Indigo 7.5 Documentation
Welcome to the Indigo 7.5 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 7.5.
  1. Getting StartedStart here!
  • iTunes - makes iTunes/Music information available for use in Indigo and allows you to control iTunes/Music. Note: As of Music v1.1.5 (Big Sur), you can no longer pair and control from a different Mac.
  • NOAA Weather - makes weather data from the National Oceanic and Atmospheric Administration available for use in Indigo.
With Indigo 7.5, we no longer ship the Growl plugin as the Growl Mac application has been deprecated. The plugin is still available in the Plugin Store if you continue to use Growl. We have also removed the iCal Alarm plugin.
  • /www/perceptive/wiki/data/pages/indigo_7.5_documentation/documents.txt
