Indigo Scripting Tutorial
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
	isOn = lamp.onState
from datetime import datetime
Access a custom device state
# get the device
print unicode(dev.states)
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import urllib, urllib2
myUnicodeString = u"éçø"
myInteger = 1
myFloat = 1.0
import simplejson as json
myNewDictionary["myList"]
class myCustomClass:
  def __init__(self):
	  self.a=1
	  self.b=2
  def __unicode__(self):
    return outputString
cl = myCustomClass()
Get the current server time:
indigo.server.getTime()
import datetime
print(logList)
except ValueError, e:
		myFolder = None
if lamp.folderId != 0:
	lampsFolder = None
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Plugin Host Prompt Image
indigo-host -e '
indigo_attachments.py
    import indigo
except ImportError:
    raise ImportError
def log(message, label=None):
import indigo_attachments
    raise ImportError
ImportError
pluginDisplayName The name displayed to users in the clients
pluginId The ID of the plugin (same as was passed to the getPlugin() method above)
pluginSupportURL The URL supplied by the plugin that points to its user documentation
pluginVersion The version number specified by the plugin
isEnabled()
This method will return True if the plugin is enabled (running), False otherwise
executeAction(actionId, deviceId, props)
This is the method that actually executes the action. actionId is the unique action id. deviceId is the id of the device that the action on which the action will perform (if it requires a device). props is a dictionary of properties that the action needs to process correctly. See the plugin's documentation for a description of what you need to pass in to execute actions.
restart(waitUntilDone=True)
This method will restart the plugin if it's already running. Pass the optional parameter waitUntilDone=False if you don't want to block while the plugin restarts (waitUntilDone defaults to True if it's no parameters are passed). If you're a plugin developer and you want to restart the plugin from within itself you should pass that parameter.
iTunes Toggle Play State
if itunesPlugin.isEnabled():
iTunes Set Volume to 50
Restart a Plugin
	itunesPlugin.restart()
  • /www/perceptive/wiki/data/pages/indigo_7.5_documentation/plugin_scripting_tutorial.txt
