Welcome to the Indigo 6 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 6.
This section contains links to documents that apply to the base Indigo product (both Indigo Lite and Indigo Pro). It's the starting point if your new to Indigo. We highly recommend starting with the Getting Started guide then progressing on to the other documents.
There are other help documents available below and from the purple question mark icon in the UI for the less frequently used dialogs in Indigo.
Indigo Pro ships with many plugins to offer greater functionality. This section contains links to the documentation for each plugin that ships with Indigo 6 (the version number after the plugin name indicates the Indigo version in which the plugin began shipping).
Note: The functionality of the INSTEON Commands plugin (available in Indigo 5) has been directly integrated into Indigo 6 so it doesn't appear as a separate plugin. Check the Managing Your INSTEON Network document for details. We've also done the same thing with the Action Collection plugin - see the Actions documentation for information on those actions.
We provide several powerful yet easy to use ways to extend Indigo. We support a Python-based API that allows 3rd parties to integrate devices, events, and actions natively into Indigo without sacrificing speed and stability of the core server. We also support a legacy AppleScript API that allows you to integrate with other Mac applications. This section provides links to all the documentation needed to develop scripts and plugins for Indigo.
Starting with Indigo 6 beta releases and API v1.4, we're going to add release notes specifically for API revisions so you can more easily locate new features and changes.
