We also have a Plugin Store so you can quickly check to see if there's a plugin for some specific device or service you're interested in. If one isn't there for something you'd like to see, just post an idea for a plugin on the forums and maybe some developer out there will think your idea is a good one and will build it.
  • /www/perceptive/wiki/data/attic/start.1725029637.txt.gz
  • Last modified: 2024/08/30 14:53
  • by jay
