key_value_list = [
>>> print(json.dumps(python_dict, indent=4, cls=indigo.utils.JSONDateEncoder))
"allowOnStateChange": false,
"protocol": "ZWave",
"configured": true,
"states": {
"onOffState": true,
"batteryLevel.ui": "100%",
"batteryLevel": 100
"subType": "",
"globalProps": {
"zwConfigVals": {},
"zwShowWakeIntervalUI": true,
"zwModelId": 0,
"zwClassIds": [
4,
7,
1
"zwShowDumpDevToLog": false,
"zwLibType": 3,
"SupportsBatteryLevel": true,
"zwProtoVersMajor": 4,
"zwEndpointDevTypeMap": {},
"userWakeInterval": 60,
"indigoObjVersion": 10,
"version": "5.01",
"zwClassCmdMap": {
"c134": 1,
"c90": 1,
"c133": 1,
"c132": 2,
"c89": 1,
"c94": 1,
"c128": 1,
"c122": 1,
"c115": 1,
"c114": 1,
"c113": 1,
"c32": 1
"SupportsOnState": true,
"zwShowMainUI": true,
"zwAppVersMinor": 1,
"userPollInterval": 0,
"zwDevSubIndex": 0,
"zwEncryptClassCmdMap": {},
"address": 17,
"zwEndpointClassMap": {},
"zwModelDefnVers": 0,
"zwManufactureId": 0,
"SupportsSensorValue": false,
"zwAssociationsMap": {
"g1": [
1
"zwShowPollingUI": false,
"zwWakeInterval": 60,
"zwClassCmdBase": 0,
"zwAppVersMajor": 5,
"zwProtoVersMinor": 5,
"zwNodeNeighbors": [
1,
15,
16
"userPollingEnabled": true
"pluginProps": {},
"buttonGroupCount": 0,
"id": 854505717,
"supportsAllOff": false,
"errorState": "",
"remoteDisplay": true,
"energyAccumBaseTime": null,
"displayStateValUi": "on",
"subModel": "",
"version": "5.01",
"energyAccumTimeDelta": null,
"batteryLevel": 100,
"supportsSensorValue": false,
"ownerProps": {
"zwConfigVals": {},
"zwModelId": 0,
"zwClassIds": [
4,
7,
1
"zwLibType": 3,
"version": "5.01",
"zwClassCmdMap": {
"c134": 1,
"c90": 1,
"c133": 1,
"c132": 2,
"c89": 1,
"c94": 1,
"c128": 1,
"c122": 1,
"c115": 1,
"c114": 1,
"c113": 1,
"c32": 1
"zwDevSubIndex": 0,
"address": 17,
"g1": [
1
1,
15,
16
"description": "",
"onState": true,
"energyAccumTotal": null,
"address": "17",
"sharedProps": {},
"folderId": 1145028206,
"supportsOnState": true,
"sensorValue": null,
"energyCurLevel": null,
"enabled": true,
"displayStateValRaw": true,
This will be a python dictionary with all details about a device. One other feature to note here: by default, Python datetime objects are not serializable by the json module (odd oversight we believe). We have included a JSON encoder class that will solve this problem: indigo.utils.JSONEncoder. Just specify that as the cls parameter to a json dump call and any datetime class that's encountered during JSON encoding will be correctly converted to a string in the resulting json string:
sharedProps | dictionary | No | 2.3 | an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
Protocol Enumeration
| indigo.kProtocol |
Value | Description |
State Image Sel Enumeration
API v1.18+ only:
| indigo.kStateImageSel |
dev=indigo.devices[123]
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
| Parameters |
indigo.kAllDeviceSel |
Beep (API v1.11+ only)
indigo.device.beep(123)
| Parameters |
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (
you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
address='F8',
name='Device Name Here',
folder=1234)
| Parameters |
indigo.device.delete(123)
| Parameters |
| Parameters |
Enable/Disable
| Parameters |
Get Group List
| Parameters |
| Parameters |
ID : 1280166770 (integer)
ID : 106487666 (integer)
| Parameters |
Ping Device (API v1.16+ only)
if result["Success"]:
| Parameters |
| Parameters |
| Parameters |
| Parameters |
Status Request
| Parameters |
Toggle
indigo.device.toggle(123)
| Parameters |
Turn Off
indigo.device.turnOff(123)
| Parameters |
Turn On
indigo.device.turnOn(123)
| Parameters |
Unlock (API v2.0+ only)
indigo.device.unlock(123)
| Parameters |
Lock (API v2.0+ only)
indigo.device.lock(123)
| Parameters |
# Creating a device
name="Office Lamp",
address="F7",
# Getting a device
-- Getting a device
if (myDevice.remoteDisplay):
all off
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
| Parameters |
All Lights On
indigo.dimmer.allLightsOn()
| Parameters |
Brighten
indigo.dimmer.brighten(123)
| Parameters |
Dim
indigo.dimmer.dim(123)
| Parameters |
Set Brightness
| Parameters |
Set LED State
| Parameters |
Set On State
# Getting a device
(myDevice.onState)):
myDevice.folderId
# OR
Commands (indigo.iodevice.*)
Set Binary Output
| Parameters |
Commands (indigo.sensor.*)
Set On State
| Parameters |
Commands (indigo.relay.*)
Set LED State
| Parameters |
# Toggle the device
Decrease Speed Index
Decreases the speed index.
| Parameters |
Increase Speed Index
Increases the speed index.
| Parameters |
Set Speed Index
| Parameters |
Set Speed Level
| Parameters |
Commands (indigo.sprinkler.*)
Next Zone
| Parameters |
Pause Schedule
indigo.sprinkler.pause(123)
| Parameters |
Previous Zone
| Parameters |
Resume Schedule
indigo.sprinkler.resume(123)
| Parameters |
Run Schedule
Run a sprinkler schedule.
| Parameters |
Stop Schedule
indigo.sprinkler.stop(123)
| Parameters |
Set Active Zone
| Parameters |
# run schedule
Fan Mode Enumeration
indigo.kFanMode |
HVAC Mode Enumeration
indigo.kHvacMode |
Decrease Cool Setpoint
| Parameters |
Decrease Heat Setpoint
| Parameters |
Increase Cool Setpoint
| Parameters |
Increase Heat Setpoint
| Parameters |
Set Cool Setpoint
| Parameters |
Set Fan Mode
Adjust the fan mode.
| Parameters |
Set Heat Setpoint
| Parameters |
Set HVAC Mode
Adjust the HVAC mode.
| Parameters |
# set the heat setpoint to 78
