Indigo 7.4 Documentation
Welcome to the Indigo 7.4 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 7.4.
  1. Getting StartedStart here!
  • Growl - adds the ability to alert you of special events via the Growl library. Growl 2.1, 2.2, and 3.0 are supported.
  • iCal Alarm Processor - a plugin that will monitor an IMAP email account for iCal alarm email messages and do some post-processing for you.
  • iTunes - makes iTunes information available for use in Indigo and allows you to control iTunes.
  • NOAA Weather - makes weather data from the National Oceanic and Atmospheric Administration available for use in Indigo.
With Indigo 7, we no longer ship the following plugins.
  • Airfoil - this plugin was replaced by the Airfoil Pro plugin listed above, so you'll need to create Airfoil devices and update your old Airfoil actions to use the new plugin. If you need to use the old plugin, you can get it on our Github repo.
  • DIRECTV DVR Control - this plugin, which allows Indigo to control some DIRECTV set-top boxes, is now in our Github repo to allow community improvements.
  • Vera Bridge - this plugin, which integrates with the Vera controller, is no longer needed since Indigo now supports Z-Wave locks directly. It is still available in our Github repo.
  • WeatherSnoop - the WeatherSnoop development team has taken over management of this plugin. Indigo 7.1.2 is the last version that will install the plugin automatically. Beginning with 7.2.0, you'll need to get the plugin from the Plugin Store.
  • /www/perceptive/wiki/data/pages/indigo_7.4_documentation/documents.txt
