Table of Contents
Getting Started Guide
Introducing the Indigo Home Automation Server
Welcome to Indigo!
Out of the box, Indigo supports the following Home Automation protocols (simultaneously) via a separate hardware interface device:
Z-Wave
Z-Wave is a very popular home automation technology that's used worldwide. There are many different manufacturers of Z-Wave devices so the selection is quite good. To use Z-Wave with Indigo, you'll need a Z-Wave interface (often referred to as a dongle): Indigo supports Z-Wave via the Aeotec Z-Stick Series 2 interface or the EZController / Z-Troller interfaces. Other USB and serial Z-Wave interfaces may work as well but we've concentrated our efforts on the Z-Stick / EZController / Z-Troller.
  • Sensors (contact, magnetic, motion, temperature, etc.)
  • Thermostats
  • Locks
Other device types will be added over time. Check our Supported Z-Wave Module List to see if a specific module has been tested. Note however that just because a module isn't listed doesn't mean that it won't work - Z-Wave is architected such that devices that correctly support Z-Wave features should automatically work. There are so many different devices from many different manufacturers that we will never be able to test them all. If you have a device that isn't listed but works, please feel free to report it to us and we'll add it to the list. There is a very simple mechanism to report devices, described in Editing a Z-Wave Device's Properties towards the end of that section.
INSTEON
INSTEON is a protocol developed by SmartLabs, parent company of Smarthome.com, which is widely used in North America and is moving into other markets as well. There are a few 3rd party vendors that make INSTEON hardware but most devices are made by SmartLabs. To use INSTEON with Indigo, you'll need an INSTEON interface. These are the INSTEON interfaces that Indigo supports:
  • PowerLinc Modem 2413U and 2413S (with serial to USB adaptor) - these are our recommended interfaces since they support both power line and RF transmission. They also support the legacy X10 protocol.
  • PowerLinc Modem 2412U and 2412S (with serial to USB adapter) - these interfaces also support the legacy X10 protocol.
  • PowerLinc Portable USB Adapter 2448A7 - this discontinued interface is INSTEON only
We also support the following discontinued INSTEON interface:
  • PowerLinc Controller V2 2414U - this interface doesn't support the latest INSTEON devices so should be avoided
Indigo supports the vast majority of INSTEON devices - see our Supported INSTEON Devices List for a complete list.
X10
X10 is a legacy technology that works primarily over the power line though some devices are wireless (using the X10 RF protocol). We don't recommend anyone start a new home automation system using X10 because of it's poor reliability - however, if you have existing X10 devices you can definitely use them with Indigo if you have a compatible X10 interface. These are the X10 interfaces that Indigo supports:
  • ActiveHome Pro (CM15A) - includes X10 RF (wireless) receiving
  • ActiveHome (CM11) - X10 power line only
  • W800RF (USB or Serial) - X10 RF (wireless) receiving only
  • X10 PC Receiver (MR26A) - X10 RF (wireless) receiving only
  • PowerLinc Modem 2412U/2412S/2413U/2413S/ - as noted above, these are primarily INSTEON interfaces but also work with X10 (power line only)
We also support the following discontinued X10 interfaces:
  • PowerLinc Controller V2 (2414U)
  • PowerLinc Controller (1132CU & 1132U) - X10 only
  • LynX-PLC (X10 only)
Other Devices
If you don't have any of the above hardware, you can still install and use Indigo - particularly if you have hardware supported by one of the many 3rd party plugins. For instance: RFXtrx433 with support for Home Easy/Chacon, X10 RF, LightwaveRF, and many different types of sensors; Nest and Aprilaire Thermostats; Alarm Panels; A/V equipment; etc. See our plugin list for all available 3rd party plugins. Indigo also ships with some useful plugins out of the box.
Other Sources for Help
Installing Indigo
Indigo can run as a standalone application on a single Mac or can be run in a client/server mode on two or more Macs. In either case, you must first run the Indigo installer on the main Mac (also referred to as the server Mac) to which the home automation interface hardware (Z-Stick, EZController / Z-Troller, PowerLinc, CM11, etc.) will be connected. Just download the latest Indigo installer. This should download the disk image. In Safari, click the downloads button (the down arrow to the right of the URL/search bar). You should see an entry titled “Indigo.dmg”. Double-click that and you should get switched to the Finder and a dialog will show that the disk image is being mounted. Once it's mounted, a window will open with the following files:
The Indigo 7 application can be found here:
  /Applications/Indigo 7
Database files are stored in the Database folder in that folder.
Note: this is the Library folder at the top level of your hard drive, not the one in your User folder. Lion and greater hide these folders by default, but if you select the “Go→Go to Folder…” menu item in the Finder and paste in the path above it will open that folder in a Finder window.
