Integration APIs
NOTE:
  "key1": "value 1",
  "key2": 2
PythonJSON Equivalent
True true
False false
float Number
int Number
None null
dict Object
list Array
tuple Array
str String
WebSocket Lifecycle
  1. Setup:
''//wss://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed?api-key=YOUR-API-KEY//''
IMPORTANT! In order to use API Key authentication, you MUST have enabled Enable OAuth and API Key authentication in the Indigo "Start Local Server" dialog box. Don't share your API keys with anyone who isnot authorized to use them — especially in posts to the Indigo user forums. Note that disabling this feature disables both API Keys and secrets.
Python Receiver Example
import asyncio
import websockets
import json
API_KEY = 'YOUR-API-KEY'
async def receiver():
            while True:
    except Exception as exc:
        print(f"Exception:\n{exc}")
asyncio.run(receiver())
import asyncio
import json
async def receiver(ws):
        refresh_message = {
            "message": "refresh",
            "objectId": DEVICE_ID
        counter = 0
        device = {}
        while counter < 20:
            if message_type == "refresh":
            elif message_type == "patch":
            counter += 1
async def sender(ws, count):
        print("Starting sender task")
        message = {
        for count in range(10):
            msg = json.dumps(message)
            await asyncio.sleep(5)
async def main():
asyncio.run(main())
JavaScript Example
  console.log(message.data);
%%ws:localhost:8176/v2/api/ws/device-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed%%
add device message
  "message": "add",
  objectDict": {
    "address": "3B.04.7A",
    "batteryLevel": null,
    "blueLevel": null,
    "brightness": 100,
    "buttonConfiguredCount": 0,
    "buttonGroupCount": 1,
    "configured": true,
    "defaultBrightness": 100,
    "deviceTypeId": "",
    "displayStateValRaw": 100,
    "displayStateValUi": "100",
    "enabled": true,
    "energyAccumBaseTime": null,
    "energyAccumTimeDelta": null,
    "energyAccumTotal": null,
    "energyCurLevel": null,
    "errorState": "",
    "folderId": 1552926800,
    "globalProps": {
      "emptyDict": {}
    "greenLevel": null,
    "id": 1508839119,
    "ledStates": [],
    "name": "Insteon Dimmer",
    "onBrightensToLast": false,
    "onState": true,
    "ownerProps": {},
    "pluginId": "",
    "pluginProps": {},
    "redLevel": null,
    "remoteDisplay": false,
    "sharedProps": {},
    "states": {
      "brightnessLevel": 100,
      "onOffState": true
    "subModel": "Plug-In",
    "subType": "Plug-In",
    "supportsAllOff": true,
    "supportsColor": false,
    "supportsOnState": true,
    "supportsRGB": false,
    "supportsWhite": false,
    "version": 67,
    "whiteLevel": null,
    "whiteLevel2": null,
    "whiteTemperature": null
update device message
  "message": "patch",
  "objectId": 1508839119,
  "patch": [
      "change",
      "brightness",
      [100, 0]
      "change",
      "displayStateImageSel",
      "change",
      "displayStateValRaw",
      [100,  0]
      "change",
      "displayStateValUi",
      ["100", "0"]
      "change",
      "lastChanged",
      "change",
      "lastSuccessfulComm",
      "change",
      "onState",
      [true, false]
      "change",
      "states.brightnessLevel",
      [100, 0]
      "change",
      "states.onOffState",
      [true, false]
device refresh messages
  "list": []
  "objectDict": {}
delete device message
  "message": "delete",
  "objectId": 123456789
Device messages to the server
device refresh requests
  // Specify the object type
device command messages
  "objectId": 123456789,
%%ws:localhost:8176/v2/api/ws/variable-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/variable-feed%%
  "class": "indigo.Variable",
  "description": "",
  "folderId": 0,
  "globalProps": {
  "id": 345633244,
  "name": "house_status",
  "pluginProps": {},
  "readOnly": false,
  "remoteDisplay": true,
  "sharedProps": {},
  "value": "home"
add variable message
  "message": "add",
update variable message
Variable patch objects are created via the dictdiffer python module by comparing the variable dictionary (%%dict(some_variable)%%) for the old variable with the one for the new dictionary as they are received in the %%variable_updated()%% Plugin method call.
delete variable message
variable refresh messages
variable command messages
updateValue
  "parameters": {
    "value": "Some string value"
%%ws:localhost:8176/v2/api/ws/action-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/action-feed%%
  "description": "",
  "folderId": 532526508,
  "globalProps": {
      "speakDelayTime": "5",
  "id": 94914463,
  "name": "Movie Night",
  "pluginProps": {},
  "sharedProps": {
add action group message
  "message": "add",
update action group message
Action group patch objects are created via the dictdiffer python module, by comparing the action dictionary (%%dict(some_action_group)%%) for the old action with the one for the new dictionary as they are received in the %%action_group_updated()%% Plugin method call.
delete action group message
action group refresh messages
action group command messages
%%ws:localhost:8176/v2/api/ws/page-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/page-feed%%
  "backgroundImage": "",
  "description": "",
  "folderId": 0,
  "globalProps": {},
  "hideTabBar": true,
  "id": 963336187,
  "name": "Weather Images",
  "pluginProps": {},
  "sharedProps": {}
add control page message
  "message": "add",
update control page message
delete control page message
  "id": 617272302,
  "class": "indigo.Folder",
  "name": "My Device Folder",
refresh folder server message
  "message": "add",
  "objectDict": {
    "message": "Stopping plugin \"Web Server 2024.1.0\" (pid 1020)",
    "typeStr": "Application",
    "typeVal": 0
  • %%/v2/api/indigo.devices%% - endpoint to get a list of devices
  • %%/v2/api/indigo.devices/123456789%% - endpoint to get a specific device instance (See Device Objects below)
  • %%/v2/api/indigo.variables%% - endpoint to get a list of variables
  • %%/v2/api/indigo.variables/123456789%% - endpoint to specific variable object (See Variable Objects below)
  • %%/v2/api/indigo.actionGroups%% - endpoint to get a list of action groups
  • %%/v2/api/indigo.actionGroups/123456789%% - endpoint to get a specific action group (See Action Group Objects below)
  • %%/v2/api/command%% - endpoint to send Indigo a command (device control, variable update, action execution).
