Indigo Scripting Tutorial
Talking to the Indigo Server
Example Code Snippets
Device Examples
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
from datetime import datetime
Access a custom device state
Variable Examples
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import urllib, urllib2
myUnicodeString = u"éçø"
myInteger = 1
myFloat = 1.0
import simplejson as json
myNewDictionary["myList"]
class myCustomClass:
def __init__(self):
self.a=1
self.b=2
def __unicode__(self):
return outputString
Date and Time Examples
Get the current server time:
indigo.server.getTime()
Action Group Examples
Log Examples
Folder Examples
except ValueError, e:
myFolder = None
Miscellaneous Examples
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Connecting Remotely over SSH
What Else Can it Do?
indigo-host -e '
Executing Indigo Python Files
Executing AppleScript
indigo_attachments.py
import indigo
except ImportError:
raise ImportError
def log(message, label=None):
import indigo_attachments
raise ImportError
ImportError
Scripting Indigo Plugins
| pluginDisplayName | The name displayed to users in the clients |
| pluginId | The ID of the plugin (same as was passed to the getPlugin() method above) |
| pluginSupportURL | The URL supplied by the plugin that points to its user documentation |
| pluginVersion | The version number specified by the plugin |
iTunes Toggle Play State
if itunesPlugin.isEnabled():
iTunes Set Volume to 50
Restart a Plugin
