The help links inside the Indigo client app for your version will link to the appropriate version of the documentation, but here are direct links to the doc landing page for each version:
We also have a Plugin Store so you can quickly check to see if there's a plugin for some specific device or service you're interested in. If one isn't there for something you'd like to see, just post an idea for a plugin on the forums and maybe some developer out there will think your idea is a good one and will build it.
  • /www/perceptive/wiki/data/attic/start.1739913456.txt.gz
  • Last modified: 2025/02/18 21:17
