Indigo 5 Object Model Reference
The IOM is divided up based on the major object types: Devices, Triggers, Schedules FIXME (not yet implemented), Action Groups FIXME (not yet implemented), Variables, and Folders. There is also a utility base class (and subclasses), Action FIXME (not yet complete), that's used with the major object types that support actions.
# some code here
# that does something
You should be able to tell from the context if it's Python code or, sometimes, AppleScript, if we're comparing how to do something.
NOTE: Indigo uses Python v2.5. Python 2.6 is the default installation on Snow Leopard and 2.7 is the default installation on Lion (2.5 is default on Leopard), and there are differences, so make sure that you're using Python 2.5 for your development or you could get a nasty surprise when you turn your code into a plugin (if you're developing code outside the plugin architecture). Both Lion and Snow Leopard do have 2.5 installed, it's just not the default install. It's in this directory:
If you execute “python2.5” at the command line instead of “python” you'll get the installed 2.5 version.
TermMeaning
From an architectural perspective, the most fundamental design point that needs to be understood is that the host process that executes python scripts is a separate process from the IndigoServer process - which where the objects actually reside. We do this so that a single script or plugin can't bring down the entire IndigoServer.
For Scripters and Developers:
For Developers:
A couple of notes to help you understand these rules. First, the IOM allows Server Plugins to attach arbitrary attributes to any object. We call these plugin properties, or just props. Currently, those properties are only available through Python (they aren't exposed in the UI and they aren't exposed in AppleScript). They are only read-write for Server Plugin, but are readonly for all Python scripts.
ClassCommand namespaceNotes
InputOutputDevice (indigo.InputOutputDevice)indigo.iodevice.*manipulate an I/O device
RelayDevice (indigo.RelayDevice)indigo.relay.*manipulate a relay device
Schedule
Trigger
DeviceStateChangeTrigger (indigo.DeviceStateChangeTriggerindigo.devStateChange.*manipulate a device state change trigger
VariableChangeETrigger (indigo.VariableChangeETrigger)indigo.varValueChange.*manipulate a variable changed trigger
ActionGroup (indigo.ActionGroup)indigo.actionGroup.*manipulate an action group FIXME not yet implemented
Variables
Protocol Specific Commands
INSTEON specific commandsindigo.insteon.*commands specific to the INSTEON protocol FIXME not yet complete
X10 specific commandsindigo.x10.*commands specific to the X10 protocol FIXME not yet complete
General Commands
General and commonly used commandsindigo.server.*for commands that are more general in nature
Another very important concept that we’re introducing along with the IOM is the concept of an identifier, or id. Every top-level object in Indigo (action group, device, folder, schedule, trigger, variable) now has a globally unique integer ID associated with it. For those who never used AppleScript with the IndigoServer, the only way to reference an object in AppleScript is via the object’s name. This presents a problem: what if the name you stored in your script changes?
All commands in the IOM accept the id of an object or the object reference itself (along with the name). You should never store the object’s name. The id is visible in the various lists throughout the UI. You can also select any object in the GUI and right click it to get its contextual menu where you'll find a new Copy ID (123) item that shows the ID and allows you to copy it to the clipboard. Server plugins that define config UIs that use the built-in lists will get the id(s) of the object(s) selected in the lists rather than the name.
If you are a user of the Indigo AppleScript Dictionary, you may have certain expectations set about how you would use the IOM in Python. While there are similarities, there are also some non-trivial differences. Most of these will become apparent in the following sections, but we’d like to outline a few here.
First, and most obvious, is the nature of most objects in the IOM as we discussed earlier - using copies and updating the server when you change the properties. In AppleScript, when you alter an object’s property the change in instantaneous since the script is running in the IndigoServer process. That significant architectural difference is what led us to the split between objects and the commands that work on them.
item 1 of myArray
myArray[0]
Hierarchy Image
  • keys cannot contain spaces.
The last point can lead to some unexpected behaviors when compared to python dicts and lists, especially when multiple levels of container nesting is being used. What this means is that you can set items and append to items, but the items returned from the get / iterators are always new copies of the values and not references. For example, consider:
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
a['c'] = c				# a COPY of list C above is inserted (not a reference)
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
a['c'][4]					# works, but is slow because a temporary copy of a['c'] is created
Object Description
  2. They contain a “folders” property that has all the folders defined for that object type
Each of the objects above corresponds to one of the high-level objects in Indigo. In the UI, you know that you can create folders for each of those object types. To access the folders available for each type, you can reference the “folders” property: i.e. indigo.devices.folders. This is also a read-only indigo.Dict of folder objects. As with the other top-level classes, you manipulate folders within specific namespaces, described on the folder class page.
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (FIXME like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene “state” has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming() and subscribeToOutgoing() methods to see commands regardless of their effect on device state.
Python AppleScript
for dev in indigo.devices:
    # do stuff with dev here
repeat with dev in every device
	-- do stuff with dev here
end repeat
Filter Description
indigo.x10include X10 devices
indigo.relayrelay devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Triggers also have filters:
Filter Description
for var in indigo.variables:
    # all variables
Possible Exceptions
FIXME Need more explanation and example of how to handle exceptions here?
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
# You can use the deviceTypeId property to get the plugin's defined type
>>> tunes.deviceTypeId
u'mediaserver'
So, from a discovery perspective, the dir(obj) method will list all properties and methods for an object. The hasattr(obj, attr) will test an object to see if it has a specific property. The obj.%%class%% property will show you what class the object is. As you explore IOM objects, these methods will help you figure out how to use IOM objects effectively.
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/object_model_reference.txt