Backing Up Indigo
Note: this is the Library folder at the top level of your hard drive, not the one in your User folder. Use the Go→Go to Folder… menu item in the Finder and paste in the path above to get there easily).
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 7 installer again (which will repair any permission issues that Time Machine may have introduced).
  • Indigo 7 moved to Python 2.7, so if you installed any shared scripts (as outlined here) then you'll need to move them from: /Library/Python/2.6/site-packages/ to /Library/Python/2.7/site-packages/
  • Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo 7, then it will automatically be installed and used on launch.
  • Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 2/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 2/IndigoWebServer/images/
NOTE: Do not replace the Indigo 7 versions of any file with your Indigo 6, 5, 4, 3, or 2 files. They have been modified to run optimally under Indigo 7.
Upgrading from Indigo 1.x
  • Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. You will be prompted to save the new copy of the Indigo database file. The Indigo 7 file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo 7 to your database settings will not be available in older versions of Indigo.
NOTE: Do not replace the Indigo 7 versions of any file with your Indigo 1.x files. They have been modified to run optimally under Indigo 7.
  5. NOTE: It is not necessary to restart your Mac after installing the Indigo Client package only.
Moving an Indigo 7 Installation to another Mac
  1. First copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 7/
  2. Install Indigo 7 on the new Mac (download and run the installer)
NOTE: this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the “Go→Go To Folder…” menu item in the Finder and paste in this:
Uninstalling Indigo 7
To uninstall the Indigo Server and all of its data and configuration files, make sure that you have the server and client completely shut down (select Stop Server from the Indigo 7 menu before you quit the Indigo Mac Client). Then, delete the following files:
  • /System/Library/Extensions/IndigoOverrides.kext
  • /Applications/Indigo 7
  • ~(your user folder)/Library/Preferences/Indigo 7 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 7 Client Settings.indiPref
Note your Mac has two different Library folders. One is in your the home directory of the account Indigo runs under and the other is at the root level of the drive. In Mac OS X Lion and higher the user's home Library folder is hidden in the Finder so you'll have to use the Go to Folder… menu item in the Finder and type in the path (“~/Library/Preferences”) which will open a Finder window to the Preferences folder.
Starting Indigo Server
  1. Double click the Indigo 7 application (/Applications/Indigo 7).
  2. If this is the first time to run Indigo 7 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 7→Start Local Server… menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application radio button. This will automatically run the client/server as a single application. This requires that the Indigo UI always be running on your Mac - when you quit the Applications→Indigo 7 application all Indigo event processing (triggers, schedules, scripts, etc.) will cease processing. This is not our recommended configuration.
Running in Client/Server Mode
Use the Enable anywhere secure access checkbox for secure Web browser access from anywhere. This option requires a you to have configured a Reflector, which handles maintaining the secure connection to Indigo Server automatically. Reflectors are included as part of your Up-to-Date subscription.
Use the Enable remote Indigo client access checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server.
Use the Log Device state history to SQLite or PostgreSQL checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions.
Starting the Server
If this is the first time you've started the server, you'll be prompted first to click through our Enduser License Agreement (EULA), then you'll see the server registration dialog:
Enter you name and registration code exactly as they appear in your registration email (copy/paste works best) and click OK. The server will continue to start up.
If you purchased a retail disk, you should enter your full first and last name along with the registration code exactly as it appears on the label on the disk sleeve. When you click OK you'll be prompted to register your copy on our website.
While this isn't required, it's highly recommended. If you don't, we won't be able to locate your registration code in the future should you need it again - and you will to get discounted upgrades to major new releases and access to dot releases.
Remote Indigo Access
Modifying Firewall Settings
In order to remotely access the Indigo Server we must enable the ports Indigo Server uses in the system's network firewall. Follow these steps on the Mac running Indigo Server if you are running Mac OS X 10.7 or earlier (later systems will automatically prompt you if required so you shouldn't need to adjust any settings).
  1. Stop the Indigo Server if it is running by choosing the Indigo 7→Stop Server menu item.
  2. Choose the Apple Menu→System Preferences menu item.
  3. Select the Security preference panel.
  4. Select the Firewall tab.
  5. Select the Set access for specific services and applications radio button.
  6. Restart the Indigo Server by choosing the Indigo 7→Start Local Server… menu item and pressing the Start Server button.
  7. Mac OS X will now ask your permission to allow incoming network connections for the application IndigoServer.app and Python.app. Press the Allow button for each.
The Indigo Web Server advertises itself via Bonjour, so Indigo Touch and Safari (by clicking on the bookmarks icon, then selecting Bonjour) will automatically find any local servers. In addition to that, when connecting to a local server for the first time, Indigo Touch will also automatically fetch Prism Reflector settings for that connection so that you'll be able to connect outside your LAN via LTE/4G/3G/Edge.
