Folders
Commands (indigo..folder.)
The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder., indigo.variables.folder., etc).
Delete the specified folder.
Get ID
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
