method. If you implement this method you'll need to call triggerStopProcessing() yourself or duplicate the functionality here.|
^ Schedule Specific Methods ^^^
| add schedule documentation when it is complete (not currently available)|||
^ Action Group Specific Methods ^^^
^ Name ^ Required ^ Notes ^
add action group documentation when it is complete (not currently available)|||
^ Variable Specific Methods ^^^
|<code>variableCreated(self, var)</code>| No |This method will get called whenever a new variable is created. You can call the
indigo.variables.subscribeToChanges() method to have the IndigoServer send all variable creation/update/deletion notifications. As with other change subscriptions, this should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer.|
|<code>variableUpdated(self, origVar, newVar)</code>| No |Complementary to the variableCreated() method described above, but signals variable updates. You'll get a copy of the old variable object as well as the new variable object.|
|<code>variableDeleted(self, var)</code>| No |Complementary to the variableCreated() method described above, but signals variable deletes.|
=== Helper Methods ===
^Method definition ^Parameters ^Return Value ^Notes ^
| <code>applicationWithBundleIdentifier(self,
bundleID)</code> | bundleID - this is the bundle identifier for the app | SBApplication instance | Bundle id's are usually fully qualified strings - for iTunes it's com.apple.iTunes. What's returned is a scripting bridge SBApplication instance. See the Scripting Bridge documentation for more information. |
| <code>browserOpen(self,
url)</code> | url - the url to open in the browser | None | This method will open the specified in the default browser. Note it does so on the server machine and not on any remotely connected clients. |
| <code>debugLog(self,
msg)</code> | msg - the string to insert into the event log | None | (DEPRECATED - see Logging below) If, at any point in your plugin, you set self.debug = True, then any time debugLog is called the string will get inserted into Indigo's event log. If self.debug = False (the default) any call to debugLog does nothing. |
| <code>errorLog(self,
msg)</code> | msg - the string to insert into the event log | None | (DEPRECATED - see Logging below) If you want an error to show up in the event log (in red text), use this log method rather than indigo.server.log(). |
| <code>openSerial(self,
ownerName,
portUrl, baudrate, bytesize,
parity, stopbits, timeout,
dsrdtr, interCharTimeout)</code> | ownerName - the name of the device or plugin that owns this serial port (used for error logging) - make sure that it's ASCII text with no unicode characters
other args - all other arguments are passed directly to the pySerial's Serial contructor | serial.Serial instance | This method is identical to creating a new pySerial Serial object except that it never throws an exception. If the serial connection cannot be openned then None is returned and an error will be automatically logged to the Indigo Server event log. |
| <code>sleep(self,
seconds)</code> | seconds - the sleep duration as a real number | None | This method should be called from within your plugin's runConcurrentThread() defined method, if it is defined. It will automatically raise the StopThread exception when the Indigo Server is trying to shutdown or restart the plugin. See runConcurrentThread documentation above for more details. |
| <code>substituteVariable(self,
inString,
validateOnly=False)</code> | inString - the string which contains valid variable ID
validateOnly - whether to return the actual string or a validation tuple where the first item is a boolean whether the formatting is valid and the variable ID exists and the second item is the error string to show (defaults to False) | String
if validateOnly is False
(BOOL, errStr)
if validateOnly is True | This method will allow any string with the following markup to have a variable value substituted: <code>%%v:VARID%%</code>VARID is the unique variable ID as found in the UI in various places. It's recommended that you call this method twice: first, when the validation method for your action is called so that you can validate at that point if the syntax is correct and make sure the variable exists. The second time you call this method would be when you execute the action - call it before you actually use the string so that the substitutions will be made. Errors will show up in the event log if the variable doesn't exist (or if there's a formatting problem) at action execution time. |
| <code>substituteDeviceState(self,
inString,
validateOnly=False)</code> | inString - the string which contains valid device ID and state key
(BOOL, errStr)
if validateOnly is True | This method will allow any string with the following markup to have a variable value substituted: <code>%%d:DEVICEID:STATEKEY%%</code>DEVICEID is the unique device ID as found in the UI in various places and the STATEKEY is the identifier for the state. It's recommended that you call this method twice: first, when the validation method for your action is called so that you can validate at that point if the syntax is correct and make sure the device exists. The second time you call this method would be when you execute the action - call it before you actually use the string so that the substitutions will be made. Errors will show up in the event log if the device doesn't exist (or if there's a formatting problem) at action execution time. |
| <code>substitute(self,
inString,
validateOnly=False)</code> | inString and validateOnly as described in the previous two methods
substituteVariable(), substituteDeviceState() |See above | Validation works the same and should be called when your dialog validates user input. This method calls substituteVariable() first followed by substituteDeviceState(). The ordering was carefully chosen such that the variable substitution could, in fact, add more device markup to the string before the device substitution happens. So the user can even more dynamically generate content by inserting device markup into a variable value. However, only device markup will be honored in variable values - we don't recursively call variable markup on variable values.|
=== Properties ===
^Property ^Value Type ^Notes ^
| <code>pluginFolderPath</code> | string | The return value is the full path to the plugin. This is useful if you need to construct a full path to a file somewhere in the plugin's hierarchy, perhaps to have IWS stream the file back. |
| <code>pluginSupportURL</code> | string | The return value is URL that's specified in the plugin's Info.plist. |
==== Logging ====
^ Attribute ^ Description ^
| logger | An instance of the standard Python logger class. You should use this instance to log messages. See the examples below for details. |
| indigo_log_handler | An instance of a special Python Handler class that emits messages to the Indigo Event Log window and the Indigo Server's log file. |
| plugin_file_handler | An instance of a Python TimedRotatingFileHandler which writes you own log files in the /Logs/ directory. A subdirectory will be created using your plugin's ID as the name. Inside that directory will be daily log files (with 20 days of backups) of all log messages from your plugin. See below for examples of the default format of that file. |
<code>
self.logger.debug(u”Debug log message“)
self.logger.info(u”Info log message“)
self.logger.warn(u”Warning log message“)
self.logger.error(u”Error log message“)
self.logger.critical(u”Critical log message“)
</code>
=== self.indigo_log_handler ===
=== self.plugin_file_handler ===
<code>
</code>
=== Log Levels ===
=== Logging from Another Class or Submodule ===
<code>
plugin_logger = logging.getLogger(“Plugin”)
</code>
<code>
class MyClass(object):
def init():
self.logger = logging.getLogger(“Plugin”)
self.logger.debug(“MyClass Object”)
</code>
== Custom IndigoLogHandler ==
<code>custom_logger = logging.getLogger(“MyModule”)
custom_handler = self.IndigoLogHandler(“MyModule”, logging.DEBUG)
custom_logger.addHandler(custom_handler)</code>
<code>
</code>
== exc_info ==
<code>
My Plugin Error Something bad happened.
My Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
</code>
<code>
File “plugin.py”, line 123, in runConcurrentThread
x = 1 / 0
</code>
== Full Example ==
<code>
import logging
def init(self):
self.debugLevel = int(self.pluginPrefs.get('showDebugLevel', “30”))
self.logger.debug(“Starting concurrent thread.”)
x = 1 / 0
except ZeroDivisionError:
</code>
Which yields:
<code>
x = 1 / 0
</code>
=== Logging from Linked and Embedded Scripts ===
<code>
import logging
indigo.server.log(“debug message”, level=logging.DEBUG)
indigo.server.log(“info message”, level=logging.INFO)
indigo.server.log(“warning message”, level=logging.WARNING)
indigo.server.log(“error message”, level=logging.ERROR)
indigo.server.log(“critical message”, level=logging.CRITICAL)
</code>
===== Processing HTTP requests in your plugin =====
* The recommended approach is to use an API key: the request must contain an “Authorization” HTTP header, the value of which is “Bearer API_KEY_HERE”, where you substitute an API key that is generated from the Authorizations page in the user's Indigo Account. This is also how OAuth is used to authenticate when using a external service like Alexa or Google Home.
* If for some reason you can't include the header, you may pass the API key as an additional GET argument on the URL (?other=args&api-key=KEYHERE)
==== Request ====
<code><Action id=“handle_message” uiPath=“hidden”>
<Name>some message</Name>
</Action>
</code>
<code>def handle_some_action(self, action, dev=None, callerWaitingForResult=None):
some_value = action.props[“somekey”]
return some_value
</code>
|Key |Value |
|incoming_request_method | this will be either POST or GET. |
|headers | this is a dictionary of the headers in the request. |
|body_params | if this key exists, it will be a dictionary containing any form POST name/value pairs. It won't exist if the request was a GET or a POST with a body.|
|url_query_args | if there were any query args on the URL line, they will be in this dictionary if it exists. |
|request_body | this will be the contents of the body of the HTTP request. It won't exist if the request was a GET or a POST without any body. |
|file_path | this will be a list of path parts from the URL after the action ID. So for the url: %%http://host/message/pluginid/actionid/path/to/some/file.txt%% the value will be an indigo.List with the following items: %%[“path”, “to”, “some”, “file.txt”]%% |
==== Reply ====
|Key|Value|
|status | this is an integer representing a valid HTTP return code. If it's not included, a 200 will be returned. |
|headers | a dictionary of HTTP headers that will be added to the reply. Most useful will be the 'Content-Type' header if you want to return something else besides JSON (which is the default). |
|content | this is the actual string returned in the HTTP reply. Defaults to an empty string.|
<code>{
“status”: 310, # Internal status code indicating that IWS should stream back the specified file.
“file_path”: path, # this is a full path specifier
“headers”: indigo.Dict({“Content-Type”: content_type} # you should add a Content-Type header
)</code>
==== Errors ====
|Status|Meaning|
|401 | if the OAuth token is invalid. |
|405 | if any method other than POST or GET is attempted. |
|500 | any unexpected/uncaught exception. |
|501 | if the plugin isn't installed or doesn't define the action specified in the URL. |
|503 | if the plugin is installed but is disabled. |
|Key|Value|
|error | One of: plugin_disabled, invalid_plugin, invalid_action, unknown_error|
|description | A textual description of the error|
|exception | Only returned when an unknown_error is returned. It will be the stack trace of the uncaught exception.|
=== Usage Guidance ===
* Long running actions - if your action should be relatively quick to respond: 15-20 seconds is the max guidance
* Large files - large files will slow the total turnaround time, which you need to minimize (see above)
* Binary data - this release of the API isn't designed for binary data
===== Event and Message Flow =====
<code>
###### TURN ON ######
if send_success:
self.logger.info(f”sent \“{dev.name}\” on“)
dev.updateStateOnServer(“onOffState”, True)
self.logger.error(f”send \“{dev.name}\” on failed“)
###### TURN OFF ######
if send_success:
self.logger.info(f”sent \“{dev.name}\” off“)
dev.updateStateOnServer(“onOffState”, False)
self.logger.error(f”send \“{dev.name}\” off failed“)
###### STATUS REQUEST ######
self.logger.info(f”\“{dev.name}\” updated.“)
</code>
===== Plugin Preferences File =====
Back to Top
===== 3rd Party Python Libraries =====
Indigo 2023.2 includes a variety of popular 3rd party Python libraries which are described on the Python Packages page. Any changes to the libraries installed will be detailed there. You should not make changes to the packages that Indigo installs. If you need a different package version, you should include it within your plugin package distribution.
===== Setting Up a Development Environment =====
