Variables
value string the value of the variable
Remember that accessing the value property of a variable object (var.value) will return a string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
# Getting the boolean value
# Getting the integer value
# Getting the float value
Delete the specified folder.
indigo.variable.delete(123)
Update Value
Python AppleScript
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
-- Create a new variable
-- Update value
set value of newVar to "asleep789"
-- Changing name property
set name of newVar to "goodName"
set newVar to variable "goodName" -- when the name changes, you have to get a fresh reference
-- Changing name and values properties
set name of newVar to "goodName2"
set newVar to variable "goodName2" -- when the name changes, you have to get a fresh reference
set value of newVar to "searchingForWaldo"
delete variable "goodName2"
# You can't get a variable using its ID in AppleScript
set someVar to variable named "MyVarName"
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/variable_class.txt
