Indigo 7 provides several tools to manage your Z-Wave network. Not only can you create/control/delete devices but you can also manage device associations and scenes. See the Connecting Z-Wave Interfaces section of the Getting Started Guide for details on connecting and configuring your Z-Wave interface.
Tip: if you're having issues with Indigo communicating with some of your Z-Wave devices, look at the position of your Z-Stick or EZController / Z-Troller. If you have it plugged directly into your Mac then the chances are that the signal range is reduced somewhat. Also, if there are any other electronics close to it (external hard drives, etc.) then you may want to try to move the interface around a little. For the Z-Stick, try a USB hub with connectors on the top that allow you to position it vertically. A word of warning: some users have used short USB extension cables successfully but others have found that these sometimes cause communication errors with the Z-Stick.
DEVICES
dialog.Z-Wave
from the Type popup menu.Define and Sync…
button.Synchronize Z-Wave Device
dialog.
If you added a device to the network (Z-Wave Controller) without encryption enabled and then wish to enable encryption you must first remove it from the network. This is because the encryption key exchange can only occur with Indigo if the device has just been added to the network (within a few seconds), and before a device can be added to the network it must not be included in any networks. To do this you can use the Interfaces->Z-Wave->Start Controller Exclusion Mode
menu item to put the Z-Wave Controller into exclusion mode, then follow the steps from the device's manual to have it exclude itself from the network. Once excluded (you can see the progress in the Event Log window
), you can then use the New with Encryption Enabled
button inside the Syncrhonize Z-Wave Device dialog to re-add it to the network with encryption.
If you have a Z-Wave lock currently included with another controller, you must first exclude the lock from the network before adding it to Indigo with encryption enabled. To do this you can use the Interfaces->Z-Wave->Start Controller Exclusion Mode
menu item to put the Z-Wave Controller into exclusion mode, then follow the steps from the device's manual to have it exclude itself from the network. Note you do not have to use the original controller to perform the exclusion – you can use Indigo's exclusion process. Once excluded (you can see the progress in the Event Log window
button inside the Syncrhonize Z-Wave Device dialog to add it to Indigo's Z-Wave network with encryption. Follow the instructions from the lock's manual for the inclusion steps required. Note that either the Z-Wave Controller used by your Mac or a device that supports Z-Wave beaming will need to be within close proximity to the lock for the communication to succeed.
DEVICES
in the Main Window outline view or select one of the sub-folders.Edit…
button)Edit Device
dialogEdit Device Settings…
button and you'll see the configuration dialog:
, is a great optimization - some devices send out a message whenever they change - they don't actually send the necessary information for Indigo to automatically update state, but it is enough to bump the device to the top of the poll list so that the status update will occur much more quickly. And it keeps us from having to poll the device at regular intervals because we can just poll it when we see this specific message. How do you know to select this option? You can try the setting out: just select Only When Activity Detected
- we'll poll the device as frequently as we can given the conditions of the z-wave network.
Also shown in the settings dialog are any configuration parameters specific to that device (in this example the temperature units and display contrast). Indigo only shows settings if there is a custom device profile for a particular device. However, if no settings are shown you can still modify any configuration parameters by using the Interfaces->Z-Wave->Modify Configuration Parameter...
menu item.
If a Submit Device Information
button is visible, then you can use it to help us learn more about the device. When pressed a page will open in your browser asking for some more information that will help us and other users more effectively use the device. Please take time to accurately fill out the form as much as possible. The more information we have the more likely we will be able to add a custom device profile to fully support the device.
DEVICES
button).Define and Sync…
button.Sync
dialog disappears, just close the Edit Device
dialog.This will tell Indigo to query the device and update various information about it and may help with some communication issues.
DEVICES
button.Sync using node
popupSynchronize Z-Wave Device
dialog.
Note that not all devices can be replaced. Specifically, if a device has multiple personalities (like, for instance, a multi-sensor that has a motion sensor, temp sensor, humidity sensor, etc) and any of those dependent devices are used in Triggers, Conditions, Actions, or Control Pages, then you'll get an error message in the Event Log window
saying that you need to manually resolve those conflicts (or manually delete the device). Indigo helps with this process - see Deletion Dependencies for details.
DEVICES
in the Main Window outline view or select one of the sub-folders.Delete…
button (or press the Delete key on the keyboard).If the device has any deletion dependencies, Indigo will show the dependency dialog that will allow you to review and/or modify any of those dependencies. If you choose to continue the deletion process, the device will be deleted along with the dependencies.
The last thing you'll want to do is to exclude the device from your network if it's still functional. To do this you can use the Interfaces->Z-Wave->Start Controller Exclusion Mode
Interfaces→Start Controller Exclusion Mode
. Note you can exclude from any controller, not just the one it was included with.Define and Sync
button and press the New with Encryption Disabled
(only select Enabled if you're including a device which requires encryption to work correctly, such as a lock).Inclusion into network successful
in green just under the Add to network
buttons), confirm that the new node shows up in the popup at the bottom, and then press Sync
.Interfaces→Z-Wave→Optimize Z-Wave Network…
menu item and click Start Optimization
- you can do this at night just before going to bed when the network is likely to be the least busy.If your controller has a physical button, you may chose to follow this process because it requires fewer walks from your Mac to the devices being moved to the new controller:
Define and Sync
button.Sync
The Interfaces→Z-Wave
This menu selection puts the Z-Wave Controller into inclusion mode. You can then follow the steps from the device's manual to have it include itself from the network. Open and watch the Event Log window
for progress as it is included. This menu item is functionality the same as using the New with Encryption Disabled
button inside the Synchronize Z-Wave Device
dialog.
This menu selection puts the Z-Wave Controller into inclusion mode with encryption enabled. You can then follow the steps from the device's manual to have it include itself from the network. Open and watch the Event Log window
for progress as it is included. This menu item is functionality the same as using the New with Encryption Enabled
dialog.
This menu selection puts the Z-Wave Controller into exclusion mode. You can then follow the steps from the device's manual to have it exclude itself from the network. Open and watch the Event Log window
for progress as it is excluded. Note Indigo is able to exclude device s from any Z-Wave network.
