apiVersion string No API v1.7+ only: the currently connected Indigo Server plugin API version as a string (ex: “1.7”)
/* |portNum| integer | No |the port number of the currently connected Indigo Server */ /* |connectionGood| boolean | No |true if the connection to the Indigo Server is currently good| */
lat = latLong[0]
long = latLong[1]
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
indigo.server.getTime()
No Parameters
level No integer API v2.4+ only: the python logging level which determines both the type shown and the text color used. (ex: using “level=logging.WARNING” will show orange text)
indigo.server.sendEmailTo("[email protected]")
  • /www/perceptive/wiki/data/pages/indigo_7.4_documentation/server_commands.txt
