name | string | the name of the variable - no two variables can have the same name and the name cannot contain whitespace |
sharedProps | dictionary | API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use var.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props). |
value | string | the Unicode string value of the variable |
Remember that accessing the value property of a variable object (var.value) will return a Unicode string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
# Getting the Unicode string value (no conversion call necessary, just access the property)
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
| Parameters |
| direct parameter | Yes | string | the name of the variable |
Delete the specified variable.
indigo.variable.delete(123)
| Parameters |
| Parameters |
indigo.variable.getDependencies(123)
| Parameters |
ID : 552463741 (integer)
ID : 296710860 (integer)
So, the dictionary will have 6 top-level keys: “actionGroups”, “controlPages”, “devices”, “schedules”, “triggers”, and “variables”. Each one of those keys will return a list object. Inside that list object will be multiple dicts, one for each dependency (or an empty list if there are none). Each dependency dictionary has two keys: “ID” which is the unique id and “Name” which is the name of the object.
| Parameters |
| Parameters |
Update Value
| Parameters |
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
# Getting a variable using its ID
# Getting a variable using its name