For other browsers to remotely access the Web server, we need to know the network IP address for the Mac running Indigo Server. This address will be used on the remote Mac or Web browser when connecting to the Indigo Server. Follow these steps on the Mac running Indigo Server.
  1. Choose the Apple Menu→System Preferences menu item.
  2. Select the Sharing preference panel.
  3. If File Sharing is not turned on, then temporarily enable it.
  4. Note the URL shown in the window:
  5. The IP address is the number portion of the URL (ex: 192.168.1.4).
  6. If you do not want File Sharing on, then turn it off. You only turned it on to make the IP address visible.
  7. Close the System Preferences window.
You now have the IP address for the Mac running Indigo Server. Depending on your home network setup, this IP address may change periodically, such as when the Indigo Server Mac or router is restarted. If this happens, then you can use the steps above to discover the IP address again, or you can configure a static (not dynamic) IP address for the Mac running Indigo Server.
  1. Double click the Indigo 7 application (inside /Applications/Indigo 7) on the remote Mac.
  2. If this is the first time to run Indigo 7 on this remote Mac, then press the Connect to Remote Server… button in the connection status window.
  3. If you are wanting to connect to a different Indigo Server, then select the Indigo 7→Connect to Remote Server… menu item.
  4. Enter the IP address for the Indigo Server Mac discovered in the section above.
  5. If you overrode the Indigo Server port number (default: 1176) in the Start Local Server dialog on the server Mac, then select the Override default port number checkbox and enter your custom port number.
  6. Press the Connect button.
NOTE: the Indigo Mac Client doesn't use the Prism Reflector service. Connecting an Indigo Mac Client to a server over the internet is a complex topic that is well beyond this document – we suggest you search our online forums for others that have configured this type of access.
Indigo Touch, the iPhone and iPod Touch application from Perceptive Automation, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages. One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings button. You should see the name of your Database in the list. Tap on it, and it will connect (it will ask for your username/password if you have one set, but it will remember it going forward so you won't have to type it in again).
At this point, Indigo Touch will also query the server to see if you have a Prism Reflector account set up for the server. This makes connecting to your home server via Indigo Touch completely seemless. If you have a reflector set up and running, then Indigo Touch will automatically attempt to connect no matter where you are or how you're connected. If you're local, it will use the local wireless LAN, If you're on a remote wireless LAN, it will attempt to use the reflector account. If you're iPhone is on LTE/4G/3G/Edge, it will also attempt to connect via your reflector account. This makes Indigo Touch truly location agnostic!
Indigo, when run in client/server mode, will automatically start its built-in Web server on launch. This allows access from remote Macs, PCs, and other internet devices like the iPhone, iPod Touch, Nokia 770 and PepperPad. Any device that can run a modern Web browser (Safari, Firefox, Opera) will work.
 http://192.168.1.23:8176/
Alternatively, if you already have the Indigo Client on a remote Mac connected to the Indigo Server, then you can use Indigo's Go→Browser… menu items to open a new browser page pointing to the built-in Web server.
Connecting Z-Wave Interfaces
The Aeotec Z-Stick Gen5 uses a built-in driver included with Mac OS X (AppleUSBCDC Modem), so you don't need to install any drivers for it.
The Aeotec Z-Stick Series 2 interface requires that you install the Silicon Labs VCP Driver Kit for Mac OS X. Make sure you have restarted after the installation process. If you reinstall your OS, then you will need to rerun the driver installer.
The Z-Troller (EZController) is a serial interface so it will require the use of a serial-to-USB adaptor. You'll need to install the appropriate drivers for your adaptor. We highly recommend getting an adaptor that uses the FTDI chipset as they seem to be the most reliable virtual comm port drivers for Mac OS X.
As mentioned before, other Z-Wave Interfaces that support the Z-Wave Serial API may be compatible and those may require other drivers. See the vendor for more information.
  3. On the Serial Port popup, you should select the serial port titled SLAB_USBtoUART (for Z-Stick Series 2) or one that starts with usbmodemfd (for Z-Stick Gen5), depending on which Z-Stick version you have. If you have two serial ports that start with SLAB_USBtoUART that means that you have multiple devices that use the Silicon Labs VCP driver - you'll just need to try each one to determine which is the correct port if you don't know beforehand. Unfortunately, that driver doesn't handle multiple devices using the Silicon Labs chip very well, and that number may change when you reboot.
Connecting INSTEON and X10 Power Line Interfaces
Install the FTDI VCP Drivers
The PowerLinc 2412U, 2413U, and 2448A7H interfaces should be plugged directly into one of your Mac's USB ports (preferably not into a USB hub port) and require the FTDI Virtual COM Port (VCP) driver to be installed. If you are using Mac OS X 10.9 (Mavericks) or better, it has the driver already installed.
