The commands in this section are common to all action groups regardless of type.
| Parameters |
Display In Remote UI
| Parameters |
| Parameters |
| Parameters |
| event_data | No | dict | a dictionary instance that will get passed to all actions in the action group for processing |
A note on event_data - Indigo will automatically add a source key to your dictionary to represent where the action execution came from:
However, if you include a source key in your event_data, we will not overwrite it, we'll just pass through whatever your value is.
Use this command to retrieve all the Indigo objects dependent on the action group. The command will return an indigo.Dict containing all the dependencies.
indigo.actionGroup.getDependencies(123)
| Parameters |
| Parameters |
