Welcome to the Indigo 2023.1 Documentation pages. We've separated the docs into multiple areas, each focusing on some different part of Indigo 2023.1.
There are other help documents available below and from the purple question mark icon in the UI for the less frequently used dialogs in Indigo.
About Python IOM API v3.x and Indigo 2023.1: with API v3.0 and later, we have switched to Python 3. Older versions of the API use Python 2, and – with the release of Indigo 2023.1 – Python 2 is no longer supported. Further, plugins and scripts – both embedded and external – will run in Python 3 only. The Indigo Plugin Store highlights the plugins that will not work with Indigo 2023.1. See the API release notes for v3.0 for details. See Python Packages for a list of the additional Python packages that are installed with the Indigo 2023.1 installer.
A note about version numbers: As we've revised the Python IOM API and added features, we've incremented the API version number. The API version number takes the form of X.Y - where X is the major version and Y is the minor. We will increment the minor version any time we implement new functionality (but old functionality remains the same). We will only increment the major version if we implement a change in the API that will break backwards compatibility. See the API version chart to see which API versions were released in which Indigo version. Also, the HTTP and WebSocket APIs have versioning built-in to their respective URLs: /v2/api
, so if we make any breaking changes in the future, we will bump that version number.