For earlier versions of the OS, you can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type popup menu in the Preferences dialog (see below), then Indigo will alert you if the driver is not installed on your Mac. If you're using a PowerLinc 2412S/2413S with a separate USB to serial adapter, you can ignore that warning alert.
Connecting the Interface
Plug the interface directly into an outlet (with the exception of the PowerLinc 2448). Do not plug the interface into your computer's power strip because many power strips contain filters that will severely degrade the INSTEON / X10 signal quality being received and transmitted by the interface. Additionally, uninterruptible power supplies (UPSs) can cause signal quality problems. If at all possible plug the interface into a different outlet than used by power strips and UPSs. Signal filters are available to isolate computer power strips and UPSs as well.
Indigo is pre-configured to recognize and use the PowerLinc 2414U/1132CU/1132U interfaces but not the other PowerLinc models. If you are using the PowerLinc 2414U/1132CU/1132U, then you can skip to the Enabling and Disabling Communication section below by choosing the Interface→Connect menu item. Depending on the PowerLinc, Indigo may have to upload information and synchronize with it, which can take a couple of minutes. If you receive an error or are using a different interface model, then manually configure the interface.
  1. Choose Indigo 7→Preferences… menu, then make sure the Interfaces tab is selected.
Choose the Interfaces→INSTEON/X10 Powerline→Disable (or Enable) menu item to disable/enable the interface.
Connecting X10 RF Interfaces
The process for connecting X10 RF Interfaces is basically the same as for power line interfaces - you just need to select the correct serial port. The W800USB will require installing the FTDI drivers mentioned above. You only need to use this interface if you're using a separate X10 RF interface like the W800 or MR26. If you are using a CM15 then enable it in the Connecting INSTEON and X10 Power Line Interfaces section above.
Interface Preferences
You can also enable/disable and configure the various built-in interfaces by selecting the Interfaces→Manage Interfaces… menu item or by opening the preferences dialog by selecting the Indigo 7→Preferences… menu item then clicking on the Interfaces tab.
Installing Plugins, Configuring Plugin Settings, Permanently Removing Plugins
Indigo includes the ability to use plugins developed by 3rd party developers (see our plugin list for available plugins). To install a plugin, just download it from the source (wherever that may be) onto your Indigo Server Mac, then in the Finder double-click the .indigoPlugin file (if the file ends with .zip, then you will have to unzip it first by double-clicking). This will open the Indigo Mac Client application and ask you if you want to install it. If you agree, the first time you install a plugin it will automatically open the plugin's configuration dialog (if it has one).
You can also open the config window choosing the Indigo 7→Preferences… menu item and clicking the Plugins tab. Make sure the plugin is enabled (by checking the Enabled checkbox) then double-click on the plugin's name (or select it and click the Configure… button).
Again, if this is the first time the plugin has been enabled this will open the configuration dialog for the individual plugin if the plugin supports a one.
You can also enable/disable and configure the various plugins by selecting the Plugins→Manage Plugins… menu item or by opening the preferences dialog by selecting the Indigo 7→Preferences… menu item then clicking on the Plugins tab.
If you would like to permanently remove a plugin (rather than just disabling it by unchecking the Enabled button mentioned above), you may do so by following these steps:
  1. Shut down the Indigo Server by selecting the Indigo 7→Stop Server menu item in the Mac client (you can leave the client app running).
  2. Open the following folder in the Finder: /Library/Application Support/Perceptive Automation/Indigo 7/ (you can select the Go→Go to Folder… menu item in the Finder and paste in the path to open a Finder window). In that Finder window you'll see two folders: Plugins and Plugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin.
  3. Switch back to the Indigo 7 Mac client and click on the Start Local Server… button in the Server Connection Status dialog.
Configuring Email Settings
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as jetsons-house@myisp.com. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server options shown below to reduce mailbox clutter.
To configure email sending
  1. Choose Indigo 7→Preferences… menu item, then make sure the Email tab is selected.
  3. Enter your SMTP user name and password (these may be optional)
To configure email scanning
  • Choose the Indigo 7→Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 7→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 7→Check for Updates… menu item.
Modifying System Settings for Continuous Monitoring
How to Enable Plugins
Indigo ships with quite a few very useful plugins. We install these plugins disabled so you'll only need to enable the ones you want to use. There are two ways to enable/disable a plugin: select the Enable (or Disable as the case may be) menu item under the plugin's submenu on the Plugins menu. The other is to select the Plugins→Manage Plugins… menu item which will open the Indigo Preferences window to the Plugins tab. Installing 3rd party plugins is a very simple process as well.
Where to Go Next
indigo_7_documentation/getting_started.txt · Last modified: 2017/10/08 16:41 by mattb