Getting All Device Objects
import json
with urlopen(req) as request:
    print(device_list)
const http = require("https")
const options = {
  headers: {
  let result = ""
    result += chunk;
  response.on("end", () => {
    console.log(deviceList);
import json
DEVICEID = 123456789
    print(device_instance)
const DEVICEID = 123456789
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(deviceInstance);
Controlling an Indigo Device
import json
message = json.dumps({
    "objectId": DEVICEID
}).encode("utf8")
    reply = json.load(request)
    print(reply)
const options = {
  path: "/v2/api/command",
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
import json
  "objectId": DEVICEID,
  "parameters": {
    "value": 50,
    "delay": 10
}).encode("utf8")
    print(reply)
  "parameters": {
    "value": 50,
    "delay": 10
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
Getting All Variable Objects
import json
    print(variable_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(VariableList);
import json
    print(var_instance)
const VARID = 123456789
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(varInstance);
Updating a Variable's Value
import json
VARIABLEID = 123456789
  "objectId": VARIABLEID,
  "parameters": {
}).encode("utf8")
    print(reply)
const VARIABLEID = 123456789
  "parameters": {
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
import json
    print(action_group_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(actionGroupList);
Executing an Action Group
import json
ACTIONGROUPID = 123456789
  "objectId": ACTIONGROUPID
}).encode("utf8")
    print(reply)
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
Device Objects
Example device object
  "blueLevel": null,
  "brightness": 0,
  "configured": true,
  "deviceTypeId": "",
  "displayStateValRaw": 0,
  "displayStateValUi": "0",
  "enabled": true,
  "errorState": "",
  "folder": {
    "id": 1552926800,
    "name": "Insteon",
  "globalProps": {},
  "greenLevel": null,
  "id": 1508839119,
  "ledStates": [],
  "onState": false,
  "ownerProps": {},
  "pluginId": "",
  "pluginProps": {},
  "redLevel": null,
  "sharedProps": {},
  "states": {
    "brightnessLevel": 0,
    "onOffState": false
  "version": 67,
  "whiteLevel": null,
indigo.device
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "value": True,
indigo.dimmer
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "value": 50,
    "delay": 10
indigo.iodevice
  "parameters": {
    "index": 5,
    "value": true
indigo.sensor
  "parameters": {
    "value": true
indigo.speedcontrol
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "value": 2,
    "delay": 5
  "parameters": {
    "value": 50,
    "delay": 5
indigo.sprinkler
  "parameters": {
  "parameters": {
    "index": 2
indigo.thermostat
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "value": 76
  "parameters": {
  "parameters": {
    "value": 76
  "parameters": {
Variable Objects
  "description": "",
  "folderId": 0,
  "folder": {},
  "globalProps": {
  "id": 345633244,
  "pluginProps": {},
  "readOnly": false,
  "sharedProps": {},
  "value": "home"
  "parameters": {
  "description": "",
  "folder": {
    "id": 532526508,
    "name": "Mood Scenes",
  "globalProps": {
  "id": 94914463,
  "pluginProps": {},
  "sharedProps": {
Example Log Message
  "typeVal": 0
EVENT_TYPES = {
  Application = 0,
  Error = 1,
  Error_Client = 2,
  Warning = 3,
  Warning_Client = 4,
  Debug_Server = 5,
  Debug_Client = 6,
  Debug_Plugin = 7,
  Custom = 8,
Log Command Message
import requests
API_KEY = "MY_API_KEY"
message = {
"message": "indigo.server.log",
    device_list = response.json()
    print(device_list)
Plugin Command Messages
restart plugin
    "message": "plugin.restart",
    "pluginId": "com.some.indigo.plugin"   # the plugin's bundle identifier
Execute Plugin Action
    "pluginId": "com.some.indigo.plugin",   # the plugin's bundle identifier
    "actionId": "some_plugin_action",  # the ID of the plugin action found in the plugin's Actions.xml file [string]
    "deviceId": 12345678,  # the device ID targeted by the plugin action (not all actions will require a device ID). [int]
    "props": {"prop1": "foo", "prop2": "bar"},  # required if the plugin action requires props to fire the action [valid JSON]
    "waitUntilDone": True  # optional [True/False]
Generic Error Message
  "validationErrors": {
Example API Call
  "parameters": {
    "value": 1234.56
Resulting Error Message
  1. %%message%%,
  2. %%objectId%%,
  3. %%parameters%%, and
  4. %%value%%
Invalid JSON
Example Invalid JSON Message
  "error": "invalid JSON"
Web Server Warnings
Code Condition Description
200 OK or Success Indicates that the request has succeeded.
400 Bad Request Indicates that the server cannot or will not process the request due to something that is perceived to be a client error <HTML><BR></HTML>(for example, malformed request syntax, invalid request message framing, or deceptive request routing)
401 Unauthorized Indicates that the client request has not been completed because it lacks valid authentication credentials for the <HTML><BR></HTML>requested resource.
404 Not Found Indicates that the server cannot find the requested resource.
500 Internal Server Error Indicates that the server encountered an unexpected condition that prevented it from fulfilling the request.
Other Errors and Warnings
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/api.1734711516.txt.gz
  • Last modified: 2024/12/20 16:18
