API v2.6 Release Notes
This version of the API shipped with Indigo 2021.2.0 - check the API Version Chart to see what version of the API is available in which Indigo versions.
- Added a
<URL>element to<MenuItem>and<PluginConfig>elements so that those menus will open a browser URL rather than run a plugin config dialog. - Added the full path to a file specified in a
/messages/call to the action props dict. - Added ability for a plugin to pass back a file reference for IWS to stream back to caller.
- Added the ability to convert
indigo.Dictandindigo.Listinstances to the Python equivalents (recursively). - Added the ability for a plugin to provide static content through IWS HTTP calls.
- Added ability for plugins to return custom error text on IWS generated error pages (ex 404, etc.)
- Added the capability to specify relative URLs in plugin dialogs so that the plugin can host its own help files.
- Added the Example HTTP Responder plugin to the SDK to illustrate most of the above features.
- Added an API to get the full path to the plugin's directory (
self.pluginFolderPath) - Added an API to get the support URL for a plugin (
self.pluginSupportURL) - Added an API to get the best URL to the web server (
indigo.server.getWebServerURL) - Added new
indigo.utilsmodule- Added a JSONEncoder subclass to encode python dates as strings (
indigo.utils.JSONDateEncoder) - Added FileNotFoundError exception (
indigo.utils.FileNotFoundError) - Added helper function to validate and return the appropriate
indigo.Dictto IWS to direct it to stream the contents of a static file back to the requester (indigo.utils.return_static_file) - Added helper function to validate the construction of an email address (
indigo.utils.validate_email_address)
