Indigo Mac Client
When you double click on the Indigo 5 icon in the Applications folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
Main Window Image
The Home Window is in 5 areas:
  1. Outline View
  2. Item List
  3. Item Detail
  4. Status Bar
The outline view shows all high-level objects (except Variables which have their own window): Devices, Triggers, Schedules, Action Groups, and Control Pages. Selecting one of these in the outline view will switch the Item List to view all of those types of objects. The same goes for folders that are under the high-level headings except only the devices in those folders will show.
To create a new folder, select the main object type in the list then click the plus (+) button at the lower-left corner of the outline view. A new folder will appear and you can just start typing its new name. To delete a folder, select it, then click on the gear icon or right-click the folder (bring up the contextual menu). The resulting menu will allow you to select Delete Folder the delete it. If the folder isn't empty, it will show you a sheet with 3 options: Cancel (do nothing), Delete Items (delete the items in the folder along with the folder), or Move Items (move the items to the parent first then delete the folder).
From the same menu, you can select Rename Folder… to rename it, Enable/Disable Remote Display (for devices, action groups, and control pages) to show/hide it in remote clients (like Indigo Web Server (IWS) pages or Indigo Touch), or copy the unique folder ID for use in Python scripts.
Device Contextual Menu Image
This menu will:
  4. Copy the unique ID of the device to the clipboard - to assist in writing Python scripts that use the device
  1. Enable/disable the event.
  3. Copy the unique ID of the trigger or schedule to the clipboard - to assist in writing Python scripts
  2. Copy the unique ID of the device to the clipboard - to assist in writing Python scripts that use the device
If you have no device selected, only controls that affect collections of devices are shown:
No Devices Controls Image
Each of the other device types have their own sets of controls.
Lights/Appliances and Sensors (Motion Sensors, etc)
For lights (dimmers), appliance modules (relays), and sensors (Motion Sensor, TriggerLinc, etc), you see the same details above with some of the others enabled as is appropriate for the device.
iMeter
Imeter Controls Image
The iMeter has its own detail area - it shows the current load in watts, total usage (since the last reset) and the date of the last reset. Use the Refresh All button to immediately update the information and the Reset Total Usage button to reset the total usage information.
Sprinklers (Pro Only)
Sprinkler Controls Image
Sprinkler detail allow you to turn on a specific zone, go to the next or previous zone, update the valve status. And, if a schedule is currently running, pause/resume it, begin running the previous schedule, and stop all activity.
Thermostats (Pro Only)
Thermostat Controls Image
The thermostat detail area shows the current temperature, humidity, mode, cool/heat setpoints, and fan mode. You can also adjust all of those as well as refresh the values and turn everything off. Note that on rev2 thermostat adaptors the circles next to cool and heat setpoints will be lit if their respective HVAC system is actually running (A/C or heater).
Control Input / Output Device (Pro Only)
I/O Controls Image
IO Device detail area shows the state of all the input and output states available for the device and you can update them immediately using the Get Input/OutputStatus button. The Outputs grid shows all available outputs and their status. If you're unfamiliar with the square push buttons on the Mac, when they are light, they are OFF - when they are dark, they are ON. Use the All Off button to turn off all binary outputs.
Plugin Devices (Pro Only)
Plugin Controls Image
Because plugin devices can define as many states as they like, we've provided a list of all states and values in the detail area for every plugin device.
Triggers and Schedules
The detail area for triggers and schedules is identical - it shows the triggering event (either a state change or some time/date description), whether the condition is always, rules, or a script, and a summary of actions. The popup will allow you to specify how the object is processed:
The Execute Actions Now button will do exactly that - execute all the actions associated with the object. NOTE: just as the triggering event will be ignored, so will any conditions associated with the object.
Action Group Controls Image
Control Pages
Event Log Window Image
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 5→Preferences… and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
In the Getting Started guide, we visited almost all the tabs on the Indigo Preferences window. We did, however, miss the General tab:
General Preferences Tab Image
Menu Image
  • About Indigo 5 - this will show the About window which will show what client and server versions you're running and what your registration code is
  • Preferences… - this opens the preferences dialog
File Menu Image
Go Menu Image
  • Browser Devices Page - this will open your default web browser to the built-in devices list
  • Browser Actions Page - this will open your default web browser to the built-in actions list
  • Browser Variables Page - this will open your default web browser to the built-in variable list
  • Browser Control Pages - this will open your default web browser to the control page list (this option is only available in Indigo Pro)
  • Event Logs Folder - this will open the Event Logs folder in the Finder
  • Purchase Hardware - this will open your default web browser to our online store (the Indigo Store) – if you are running a trial copy this item will be called “Purchase Indigo” and will take you to the Indigo purchase page
  • Online Support Forum - this will open your default web browser to our online support forums
INSTEON/X10 Powerline Submenu
Interfaces Insteon Menu Image
  • Enable/Disable - toggles the interface on and off
  • Configure… - opens the configuration preferences for this interface
  • Upload Settings… - opens the upload dialog
  • Manage INSTEON PowerLinc Links… - opens the PowerLinc link editor window
  • Manage INSTEON Device Links… - opens the device link editor window
  • Start Sync INSTEON Device Links… - starts any pending link sync operations
  • Stop Sync INSTEON Device Links - stops any ongoing linking operations
X10 RF Submenu
Interfaces X10RF Menu Image
Plugins Menu Image
The Plugins menu (Indigo Pro Only) will adjust based on the what plugins you have installed. Three menu items will always be present:
  • Reload AppleScript Attachments - this will reload all the attachment AppleScripts that are in the Scripts/Attachments directory of the Indigo system directory (/Library/Application Support/Perceptive Automation/Indigo 5/)
  • Online User Contribution Library - this will open the file library in your default browser where you can find and download user-contributed plugins, scripts, applications, etc.
  • Open Scripting Shell - this will open a terminal window and start the interactive Python shell with the Indigo module loaded - see the Scripting Tutorial for more information
For information about the plugins, see the About… menu item for each plugin.
Window Menu Image
Help Menu Image
  • Help for Devices - this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular item
  • Indigo 5 Documentation - this will open your browser to the landing page for all Indigo 5 documentation
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/ui_tour.txt
